Cutoff frequency for parallel plate waveguide with two dielectric regions
12 replies · 3K views · last reply
warhammer
Plate separation is given as 2*10^-3 m. Waveguide propagates through two different permabilities. Find Frequency of Wave (Imgur Link with the Figure of the Problem is attached as well)
##f(cutoff) = {m}/{(2d*√μϵ)}##
The Imgur Link of the Problem with the figure - Problem Link. I did not paste it here as the post upload quality seemed heavily pixelated for some reason.
For this problem, what I did was to divide the waveguide into 2 sections of distinct permabilities to calculate the cutoff frequency. Since the problem asks for frequency of wave specifically I calculated the range of frequencies for which the waveguide will propagate in TM Mode.
Now I am confused as to whether this approach is fine or not (I think it should be because we do not have any more data supplied with the problem). Also, is this bifurcation technique fine or should I be finding the average of the 2 cutoff frequencies.
I have attached my work. I sincerely request someone to please take a look and guide me if my method is correct or not..
  • Handwritten working on lined paper calculating TM1 cutoff frequencies for a parallel plate waveguide with plate separation d = 2mm and two dielectric regions with constants 4 and 2.1, giving 37.5 GHz and 51.75 GHz.
From the statement of the problem, what can you say about the value of the reflection coefficient at the boundary between the two dielectrics?
Can you use this value of the reflection coefficient to figure out the angle of incidence of the TM1 waves at the boundary between the two dielectrics?
I believe that the answer to the problem will be a single frequency, not a range of frequencies.
(Your written work seems to imply that the cutoff frequency for a particular mode is the highest frequency that can propagate for that mode. But the cutoff frequency is the lowest frequency that can propagate. I don't think you will need the cutoff frequency.)
Thank you so much for your response!
The reflection coefficient should be zero, because the problem statement mentions there is no reflection loss.
I tried to use the reflection coefficient relationship to figure out angle of incidence.
##R= {(η2* \cos\theta1 - η1*\cos\theta2)}^2/{(η2* \cos\theta1 - η1*\cos\theta2)}^2##
Giving us ##η2* \cos\theta1 - η1*\cos\theta2=0## where 1,2 indicate angle of incidence and transmission respectively.
But I'm not sure how to tackle the angle of transmission in this case (I tried to express angle of transmission in terms of refractive index ~ dielectric constant and angle of incidence but to no avail). I think I'm still missing something...😓
Edit 1- Realised there is indeed a way. To completely extinguish reflected wave we can take Incident Angle ~ Brewster's Angle where ##\tan\theta B={η2}/{η1}##.
This gives B~I=36 degrees (approx).
OK. I agree that the angle of incidence at the interface of the dielectrics should be the Brewster angle which calculates to about 36o.
This means that you know the specific orientation of the wavefronts which reflect back and forth between the conducting plates in the first dielectric to produce the TM1 mode. For a given orientation of the wavefronts, there is only one wavelength (or frequency) that is possible that would correspond to a TM1 mode. Have you studied anything that would allow you to determine the wavelength or frequency of the wave from the angle of orientation of the wavefronts? I don't know what you have already covered.
To be honest I don't think I have studied anything pertaining to this (I've tried to rack my brain for all possible ways, but they're all circular approaches). If possible sir, could you refer the specific topic that can help me crack this problem. I will try to use it to get the algorithm for solution and report back on my results..
Is this a homework problem that you have been assigned or is it a problem you came across and want to understand? If it's a homework problem, then I would think that the background material for this problem would have been covered by the instructor in class or as a reading assignment. (If not, then the instructor is expecting a lot! )
It is the latter! We have already covered waveguides in our class and already moved up far ahead to Retarded Potentials and Radiations. Because the instructor is notorious for springing up surprises on students with such knotty problems during grading (without any relevant background material being covered as he's of the belief that students should use all avenues to mop up the rest of the job by taking initiative😬), I decided to tackle some problems that seemed to be outside the material covered in class out of my own volition to be on my toes. And honestly, I was stumped by this one as soon as I read it. Outside of the knowledge I had consumed during the class as well as from the relevant course textbook! Additionally, I have a tendency and a tenacity to really get at the root of virtually any Physics topic I cover, as part/outside of curriculum. That involves reading same or related content from different textbooks, building my intuition and solving problems copiously. I tend to believe it's a good habit (hopefully...😅)
{Edit- I'm not sure if it is useful but we have one additional source of information after deploying concept of Brewster's Angle. We also get the Transmission Angle at 54 degrees using the relevant relationship between them.}
OK. Since the problem is not an assignment, I think it's OK if I show how I thought about the problem. I think it is correct. But, I could be overlooking something. You can find detailed analyses of waveguides based on Maxwell's equations on the web. [For example, see videos 19, 20, and 21 here. Video 21 deals with the parallel plate guide.] But, I don't think we need all that.
