Mentor
- 11,174
- 4,019
lucas_ said:The photons from CMBR are everywhere and can't be shielded
They can be shielded.
Thanks
Bill
lucas_ said:When you see chairs and tables. They are collapsed. Yet when you see atoms and molecules. They are not collapsed. So how do you reconcile the two? Can we say the position eigenstates are collapsed while the Hamiltonians are uncollapsed.. but how could the atoms/molecules in position collapsed eigenvalues still respond to the environmental hamiltonians?
stevendaryl said:Well, according to QM if you yourself are governed by quantum mechanics, then you'll never write "both". Instead, what will happen is:
There is no possibility of your writing the word "both" in the notebook (at least not if we assume that you always write "open" if it's open, and "folded" if it's folded)
- If it is open, afterward the notebook will contain the word "open"
- If it is folded, afterward the notebook will contain the word "folded"
- If it is in a superposition or mixture, afterward the notebook will be in a superposition or mixture of having the word "open" and having the word "folded"
atyy said:How do we know from QM that the notebook being in a superposition of "open" and "folded" is not "both"?
For example, for spins, ##|x\rangle = |u\rangle+|d\rangle##
stevendaryl said:I think it's pretty obvious that the word "both" is not a superposition of the words "open" and "folded". But you could redo the experiment, with the plan of writing "Mixed" instead of "both". If the word "both" is a superposition of "open" and "folded", then the word "Mixed" can't also be the same superposition.
atyy said:So there is a possibility that one would see the superposition if open and folded, and write "both"?
stevendaryl said:I don't think that's a coherent possibility. Imagine the further implications: Suppose I hand the notebook to someone trying to decide what to eat for dinner. They decide:
So "both" being a superposition of "open" and "folded" would imply that Italian food is a superposition of Chinese food and Mexican food. I think that's pretty silly.
- If the notebook says "open", I'll eat Chinese.
- If the notebook says "folded", I'll eat Mexican.
- If the notebook says "both", I'll eat Italian.
You could substitute any consequence you like. "If open, vote for Rand Paul, if folded vote for Hillary Clinton, if both vote for Ted Cruz". That would imply that Ted Cruz is a superposition of Rand Paul and Hillary Clinton.
atyy said:Silly, but impossible?
Also, in the other argument you gave. What if I used for the intermediate state D1 = B1 + B2, and D2 = B1 - B2. Wouldn't I still end up with the same conclusion?
stevendaryl said:This seems ridiculous, arguing over a possibility that is clearly ludicrous. But when it comes to QM, it's really hard to know if ludicrous just means that you're using pre-quantum intuitions that don't apply.
you can read in this paper - https://vcq.quantum.at/fileadmin/Publications/2003-17.pdflucas_ said:The photons from CMBR are everywhere and can't be shielded and said to decohere things to position eigenstates. But how come one can perform double slit experiment or the c60 buckyball... won't the CMBR photons interact with them or are they somehow shielded from this, and how?.
In order to produce interference you make a setup where both [itex]B_1[/itex] and [itex]B_2[/itex] can probabilistically transition to [itex]C_1[/itex] or [itex]C_2[/itex]. And if you can't come up with such a setup it has little to do with decoherence.stevendaryl said:There is another way of explaining the lack of macroscopic superpositions that doesn't involve collapse (though it sort of involves decoherence).
Suppose you set up a system with a single starting state [itex]A[/itex], two possible orthogonal intermediate states [itex]B_1[/itex] and [itex]B_2[/itex] and a final state [itex]C[/itex]. The probability of starting in [itex]A[/itex], passing through either [itex]B_1[/itex] or [itex]B_2[/itex] and winding up in state [itex]C[/itex] is given by:
[itex]P_{AC} = P_{AB_1C} + P_{AB_2C} + 2 Re((\psi_{AB_1C})^* \psi_{AB_2C})[/itex]
where [itex]\psi_{AB_1C}[/itex] is the amplitude for going from [itex]A[/itex] to [itex]C[/itex] via [itex]B_1[/itex]
[itex]\psi_{AB_2C}[/itex] is the amplitude for going from [itex]A[/itex] to [itex]C[/itex] via [itex]B_2[/itex]
[itex]P_{AB_1C}[/itex] is the probability for going from [itex]A[/itex] to [itex]C[/itex] via [itex]B_1[/itex], which is [itex](\psi_{AB_1C})^*\psi_{AB_1C}[/itex]
[itex]P_{AB_2C}[/itex] is the probability for going from [itex]A[/itex] to [itex]C[/itex] via [itex]B_2[/itex], which is [itex](\psi_{AB_2C})^*\psi_{AB_2C}[/itex]
The first two terms in the expression for [itex]P_{AC}[/itex] is what you would expect from classical probability. The term that is essentially quantum-mechanical is the term:
[itex]2 Re((\psi_{AB_1C})^* \psi_{AB_2C})[/itex]
That's the interference term between the two alternatives, [itex]B_1[/itex] and [itex]B_2[/itex]. So observing this term is a kind of evidence of there being an intermediate state that is a superposition (as opposed to a mixture, which is the only kind of alternative possible in classical probability).
So here, to me, is the simplest way to understand the implications of decoherence, and the reason why we never see the effects of macroscopic superpositions: If [itex]B_1[/itex] and [itex]B_2[/itex] are macroscopically distinguishable (say, a dead cat and a live cat), then for any final state [itex]C[/itex] one or the other of the transition amplitudes will be negligible:
[itex]\psi_{AB_1C} \approx 0[/itex] or [itex]\psi_{AB_2C} \approx 0[/itex]
If the intermediate states are macroscopically distinguishable, then there will be some evidence in the final state, [itex]C[/itex] of which alternative was chosen. Only one alternative will be compatible with final state [itex]C[/itex] (that is, have a non-negligible amplitude for ending up in that state).
zonde said:In order to produce interference you make a setup where both [itex]B_1[/itex] and [itex]B_2[/itex] can probabilistically transition to [itex]C_1[/itex] or [itex]C_2[/itex]. And if you can't come up with such a setup it has little to do with decoherence.
