Decceleration problem with 3 stages of motion
  • Thread starter Thread starter oyster21
    Motion
The discussion focuses on calculating the total distance traveled by a vehicle undergoing three stages of motion: acceleration from rest to 40 m/s, maintaining that speed, and then decelerating to rest. The correct calculations reveal that the distance for the first stage is 100 m, for the second stage is 400 m, and for the third stage, after correcting for deceleration, is approximately 265.3 m. The total distance traveled is thus calculated as 765.3 m. Participants emphasize the importance of using appropriate equations for each stage and understanding the effects of acceleration and deceleration on distance.
oyster21
A vehicle of a mass 1000kg performs 3 stages of motion which are:
1)Accelerates uniformly from rest to a velocity of 40m/s in 5 seconds.
2)Continues at this velocity for 10 seconds
3)decelerates uniformly at a rate of 3m/s[SUP]2[/SUP]
V= U+at > a=(V-U)/t
1):
a=(V-U)/t
a=(40m/s - 0m/s) /5sec = 8m/s2
2):
U-V/t > t= V/a
t= 0m/s - 40m/s / -3m/s2 = 13.3sec
3):
8m/s2 = 8x8= 64m
64m x 10sec = 640m
How do I work out the total distance traveled over the 3 stages with the information if its correct for question 3?
and do I have to take into consideration the mass 1000kg?
You have not quoted the questions posed. I assume the first is to find the acceleration in the first stage and the second to find the time to come to rest in the third stage.
What is the third question? Is it to find the total distance? Average speed?
8m/s2 = 8x8= 64m and 64m x 10sec = 640m make no sense.
3)decelerates uniformly at a rate of 3m/s2
Question:
1) find the acceleration in the1st stage?
2)the time taken to come to rest?
3) the overall distance travelled?I have tried to answer Q3 but only partly as I don’t know how to answer it.
I was thinking I had to to take time it took to accelerate which is 8m/s2 then do I use that and say 8m/s2 = 8x8 = 64m then times that by 10 seconds giving me 640m and then work out the distance it took to comt to rest?
as you can probably tell I need some help with working out the answer so any guidance or input is appreciated.
No, the time it took to accelerate is 5 seconds. Did you mean the time it took to accelerate to 8m/s2?
As I posted, that makes no sense. How can m/s2 become just m? Why are you squaring the acceleration ? What standard SUVAT equation do you think you are applying?
Ok
My answer to the 1st question is the acceleration is 8m/s2
my answer to the 2nd question is time taken to come to rest is 13.3seconds
how would I work out the 3rd question?
also can you tell me if my answers so far are correct?
thank you for your patience though.
Start by explaining the thinking behind the attempt you made:
oyster21 said:
8m/s2 = 8x8= 64m
64m x 10sec = 640m
What standard SUVAT equations do you think you are applying?
u = 0
t = 28.3sec (combined time of all 3 stages)
a = 8
s = ?
S= ut+½at2
= 0 + ½ (8)(28.3)2
= 3,203.56m (total distance travelled)
is this correct?
oyster21 said:
u = 0
a = 8
s = ?
S= ut+½at2
= 0 + ½ (8)(28.3)2
is this correct?
You seem to have calculated the distance it would have covered if it had maintained its original acceleration for the whole 28.3 seconds.
The SUVAT equations assume constant acceleration. You can only apply them over an interval during which the acceleration does not change. There are three intervals in this question with different accelerations, so you cannot apply one equation over more than one of the intervals.
Work out the distance covered in each interval separately.
would i use the same equation to work out each stage seperatley?
i've used the same equations for each stage. ( s=ut+½at2)
1st stage distance = 100m
2nd stage distance= 797.3m
3rd stage distance = 400m
100m+797.3m+400m = 1297.3m
The 100m is right, but the other two are wrong.
Please post your working.
oyster21 said:
u = 0
a = 8
s = ?
S= ut+½at2
Have you been able to understand the question to the point of being confident with your use of that equation?
Again, if you make a graph of velocity versus time, you could easily see the whole process and the details of each of the three stages.
The area between the curve and the time-axis always equals the total distance covered by the vehicle.
Stage 1:
The first term of the equation becomes zero, because the vehicle accelerated from repose.
Stage 2:
The second term of the equation becomes zero, because the vehicle had no acceleration.
Stage 3:
The first term of the equation would be the distance to be covered if sustaining the speed of 40 m/s for the duration time of this stage 3, which must be reduced by subtracting the second term from it, because the vehicle is on negative acceleration down to repose.
This stage is the reverse of stage 1, but with a smaller rate of acceleration (negative in this case).
Stage 1:
Acceleration from rest to 40m/s.
Distance travelled
S=ut+1/2at2
S=0x5+0.5(8)(5)2=100m
Travelled at 40m/s over 10seconds
Distance travelled
S=ut+1/2at2
S=40x10+0.5(0)(10)2=400m
stage 3:
Deceleration from 40/ms at 3m/s2
Distance travelled
S=ut+1/2at2
S=40x13.3+0.5x(3)(13.3)2=797.3
total distance:
100m+400m+797.3m=1297.3m
where am I going wrong?
Stage 1:
Stage 2:
Stage 3:
Is you graph correct as it stayed at 40m/s for 10seconds
oyster21 said:
stage 3:
Distance travelled
S=ut+1/2at2
total distance:
You didn't notice that the vehicle is slowing down during phase 3.
stage 3:
Distance travelled
S=ut+1/2at2
S=40x13.3-0.5x(3)(13.3)2=265.3
is that rite for stage 3?
oyster21 said:
stage 3:
Distance travelled
S=ut+1/2at2
Looks about right. Just under ##14s## at an average speed of ##20m/s##.
so the total distance traveled would be:
100m+400m+265.3m=765.3m
Looks about right.
I get ##766.7m##.
Likes oyster21
Glad to see you have it right now. You confused me in post #11 by switching your answers for stages 2 and 3.
i confused myself.. thanks for your earlier input though. :smile:
Likes Lnewqban
