Decimal points different in these two answers
  • Thread starter Thread starter chriscarson
    Points
The discussion revolves around discrepancies in scientific notation answers for two numerical values, specifically focusing on the placement of decimal points and rounding conventions. The subject area includes scientific notation and significant figures.
  • Participants explore the reasons behind the teacher's use of scientific notation, questioning the rounding of numbers and the implications of using different powers of ten. Some participants suggest that the teacher may have intended to simplify calculations by using a consistent notation.
The discussion is active, with participants offering insights into rounding rules and the significance of expressing numbers in scientific notation. There is an exploration of potential reasons for the teacher's choices, but no consensus has been reached regarding the correctness of the answers or the teacher's intent.
Participants note that the teacher's rounding may not align with standard practices, and there is a suggestion that the use of \(10^6\) could be related to the units of the initial values. The discussion reflects uncertainty about the teacher's rationale and the appropriateness of the answers provided.
chriscarson
Result in decimal point
go back or forward with the point
I have two answers and somehow the answers have the decimal point in different place.
2445859.873 with the answer of 2.44x106
and
254777070.1 with the answer of 254.6x106
why the teacher do that ?
and
Your teacher has not rounded those numbers correctly 😜
we find mistakes in their work so nothing new.
@chriscarson are ##123000##, ##123 \times 10^3## and ##1.23 \times 10^5## all the same number?
and
Were your answers 2445859.873 and 254777070.1?
If the teacher's answers were 2.44x106 and 254.6x106, then I believe that your answers or the teacher's answers might have been slightly off. To three significant digits, 2445859.873 would be 2.45 x 106, and to four significant digits, 254777070.1 would be 254.8 x 106.
As already mentioned, writing both numbers times 106 might have been done for some reason that you didn't mention.
so I would have a good answer with both 254.6x106 and 2.55x108 when I have 254777070.1 on the calculator ?
Assuming you fix the dodgy rounding, then yeah!
No for your first answer. It would be 254.8x106
yeah probably there is something that she prefers x106 that she doesn t said why.
2.55x108 would also be good ?
Yes, depending on how many significant figures are required.
dodgy I guess you mean the mistake
it s not asked , ok so thanks
thanks all...
2445859.873 → 2.44x10⁶ is wrong.
2445859.873 → 2.45x10⁶ is correct if rounding to 3 sig. figs.
254777070.1 → 254.6x10⁶ is wrong
254777070.1 → 254.8x10⁶ is correct if rounding to 4 sig. figs.
(But it is not 'standard form' and it would be more usual to express it as 2.548x10⁸ if 4 sig. are required,)
However there might be a reason for using 10⁶ in both cases. If (for example) your initial values were in units of μs and you wanted the final answers in seconds, it would be helpful to use 10⁶ for both. Then the answers would simply be 2.45s and 254.8s
yes it shows like you are saying , they are both x106, thanks.
