Debugging Matlab code for Fourier transform with cosine vector
29 replies · 6K views
PainterGuy
Hi
Could you please help me to fix the code below? I know that the code is completely wrong but I have tried to write it down so that you can get an idea what I'm trying to do. Thank you.
Code:
    %%file name fourier.m
    clear all; close all; clc;
    f = 0; %% 0 Hz to 100 Hz, with 0.1 step, there would be 1000 frequencies
    cos_v=[1:1:1000]; %%vector to store values
    f_w=[]; %% defining a vector
    for i1=[0:1000]; %% for loops begins, with loop index i1
    f_w = sqrt(1/(4*f));
    cos_v(i1)=f_w*cos(2*pi*f*x); %% i1 serves as an index for cos_v vector elements too
    f=f+0.1;
    end
    combined_sinusoids=sum(cos_v); %% cos_v(1)+cos_v(2)+cos_v(3)+...
    x = [0:0.2:500];
    y = combined_sinusoids;
    plot(x, y)
I think you probably should describe what you are trying to do. Looking at the code, it looks like you end up plotting a single constant value, y = combined_sinusoids, on an XY plot.
Thank you for the reply.
I'm trying to understand Fourier transform and wanted to analyze something, and that code is a result of that effort. Explaining the problem in full detail here would be little difficult because so far I haven't organized all my effort.
But let me try. F(f)=f(w)=sqrt(1/(4*f)) is cosine Fourier transform of f(x)=1/sqrt(x). I'm trying to see how well first 100 sinusoids represent f(x).
Thank you.
I see. I had lost track of the dimensions. What makes you think it is wrong? Is the plot all wrong? Or does it abort with an error message before that? If there are error messages or if you print intermediate steps (reduce the dimensions to see a reasonably small number of values), then you may get some hints.
PS. I do not have access to MATLAB, so I can't experiment with your code at all.
Thank you.
The code doesn't compile. You don't have MATLAB installed or you are just away from your system? Anyway, let's see if someone else jumps into help. Anyway, thanks.
Is that a 0 array index in cos_v(i1) on line 9? That looks wrong. When MATLAB doesn't compile, it usually tells you what line it has problems with and why. You should indicate what it said.
PS. Retired. No MATLAB at home. I'm thinking about buying it.
PainterGuy said:
Matlab:
Why not make f a vector containing the frequencies?
PainterGuy said:
Matlab:
cos_v=[1:1:1000];
This statement doesn't make sense. In any case, it doesn't appear that cos_v needs to contain any initial value, so use
Code:
cos_v = zeros(1000);
PainterGuy said:
Matlab:
This statement is pointless. Again, use zeros to initialize f_w to the right size.
PainterGuy said:
Matlab:
Thesis not the correct syntax for a for loop. And if you define f as a vector, the loop can be replaced by vector operations, which are much more efficient.
PainterGuy said:
Matlab:
What is x?
PainterGuy said:
Matlab:
    x = [0:0.2:500];
    plot(x, y)
combined_sinusoids will be a scalar, so y will be a constant. The statement for x is also incorrect, see above.
Thank you, @FactChecker, @DrClaude.
I believe MATLAB treats every variable (even a constant) as a vector. A vector is a one-dimensional array and a matrix is two-dimensional array.
I've experience with C++ so I'd tend to stick the syntax of C++ so as I learn more about MATLAB I'll think more in MATLAB terms.
How do we define a variable in MATLAB if the require size is not known?
I've seen that mostly for loop is defined as, say, "for index=0:1000:. But I don't see why "for i1=[0:1000]" is wrong; yes, we can say that brackets are unnecessary.
What is x?
"x" could be a floating-point variable and it can take values from 0 to infinity. In C++ it could be written as "float x;"
Yes, I want to evaluate the value of function combined_sinusoids for particular values of 'x'.
I hope it's little better now. I'm posting the code with some revisions and also the error. Thank you.
Code:
    f = [0]; %%defining and initializing a constant vector
           %%0 Hz to 100 Hz, with 0.1 step, there would be 1000 frequencies
    cos_v=zeros(1000); %%defining and initializing vector to store values
                       %%a vector with 1000 zeroes
    f_w=[0]; %% defining and initializing a vector
    double x; %%"x" is a floating point variable which can take values from 0 to
                   %%infinity, in C++ we could have written "float x" or "double x"
    f=f+0.1;
    f_w=0
    end
    plot(x, y)
Error:
Code:
? Undefined function or variable 'x'.