Consider the diagram given in the problem statement:
Diagram of a parallel plate waveguide with two dielectric regions: a zigzag red ray bounces between the top and bottom conducting plates in the left region labelled εr1, and the right region is labelled εr2, with an arrow along the z axis.
The red line can be thought of as a ray that reflects back and forth between the conducting plates. We can add wavefronts as shown below:
Diagram of a parallel plate waveguide with two dielectric regions: a left section labelled ε_r1 and a right section labelled ε_r2, with a red ray zigzagging between the conducting plates and blue and green wavefront lines, with a z axis pointing right.
We have “blue wavefronts” propagating to the right and upward and we have "green wavefronts" propagating to the right and downward. For TM waves the magnetic field is oscillating in and out of the page while the electric field oscillates as shown below:
Diagram of a parallel plate waveguide with two dielectric regions: a red zigzag ray reflects between the plates, with blue and green arrows marked E. The left region is labeled ε_r1 and the right region ε_r2; the z-axis points right.
This is a very schematic picture. The blue and green wavefronts actually overlap throughout the region between the plates. See figure 24-17 in this Feynman lecture for example. So, at any point between the plates at some instant of time, the net electric field will be the superposition of a “blue electric field vector” and a “green electric field vector”. At the surface of either plate, the horizontal components of the blue and green vectors must cancel (boundary condition for E at the surface of a perfect conductor).
Consider the figure below:
Diagram of a ray reflecting between two parallel horizontal plates: segment AB goes from the top plate down to the bottom plate, segment BC goes back up to the top plate (dashed), and segment CD goes down to the bottom plate, with a blue arrow labelled E at B pointing up and to the left.
Line AB represents the edge view of an imaginary plane that extends into and out of the page and it is oriented parallel to blue wavefronts. This plane is assumed to be fixed relative to the plates and does not move with the waves. Likewise, BC is the edge view of a fixed plane oriented parallel to green wavefronts. Suppose that at some instant of time, the blue electric field at B is as shown. Then the green E-field at point B must point along the dotted line BC such that its horizontal component cancels the horizontal component of the blue E-field at B. So, it must be that at this instant of time the E-fields at B look like
Diagram of two parallel horizontal conducting plates with a zigzag line AB-BC-D reflecting between them; blue arrow labeled E at B pointing up-left, green arrow labeled E at B pointing up-right, and a dashed segment from B to C.
Since the dotted plane BC is parallel to the green wavefronts, the green electric field is the same at every point of plane BC. So, the green field at point C is the same as the green field at point B:
Diagram of a ray bouncing between two parallel conducting plates, with points A and C on the top plate and B and D on the bottom plate. Green and blue arrows labelled E show electric field vectors at points B and C.
The net horizontal component of the E-field must vanish at point C. So, the blue field at C is as shown below:
Diagram of a ray reflecting between two horizontal plates, with points A and C on the upper plate and B and D on the lower plate. Blue and green arrows show electric field vectors E at B and C.
Line CD represents the edge view of a fixed imaginary plane oriented parallel to the blue wavefronts. So, the blue electric field is the same at all points of this plane. Thus, we can see that the blue field on AB is the same as the blue field on CD. That is, the magnitude and phase of the blue field are the same on the planes AB and CD. Therefore, the planes AB and CD must be separated by a perpendicular distance equal to an integer number, m, of wavelengths:
Geometric diagram of a ray zigzagging between two horizontal parallel lines, with points A and C on the upper line and B and D on the lower line, a dashed segment from C to B, and an orange segment from B labeled mλ meeting segment CD at a right angle.
Let ##b## denote the distance between the plates and introduce the angle ##\phi## as shown:
Diagram of a parallel plate waveguide shown in edge view: two horizontal conducting plates, with the top plate labelled with points A and C and the bottom plate with B and D, separated by distance b. A tilted ray line runs from A to B, with angle phi marked at A, and an orange line labelled mλ runs from B to a right-angle mark on segment CD.
I leave it to you to use geometry and trig to derive the important result $$m \lambda = 2b\sin \phi.$$ This is the key equation. It states that if the wavefronts are tilted from the vertical by a given angle ##\phi##, then only certain discrete wavelengths can propagate between the plates.
I also leave it to you to find how angle ##\phi## is related to the angle of incidence of the waves at the boundary between the two dielectrics. Since you have already found the angle of incidence, you can deduce the value of ##\phi##. Then you can find the allowed wavelengths for this ##\phi## from the equation above.