For example, consider two cases:
1. Two beams are heading in different direction. One of them goes out to nowhere. You place in it's path a mirror and make it interfere with the other beam. Only it does not produce interference. We say that two beams are not coherent.
2. Two beams are heading in different direction. One of them goes out to nowhere. We don't have a handy mirror (say they are not invented yet) to place in the path of the beam. So there is no way we can produce interference. We won't call it decoherence, right?
stevendaryl said:No, as I said, interference is observable when you have two possible alternative intermediate states that both lead to the same final state. For example, in a two-slit experiment, the particle can either go through one slit or the other, but the final state is that the particle reaches a single spot on the screen.
There is always constructive interference outcome and destructive interference outcome. Give an example where it is not so if you do not agree.stevendaryl said:No, as I said, interference is observable when you have two possible alternative intermediate states that both lead to the same final state. For example, in a two-slit experiment, the particle can either go through one slit or the other, but the final state is that the particle reaches a single spot on the screen.
Right.stevendaryl said:[edit]I'm not claiming that lack of interference implies decoherence, I'm claiming that decoherence implies lack of interference.
No, I don't agree. Decoherence makes probabilities of outcomes add up classically.stevendaryl said:So decoherence is what makes it impossible to find a common final state that is reachable from both intermediate states.
zonde said:No, I don't agree. Decoherence makes probabilities of outcomes add up classically.
Take an example where you can observe interference. Take away coherence. You can still reach final states but probabilities add up classically.
zonde said:There is always constructive interference outcome and destructive interference outcome. Give an example where it is not so if you do not agree.
I don't see that we are talking about different things.stevendaryl said:I think you might be mixing up two different things. When I say "decoherence", I'm talking about the process whereby superpositions evolve into what is, for all practical purposes, mixtures. So it's the process by which alternatives become decoherent. From Wikipedia.
It seems to me that you are talking about a case where things start out decoherent.
Quantum decoherence gives the appearance of wave function collapse, which is the reduction of the physical possibilities into a single possibility as seen by an observer.
By my comment I wanted to say that you can't meaningfully speak about single outcome when you speak about interference.stevendaryl said:There is no interference between classically distinguishable alternatives.zonde said:There is always constructive interference outcome and destructive interference outcome. Give an example where it is not so if you do not agree.
zonde said:By my comment I wanted to say that you can't meaningfully speak about single outcome when you speak about interference.
zonde said:I don't see that we are talking about different things.
Look, if you have two ensembles of particles where one ensemble is represented by superposition of coherent states and the other one is represented by mixture. How you can tell apart two ensembles by observation? In first case you have interference and in second you don't.
No, it's not about repeating experiment. Look, Mach–Zehnder interferometer has two outputs and you can't make anything like Mach–Zehnder interferometer with single output.stevendaryl said:Right. My point was that [itex]P_{AC} = P_{AB_1C}P_{AB_2C} + 2 Re(\psi^*_{AB_1C} \psi_{AB_2C}[/itex], where [itex]B_1[/itex] and [itex]B_2[/itex] are alternative intermediate states. If you repeat the experiment many many times of starting in state A and checking if the final state is C, then you will be able to observe the second interference term. No single experiment can show it, of course (well, unless it makes [itex]P_{AC}[/itex] zero, which sometimes happens).
zonde said:No, it's not about repeating experiment.
zonde said:No, it's not about repeating experiment. Look, Mach–Zehnder interferometer has two outputs and you can't make anything like Mach–Zehnder interferometer with single output.
This is not the issue of decoherence. For decoherence, a pure state remains a pure state. The mixed state appears if one ignores the environment, and considers the effective state of the subsystem. Purely pragmatical, the question considered by decoherence is, given the system, and the environment (their subdivision defined by some actual situation) how long it takes until the interaction of the subsystem with the environment was strong enough to lead to a mixed states if one considers the projection of the whole system to the subsystem.stevendaryl said:That's true. But the evolution operator evolves pure states into pure states. So the issue for decoherence is: why in some circumstances does a pure state seem to become a mixed state?
Ilja said:This is not the issue of decoherence. For decoherence, a pure state remains a pure state.
I tried to make a point that in order to observe interference we would have to subject two alternative states to a setup similar to Mach–Zehnder interferometer where there are at least two outputs and both states can appear on either output. Say a dead cat and living cat is subjected to the some procedure that can kill/resurrect or leave intact either cat.stevendaryl said:Okay, I refreshed my memory about what that device does (by looking it up in Wikipedia). But I don't understand what point you are making about it.
Ilja said:This is not the issue of decoherence. For decoherence, a pure state remains a pure state. The mixed state appears if one ignores the environment, and considers the effective state of the subsystem. Purely pragmatical, the question considered by decoherence is, given the system, and the environment (their subdivision defined by some actual situation) how long it takes until the interaction of the subsystem with the environment was strong enough to lead to a mixed states if one considers the projection of the whole system to the subsystem.
zonde said:If two intermediate alternative states are made/become distinguishable then they do not produce interference and we say that they are no longer coherent.
This process is called decoherence. And two states become distinguishable when they are undergoing interactions asymmetrically, right?
