Derivative of h(t) = sin(arccos(t))
22 replies · 9K views
BuBbLeS01
find the derivative of the function:
h(t) = sin (arccos t)
2. The attempt at a solution
derivative of sin = cos
derivative of arccos t:
(-1/sqrt 1-t^2) * 1
my book has a complete different answer so I need some help please.
(-1/sqrt 1-t^2) * 1
did u try chain rule?
Yes I got...
-1 * (1-t^2)^-1/2 + (2t)
(cos) * 1/2 * (1-t^2)^-3/2 + (2t)
BuBbLeS01 said:
Yes I got...
no that is incorrect... chain rule will be cos u *du where u in this case arcos(t)..
try again...
real10 said:
no that is incorrect... chain rule will be sin u *du where u in this case arcos(t)..
try again...
No, it won't. BuBbLeS01's first solution was much closer. Derivative of sin(f(t)) is cos(f(t))*f'(t). Let f be arccos.
hmm I am getting [tex]\frac{-x}{(1-x^2)^(1/2)}[/tex] which I believe is right unless i read the question incorrectly!..
aaah a typo I have corrected the typo should be cos.thanks for pointing that out!
Yes that's right...where did cos go?
Is this right?
cos (arccos t) * cos(-1/sqrt 1-t^2) * (2t)
My teacher does not want our answers simplified at all.
You are mixing up arccos and it's derivative. cos(arccos(t))=t. cos and arccos are inverse functions, right? The derivative of sin(f(t))=cos(f(t))*f'(t). That's the chain rule. Now carefully put f=arccos.
Okay, we have:
1. [tex]h(t)=\sin(arccos(t))[/tex]
2. [tex]\frac{d}{dx}\sin(x)=\cos(x)[/tex]
3. [tex]\frac{d}{dt}arccos(t)=\frac{-1}{\sqrt{1-t^{2}}}[/tex]
4. [tex]\cos(arccos(t))=t[/tex]
Agreed?
Thus, by the chainrule, setting [itex]x(t)=arccos(t)[/itex], we have:
[tex]\frac{dh}{dt}=\cos(x(t))\frac{dx}{dt}=-\cos(arccos(t))\frac{1}{\sqrt{1-t^{2}}}=-\frac{t}{\sqrt{1-t^{2}}}[/tex]
BuBbLeS01 said:
cos (arccos t) * (-1/sqrt 1-t^2)
Correct!
Now, what does cos(arcos(t)) simplify to?
Ok so cos(arccos(t)) simplifies to 1 because they are inverses of each other. I am sorry it has been a while since I have had precalc so I rusty
No, it simplifies to..t, not 1!
They are functional inverses, not multiplicative inverses.
ok so anytime I have like sin(arcsin(t)) it just cancels to t?
Okay I have another similar problem...
Find the derivative of...
tan(arcsint)
can I use the product rule?
It's not a product. Use the chain rule.
That's correct. If your teacher doesn't want you to simplify, I guess you can stop there.
Oh yay! thanks...lol
Okay I got another one :)...I am getting a different answer then calcchat because I did it differently...
Find the derivative...
y = xarcsinx + sqrt 1-x^2
y = xarcsinx + (1-x^2)^1/2
y' = x(1/sqrt1-x^2) + 1/2(1-x^2)^-1/2 * (2x)
