DeBroglie and Time Dilation Paradox
The discussion revolves around the DeBroglie wavelength and its implications for time dilation, particularly in the context of a moving particle, such as an electron, compared to a light clock. Participants explore the paradoxes that arise when considering the energy and frequency of moving particles in relation to time dilation effects.
  • One participant presents a paradox regarding the DeBroglie period of a moving electron, questioning how its energy can remain consistent with time dilation effects.
  • Another participant suggests using photons as an analogy, noting that red-shifted light appears to have lower energy due to its lower frequency, raising questions about energy perception in moving frames.
  • A participant elaborates on the relationship between energy, momentum, and phase of the de Broglie wave, indicating that while time dilation affects the rate of phase change, the energy of the moving particle increases correspondingly.
  • Another participant introduces the four-vector formulation of the DeBroglie relation, providing calculations for an electron's momentum and frequency in different frames, demonstrating that the higher energy correlates with a higher frequency in the moving frame.
Participants express differing views on the implications of time dilation for the energy and frequency of moving particles. There is no consensus on how to resolve the paradox presented, and multiple competing perspectives remain throughout the discussion.
The discussion involves complex relationships between energy, frequency, and relativistic effects, with participants addressing assumptions about the behavior of particles in different frames of reference. Some mathematical steps and definitions are not fully resolved, leaving room for interpretation.
DuckAmuck
I need someone to resolve this paradox for me.
Before I start, here are the basic ideas:
Okay, so every moving particle has a DeBroglie wavelength: E=hc/[tex]\lambda[/tex].
This also means that each particle has a frequency: E=hf
So it also has a period: E=h/[tex]\tau[/tex]
So any given mass has a DeBroglie period of [tex]\tau[/tex]=h/mc^2
Consider the train problem with the light clock. The guy on the train sees the light clock ticking normally. Now an outside observer sees the train moving and thus will see the light clock ticking slower. This is due to time dilation: t' = t[tex]\gamma[/tex].
Okay, so here is the paradox: Now imagine you have an electron on the train instead of the light clock and you are monitoring it's DeBroglie period. Now since it is a time period, it should appear to increase in duration to the observer outside of the train. This cannot happen however, because if the time period increase, the frequency would decrease meaning the energy would decrease. A moving particle must have more energy than it does at rest.
What is the deal here?
If we talk use the example of photons (visible reigion) instead of electrons (since both behave as waves) we would observe a shift towards the red end of the spectrum- the doppler shift. So this leads to another question; is the energy of red-shifted light lower than it would be (if observed at rest relative to the source) because it appears to have a lower frequency?
As usual with relativity, you need to consider the whole picture, not just one part of it.
The phase of the de Broglie wave with energy E and momentum p (ignoring unit conversion constants of hbar) is given by the integral of (E dt - p.dx), which for constant velocity can be rewritten as
phase = E (1-v2/c2) t.
If the energy in the rest frame is E0 = mc2 then the increased energy E of the moving object is given by
E = E0/sqrt(1-v2/c2).
Substituting for E in the previous expression, this gives:
phase = E0 sqrt(1-v2/c2) t
From this, you can see that when the space-like phase change due to momentum is taken into account, the rate of change of phase with time does indeed decrease with the time dilation factor, as previously mentioned, but the energy increases by the same factor.
Here is a good page to start learning the four-vector de Broglie relation which unifies the usual three-vector de Broglie relation and Planck's relation.
http://physics.nmt.edu/~raymond/classes/ph13xbook/node73.html
Let's take the example of an electron. Given the four-momentum p = (E/c,px,py,pz) and the wave-four-vector k = (f/c,kx,ky,kz) where E is the total energy of the electron, px is the x component of the electron's momentum, f is the (temporal) frequency and kx is the wavenumber (spatial frequency). The four-vector formulaiton of the DeBroglie relation is:
p = hk
So, for an electron at rest
p = (2.7E-22,0,0,0) N s
k = p/h = (4.1E11,0,0,0) m-1
f = 1.2E20 Hz
Boosting to the frame where the electron is moving at 0.6 c in the x' direction.
p = (3.4E-22,2.0E-22,0,0) N s
k = p/h = (5.2E11,3.1E11,0,0) m-1
f = 1.5E20 Hz
So we see that the full formulation of the DeBroglie relation correctly predicts the higher frequency in the frame where it has higher energy.
  • · Replies 54 ·
  • · Replies 88 ·
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 45 ·
  • · Replies 70 ·