Error in ==> fourier_new at 13
The default data type in MATLAB is double, so your "double x" statement is not doing anything for you. You should delete it. But I don't see any assignment of values to x before it is used in that line.
Thank you.
But if I don't define "x" then how am I going to use it in the expression below?
Code:
It's going to be undefined variable.
You have to initialize x to some values. It's not enough to just say what it's type is. Put your "x = [0:0.2:500];" line up before x is used in a calculation.
Thank you.
Should I really do it? I don't think so because that's not what I'm trying to do. If x is initialized then the expression "cos_v(i1)=f_w*cos(2*pi*f*x)" will be evaluated for all elements of vector x each iteration of the loop. I experimented with it; see below. I want to evaluate the expression "combined_sinusoids" later for different values of "x".
Code:
 x = [0:0.2:1]
x =
         0    0.2000    0.4000    0.6000    0.8000    1.0000
>> cos(2*pi*0.1*x)
ans =
    1.0000    0.9921    0.9686    0.9298    0.8763    0.8090
The equation for cos_v(i1) is evaluating a number or array of numbers. It is not defining a function of x. So x must have a value or array of values for the calculations at that point. If you set x to a single value, then that will be all you get. Since the equation for cos_v(i1) is not in a loop which changes the value of x, you will only end up with one number for it.
To develop this type of code, I like to reduce the dimensions to a small number and print intermediate results after each calculation. The dimensions can be increased once you are satisfied that the code is working as expected.
Thank you.
Actually I don't want to assign any value to x until later once the loops end. Please have a look here: https://www.mathworks.com/matlabcen...efine-a-variable-without-assigning-it-a-value
I'm not getting another error about dimension but it looks like that there shouldn't be any problem with the dimensions.
Code:
    f = [0.1]; %%defining and initializing a constant vector
    x=[]; %%"x" is a floating point variable which can take values from 0 to
    for i1=[1:1000] %% for loops begins, with loop index i1
    f=f+0.1;
    f_w=0;
    end
    plot(x, y)
Error:
Code:
?  In an assignment  A(I) = B, the number of elements in B and
 I must be the same.
So what value would you calculate for cos(2*pi*f*x) when x has no value? This is not a programming question. It is a trigonometry question.
@PainterGuy, it seems you want to plot y as a function of x, and you think the way to do this is specify the formula for y in terms of x without specifying what x is, and then just say plot(x, y). MATLAB doesn't work like that. You have to specify the values of x that you want to plot (i.e. define x as a vector x = xmin:xstep:xmax), and you have to do that before you specify what y is (or any other expression involving x).
Thank you.
I get your point. Please note that I'm learning Matlab.
I made few changes but still it's giving an error.
Code:
    syms x; %%"x" is a floating point variable which can take values from 0 to
    f=f+0.1;
    f_w=0;
    end
    x=linspace(0,10,2000);
    plot(x, y)
Error:
Code:
? The following error occurred converting from sym to double:
Error using ==> mupadmex
Error in MuPAD command: DOUBLE cannot convert the input expression into a double array.
If the input expression contains a symbolic variable, use the VPA function instead.
But you are still putting x=linspace(0,10,2000) in the wrong place. It needs to go before the loop, i.e. replace your line syms x. There are other changes you will need to make as well, but that's definitely where you need to specify the values that x takes.
Thank you.
The following sample code could help you to see what I'm trying to do. The code works fine. I have made few changes to the main code but as you pointed out it requires more fixes. Could you please guide me how to proceed?
Sample Code:
Code:
clc; clear;
'This program will calculate values of cosine function'
syms t; %% t (time) is a symbolic variable and can be assigned any value
syms f; %% f (frequency) is a symbolic variable and can be assigned any value
f = input('Enter value of f: ');
t = input('Enter value of t: ');
y=cos(2*pi*f*t);
fprintf('The value of cos(2*pi*f*t) is %d \n',y)
Main Code:
Code:
    f_w=[0]; %% defining and initializing a vector, Fourier transfor,
    f_w = sqrt(1/(4*f)); %% Fourier transform
    f=f+0.1; %%incrementing f
    f_w=0; %%setting f_w=0 for next iteration
    end
    x = input('Enter value of x: ');
    fprintf('The value of combined_sinusoids is %d \n',y)
Error:
Code:
In the sample code, both f and t are given numerical values in the 'input' lines before they are used in a calculation. Likewise, you need to give the x array numerical values before you try to use it in a calculation. Set the x array to an array of specific numerical values before the cos_v(i1)=f_w*cos(2*pi*f*x) line.
