Definition of a circle in point set topology.
The discussion revolves around the definition of a circle in point set topology, exploring various approaches and interpretations. Participants examine the implications of defining a circle using different mathematical constructs, such as homeomorphisms and quotient spaces, and consider the relationship between geometric and topological definitions.
  • Some participants propose defining a circle as any set homeomorphic to the set of points in the plane satisfying the equation \(x^2 + y^2 = 1\).
  • Others argue that using a 2D subset with an induced topology is overly complex for defining a 1D space like a circle.
  • One suggestion is to define a circle as the unit interval \([0,1]\) with endpoints identified, while another mentions \(\mathbb{R}/\mathbb{N}\) as a potential definition.
  • A participant questions whether \(\mathbb{R}/\mathbb{N}\) is homeomorphic to \([0,1]\), expressing skepticism about the mapping.
  • Another participant clarifies that \(\mathbb{R}/\mathbb{Z}\) is the correct notation, explaining how the group \(\mathbb{Z}\) acts on \(\mathbb{R}\) through translations, leading to a circle when points differing by integers are identified.
  • There is a discussion about the distinction between topological and smooth atlases, with some participants suggesting that using the unit interval with identification could suffice for defining a differential structure.
  • One participant emphasizes that the definition of a circle as the set of points at a unit distance from an origin in \(\mathbb{R}^2\) is natural and maintains that the topological structure remains unchanged when using the identified interval.
  • Another participant notes that in topology, spaces are often considered in terms of their homeomorphic properties rather than specific representations, which leads to broader definitions of what constitutes a circle.
Participants express differing views on the most appropriate definition of a circle in topology, with no consensus reached on whether certain definitions are overly complex or sufficient. The discussion includes multiple competing perspectives on the relationship between geometric and topological definitions.
Some definitions and interpretations rely on specific mathematical structures and assumptions that may not be universally accepted. The discussion also touches on the ambiguity of notation and the implications of different mathematical frameworks.
  • #31
center o bass said:
There is no grief
Then why start a thread about avoiding metric structures on the sphere?!
and yes, in principle that is possible, by specifying the set's of it's topology.
Now you have my interest. Would you mind specifying these sets without referencing a metric on Rn or the ordering on R?
  • #32
I did not! If you had looked back, which I asked you to earlier, you would see that the thread was started with a question on how one might define a circle in topology. TinyTim answered in terms which did not involve the unit circle in R^2 and I felt it a natural progression to ask how one could do the same for a circle as a manifold. This was the point. You came in by arresting me on a terminological error.
Yes here is the pair ##(\mathbb{R}^n, \mathcal{T})##. There is often a difference between principle and practice.
  • #33
I still contend that defining S1 = R/Z or S1 = I/∂I suffers from the same defects as the unit circle definition. But at this point in time I am more interested in your later claim...
But what are the sets in T? You claimed you could tell me what sets belong in T without reference to a metric on Rn or the ordering on R. I am still waiting for this.
  • #34
I'm not, because that was not the point of the thread.
No. I claim that in principle we can topologize any space ##X## by providing a pair ##(X, \mathcal{T})##. How one might construct ##\mathcal{T}## in practice is another question.
  • #35
With this in mind hopefully you can understand why I contend that virtually any definition of S1 is going to require some additional structure in its definition. You can hide or obscure that structure a small amount but it is still there. In any case, just a friendly FYI if you want a definition of S1 with a minimal amount of structure, then the R/Z definition you have been championing is not the best example. That definition induces a group structure on the circle which is something not all manifolds have.
Edit: Basically I am saying that any definition of S1 you choose is just as good as another from a point-set topological standpoint. They all have their uses in point-set topology for different problems. To single one definition out as problematic because it contains extra structure is silly because virtually any way of topologizing the circle gives you a bit more information than its topology alone.
  • #36
I guess I could rephrase my question as: Can one define the circle, as a manifold, as the unit interval with points identified? In that case what charts should one use to specify it's differential structure?
No. The unit interval with its points identified does not define a manifold because it does not provide coordinate charts. You need to show that it can be given the structure of a manifold
  • #37
BTW: The unit interval with end points identified is an example of a structure called a CW complex. A homeomorphism from this space to a circle shows that a circle is a CW complex.
  • #38
Alright. But you can provide charts for it, can't you? I.e. one can give it a differential structure. How would that be done?
  • #39
Let U1 = (0,1) and U2 = [0,1/2)∪(1/2,1]. Let φ1 = id and φ2|[0,1/2) = id and φ2|(1/2,1] = 1-id. Under the 0~1 identification these descend to a pair of charts on the circle.
9K
  • · Replies 61 ·
  • · Replies 20 ·
  • · Replies 39 ·
