Deriving mgh from gravitational potential energy using binomial expansion
12 replies · 6K views · last reply
Faiq
Derive E=mgh from Newton's law of Gravitation where h is very small. (Use binomial expansion)
2. The attempt at a solution
[tex]E = \frac{GMm}{(r+h)^2}-\frac{GMm}{r^2}[/tex]
[tex]E = \frac{GMm}{r^2}(\frac{1}{(1+\frac{h}{r})^2}-1)[/tex]
[tex]E = \frac{GMm}{r^2}((1+\frac{h}{r})^{-2}-1)[/tex]
[tex]E = \frac{GMm}{r^2}(1+\frac{-2h}{r}-1)[/tex] Other powers of h/r becomes negligible for h<<r
[tex]E = \frac{GMm}{r^2}(\frac{-2h}{r})[/tex]
Not sure where I went wrong or what to do next
Note:- I know this can be solved in a million other methods but I want the answer specifically from this method. I had a book which used this method and I can't remember how this method works out.
The potential in Newtonian gravity is negative. You are taking potential(reference level) - potential(height h) instead of the other way around.
Okay so I will have 2h/r instead of -2h/r. Doesn't solve the problem though
Instead of "2h/r", I should get "h" so I can rewrite the answer as mgh
Start with gravitational PE, not force. (What you are calling "E" is force not energy.)
True that. The same basic principle applies though. The entire point is expressing g in terms of G, M and r.
Yep.