Then make cos_v a function that takes x as an argument, which you can later call for different values of x. For simple cases like this you can use an anonymous functions to do this:
Matlab:
F = (0:1000) / 10;
cos_v = @(X) sqrt(1./(4*F)) .* cos(2*pi*F.*X);
After this you can call cos_v(X) for any vector X with 1001 elements (the same length as the vector F) and it will return the vector of 1001 elements sqrt(1./(4*F(i))) * cos(2*pi*F(i)*X(i)) for i between 0 and 1000.
Declaring a variable to be "double" doesn't even mean anything like it would in C++. Matlab uses dynamic typing, like Python/Ruby/Perl/Lisp and unlike Fortran/C/C++/Java which use static typing. The difference is that in statically-typed languages types are assigned to variables in the source code while in dynamically-typed languages types are assigned to the objects themselves and the language environment keeps track of this at runtime.
In Matlab it is perfectly legal to for instance assign a variable x to a number, and then later to a function handle, and then later a cell array:
Matlab:
x = 1.23;
x = @sqrt;
x = {1, 2, 3};
and you can ask what the type of the value of x currently is by calling the class function:
Matlab:
>> class(x)
ans =
cell
(This is why you can have e.g. a print function in many scripting languages for which both print(3) and print("hello") work.)
Thank you, @FactChecker, @wle.
I'm sorry if I'm going in circles. I'm sure that there wouldd be many different ways to implement the same logic but I'm trying to stick with original code to see where I'm really going wrong. Seemingly, the logic is not that wrong but there is something wrong with the implementation. As I mentioned that I'm learning Matlab in view of 'basic' C++ background. I have tried to make few changed but still it's not really working. Could you please help me? Thank you.
Matlab:
    f = [0.1]; %defining and initializing a constant vector
    cos_v=zeros(1000); %defining and initializing vector to store values
    f_w=[0]; % defining and initializing a vector, Fourier transfor,
    x=sym('x'); %"x" is a floating point variable which can take values from 0 to
    for i1=[1:1000] % for loops begins, with loop index i1
    f_w = sqrt(1/(4*f)); % Fourier transform of 1/sqrt(x)
    cos_v(i1)=f_w.*vpa(cos(2*pi*f*x)); % i1 serves as an index for cos_v vector elements too
    f=f+0.1; %incrementing f
    f_w=0; %setting f_w=0 for next iteration
    end
    combined_sinusoids=sum(cos_v); % cos_v(1)+cos_v(2)+cos_v(3)+...
    x_temp = input('Enter value of x: ');
    subs(combined_sinusoids,'x',x_temp);
    y_vpa=vpa(y);
    fprintf('The value of combined_sinusoids is %d \n',y_vpa)
    fprintf('The value of 1/sqrt(x) is %d \n',vpa(1/sqrt(x)))
    fprintf('Difference between 1/sqrt(x) and approximation by combined_sinusoids is %d \n',abs(y-(1/sqrt(x))))
Error:
Matlab:
Error in fourier_new (line 14)
If you insist on keeping the x value unspecified in the line defining cos_v(il), then you need to use a function definition like @wle mentions in the post above. Other than that, there is no point in asking for help that you do not intend to take or even consider seriously. I am going to bow out from this discussion.
My sincerest apologies, @FactChecker. I didn't intend to disregard your suggestions. I was just looking at the problem from a particular angle. I have mended the code and have tried to incorporate what you suggested. Unfortunately, it's not working as intended. Firstly, it's outputting thousands of values; secondly, while loop isn't working as intended even when 'y' is input; thirdly, 'break' statement doesn't work. Thank you.
Matlab:
      f_w=[0]; % defining and initializing a vector, Fourier transform,
      user_decision = 'y';
while user_decision == 'y'
      cos_v(i1)=f_w.*(cos(2*pi*f*x)); % i1 serves as an index for cos_v vector elements too
    end
    fprintf('The value of 1/sqrt(x) is %d \n',(1/sqrt(x)))
    user_decision=input('Would you like to continue, enter Y/N: ');
    if user_decision=='n'
        break;
    end
end
Please have a look on this video:
Matlab isn't C++ and programming by guesswork (assuming things will work like in C++) is not a good idea. You should look up documentation and/or try simple commands at the interactive prompt to check that they do what you think they do.