The problem states that you are dealing with a ##TM_1## mode. I believe the subscript 1 means you have the mode where the integer ##m## equals 1. So, ##\lambda## is determined for this problem. From this, you can easily find the frequency.
Firstly, a big big thank you for such an expansive answer laden with resources! Honestly, a thank you is not even a sufficient response to convey my gratitude.
Using your approach, I found ##\phi=28 \ degree##
Finally the frequency I found was about 64 GHz.
I wanted to share something else too. Additionally, I discovered another approach to such problems rooted in similar principles given in Hayt's Engineering Electromagnetics. Crux of that approach was ##\theta m=\arccos ({m\lambda}/{2nd})## via which one could state that ##\cos \theta m={f cutoff}/{f}## Where ##\theta m## is allowed ray angle (found using ##90-\theta## Brewster's )
I don't see how to get 28o for ##\phi##. I defined ##\phi## as the angle that the wavefronts make to the vertical.
Diagram of a parallel plate waveguide with two dielectric regions; wavefronts AB and CD are drawn at angle phi to the vertical, with a right-angle marker and the path mλ between wavefronts, labelled b for plate spacing.
I believe with this definition, ##\phi## turns out to equal the angle of incidence at the interface of the dielectrics. That is, ##\phi## is equal to the Brewster angle: ##\phi = \theta_B = 36^o##.
This agrees with what I found for the frequency using ##\phi = 36^o##.
The formula ##\theta_m=\arccos ({m\lambda}/{2nd})## can be rearranged as $$m \lambda = 2nd \cos \theta_m.$$ If ##\theta_m## is the complement of the Brewster angle, then ##\cos \theta_m = \sin \theta_B = \sin \phi##. So, the formula can be written as $$ m \lambda =2nd \sin \phi$$ and this is very close to the formula mentioned in my previous post: $$ m \lambda =2d \sin \phi$$ These can be made to agree if the symbol ##\lambda## is interpreted differently in the two equations. In the formula from my previous post, ##\lambda## is the wavelength in the first dielectric. If ##\lambda_0## is the wavelength that the waves would have in a vacuum, then ##\lambda## inside the dielectric would be ##\lambda = \lambda_0/n##, where ##n## is the index of refraction of the dielectric. So, your formula ## m \lambda =2nd \sin \phi## would agree with my formula ## m \lambda =2d \sin \phi## if the ##\lambda## in your formula is the vacuum wavelength ##\lambda_0##.
I think the mistake I made is pretty much covered in this image. Since the green angles refer to incidence and reflection angle and the orange refers to inclination of ray with the wavefront ( ##\phi## ) I calculated it on this assertion, without factoring in my initial assumption that there is no reflected wave for the said case.
Hand-drawn ray diagram: a green horizontal line marks a surface with a black zigzag ray reflecting off it, red vertical wavefront lines, a dashed blue vertical normal, purple dashed arcs marking angles at the reflection point, and an orange arc near the top of the normal.
However I realised if you input ##\phi = 36## into the above equation, one gets ##\lambda = 2* 0.002 * \sin 36##
This gives ##\lambda = 0.00235##
Using ##\lambda * frequency = c## we get ##f = {3E8}/{0.00235}##
##f = 127 Ghz## and not 64 Ghz..
TSny said:
This formula ##\theta_m=\arccos ({m\lambda}/{2nd})## can be rearranged as $$m \lambda = 2nd \cos \theta_m.$$ If ##\theta_m## is the complement of the Brewster angle, then ##\cos \theta_m = \sin \theta_B = \sin \phi##. So, the formula can be written as $$ m \lambda =2nd \sin \phi$$ and this is very close to the formula mentioned in my previous post: $$ m \lambda =2d \sin \phi$$ These can be made to agree if the symbol ##\lambda## is interpreted differently in the two equations. In the formula from my previous post, ##\lambda## is the wavelength in the first dielectric. If ##\lambda_0## is the wavelength that the waves would have in a vacuum, then ##\lambda## inside the dielectric would be ##\lambda = \lambda_0/n##, where ##n## is the index of refraction of the dielectric. So, your formula ## m \lambda =2nd \sin \phi## would agree with my formula ## m \lambda =2d \sin \phi## if the ##\lambda## in your formula is the vacuum wavelength ##\lambda_0##.
Indeed! The formulae are equivalent and mirror approaches for a particular situation..!
In calculating 127 GHz you used the speed of light in a vacuum. But you need to use the speed in the dielectric.
Yes! I rectified immediately after making the above comment without considering the dielectric. Very impulsive of me and consequently embarassing to leave out such a minor detail 😅
Thank you so much for your painstaking guidance and support sir. Really learnt a few new things while trying to solve this problem🙏🏻😃
