Demography of Houses: US Slab-on-Grade Lifespan
  • Thread starter Thread starter Stephen Tashi
The discussion centers on the lifespan of slab-on-grade houses in the USA, particularly focusing on the challenges posed by buried plumbing systems. Participants highlight the need for statistical data on the age distribution of homes and suggest that property tax records could serve as a valuable resource for this research. Innovative plumbing repair techniques, such as resin-impregnated sock lining for sewer pipes, are discussed as cost-effective alternatives to traditional methods. Additionally, the decline of older suburban infrastructures, exemplified by Levitt towns, is noted as a significant concern for homeowners and realtors alike.
  • Understanding of slab-on-grade construction techniques
  • Familiarity with plumbing repair methods, including resin lining
  • Knowledge of property tax records and their implications for housing demographics
  • Awareness of suburban infrastructure challenges, particularly in post-WW2 developments
  • Research the lifespan and maintenance challenges of slab-on-grade houses
  • Investigate advanced plumbing repair techniques, specifically resin-impregnated lining
  • Explore property tax data analysis for demographic studies in housing
  • Examine case studies on the decline of infrastructure in Levitt towns and similar developments
Homeowners, real estate professionals, urban planners, and researchers interested in housing demographics and infrastructure sustainability will benefit from this discussion.
Stephen Tashi
Education Advisor
Are there any online statistics about the demography of houses? - e.g. how many existing homes are 45 years old, how many are 46 years old etc. ?
Property tax information includes the date of construction, so I'd think that the demography of houses would be a fertile field for academic research.
I'm (idley) curious about statistics concerning the lifespan of "slab on grade" houses in the USA. In that style of construction, all the plumbing is buried under concrete. I wonder how long it usually lasts before the economical solution is to tear the house down and start over.
There are other approaches to fixing plumbing.
I was working in an older campus building with pipes that were old and developing a lot of pinholes leaks (through corrosion, galvinized pipes I believe (and on a committee reviewing ways to fix it)).
One approach was to:
1) drain the water
2) blast off the corroded innerds with little beads
3) the blow in a resin to polymerized on the inside
Another approach was used on the old sewer line for our road. It was leaking in sediment whih the water company did not want to process and have clogging up their pipes. Rather than digging out the sewer line for the whole block, they did the following:
1) They ran a line through the sewer line from one end of the road to the other,
2) then pulled through a resin impregnated sock from one end to another
3) then they inflated the sock with pressure from one end and then blew steam through. The heat caused the resin to polymerize.
4) this made a sealed tube in the sewer (no one could use it for about a day)
5) they then went down the road with a hole saw cutting holes into the main pipe and glued in new connections for each house. The old connections were dug up the previous day or two.
This was a much cheaper, quicker, and less disruptive approach to fixing the sewer pipe than the old fashioned way.
There was a documentary a while back about the houses made after WW2 (Levitt towns ??) and how their suburban infrastructure is falling apart. I remember the announcer saying that newer subdivisions thrive over the older ones and malls move to where the people are so the older communities lose businesses and money to repair the infrastructure.
Here's a BBC take on Levitt town:
http://www.bbc.com/news/magazine-15598511
I think its this documentary but I'm not sure:
15K
10K
  • · Replies 19 ·