Like I pointed out before, Matlab deals with variables differently than statically typed languages like C++ do. There is no analogue of typed variable declarations like "double x;" in Matlab. The line "x=sym('x')" in your code does nothing useful and definitely doesn't do what your comment after it says it does (it binds x to a symbolic object which you subsequently never use).
zeros(1000) creates a 1000 by 1000 matrix, not a 1000 element vector. Later when you call sum it sums the columns, so the variable y ends up being a 1000 element vector instead of a single number. When you print a vector the behaviour is to loop over the contents.
Are you typing 'y' with or without the quotes? The documentation says Matlab evaluates the input as an expression and you should pass 's' as a second argument to disable this and simply read the input as a string.
However you should consider whether you really need to read input like this in the first place. Probably a better approach would be to write a function that computes what you want (Matlab functions can return multiple values), which you can then run interactively or call from some other Matlab code. As far as I can tell this function does and returns the results of the calculations you were trying to do (whether it is actually computing a Fourier transform is a different question):
Matlab:
function [ result, ideal, delta ] = fourier(x)
    f = (1:1000) / 10;
    f_w = sqrt(1./(4*f));
    cos_v = f_w .* cos(2*pi*f*x);
    result = sum(cos_v);
    ideal = 1 / sqrt(x);
    delta = abs(result - ideal);
end
This returns three values (the variables result, ideal, delta) that you seemed to want to print. You can call it interactively from the prompt by doing e.g. [r, id, dt] = fourier(2).
Thank you, @wle, @FactChecker .
It works now. I'll implement the same code using a function as suggested soon. I had thought that Matlab is more of like a calculator than a language like C++ but it looks like I was wrong.
Matlab:
      f = [0.001]; %defining and initializing a constant vector
      cos_v=0.*[1:500000]'; %defining and initializing vector to store values
    for i1=[1:500000] % for loops begins, with loop index i1
      f_w = sqrt(1/((pi^2)*f)); % Fourier transform of 1/sqrt(x)
      f=f+0.001; %incrementing f
    end
    user_decision=input('Would you like to continue, enter Y/N: ','s');
        break
    end
end
Well to be fair Matlab's programming language isn't exactly stellar and the environment and community tend to treat programming as an afterthought.
Even using the approach you use, there are redundancies in your code:
Matlab:
Matlab:
The square brackets are redundant in these cases. They're also misleading for f, since you're using it as a scalar. (Technically Matlab doesn't distinguish between a scalar and a 1x1 array, but it's still a good idea for the notation to reflect the use.) The variable i1 is also unnecessary if you vectorise your code. Also, you're writing a lot of comments that just repeat what the code already says, which isn't useful, and they seem to be getting out of sync with your code.
Matlab:
cos_v = zeros(1, 500000) is the more direct way to do this. (You should also consider making the size a variable or calling length(cos_v) instead of repeating the same array sizes/number of loop iterations multiple times.)
Matlab:
Matlab:
These assignments don't accomplish anything, since you bind f_w to the value you want to use at the beginning of the for loop.
Matlab:
Why not just do y = sum(cos_v), or omit y and just use combined_sinusoids later in your code if you want to use a self-documenting name. (For that matter, if you want to use a for loop anyway why not compute the sum in the loop instead of constructing the vector cos_v?)
Matlab:
       break
    end
You don't need this. You break out of the while loop anyway if user_decision is different from 'y'.
Hi,
Could you please help me to remove this error? Thank you.
Matlab:
>> x=2;
>> 1./{(5.*exp(3.*x))+(2.*exp(-3.*x))}
Undefined operator './' for input arguments of type 'cell'.
PainterGuy said:
Hi,
Matlab:
>> x=2;
I removed the braces and used parentheses instead and it works. I'd say that as MATLAB is a programming language too so the use of braces trick MATLAB into thinking that the expression is an array or something of that sort. Thanks.
Matlab:
>> quad('1./((5.*exp(3.*x))+(2.*exp(-3.*x)))',0,3)
ans =
    0.0594
Matlab:
ans =
    0.0594
If you put braces around an expression, it turns it into a special kind of variable called a cell array. A cell array is not a numerical variable - it's a container for variables. You can't divide a number (1) by a container. See the FAQ to gain a better, more intuitive understanding of what cell arrays are. http://matlab.wikia.com/wiki/FAQ#What_is_a_cell_array.3F
