Derivative of Log Function: Is My Solution Correct?
3 replies · 1K views · last reply
tbarnet7
y=ln (-2+√x)/(x^4)
Hi there. Just need some reassurance that I found the derivative of this equation correctly.
Also, if you can give me feedback on typing my equations that would also be wonderful. (Whether or not there are easier/better ways of typing the equations.)
g(x)f'(x)-f(x)g'(x)/g(x)^2
This is my final answer.
= x^(7/2) + 8x^3 +4x^3√x / 2x^8
tbarnet7 said:
y=ln (-2+√x)/(x^4)
I don't get this.
To make you work easier, rewrite the function like this:
[tex]y = \ln{\frac{-2 + x^{1/2}}{x^4}} = \ln(-2x^{-4} + x^{-7/2})[/tex]
[tex]\frac{dy}{dx}= \frac{1}{-2x^{-4} + x^{-7/2}} \cdot \frac{d}{dx}(-2x^{-4} + x^{-7/2})[/tex]
Can you continue from there?
I used LaTeX to format this stuff. To see what I did click either equation and a window will open with the LaTeX code.
Thanks Mark. I checked out LaTeX and found it to be a bit further over my head at first glance so I will look into it deeper.
So; you multiplied the top by the recipricole of the bottom to get ln (-2x^-4 + x^ (7/2)) correct?
However; I am not sure how you got from their to the equation below. I am supposed to be applying the quotient rule. So maybe in answering your question; I don't know how to continue from there.
Hold on a second - I might have misinterpreted what you wrote.
Is this your function?
[tex]\frac{\ln(-2 + \sqrt{x})}{x^4}[/tex]
If so, my work doesn't reflect this.
Or is it this?
[tex]y = \ln{\frac{-2 + x^{1/2}}{x^4}}[/tex]
