Design a capacitor given power, time, voltage, and material properties
22 replies · 4K views
GreenPrint
Given the power that is needed to be output by the capacitor - P
the length of time that the capictor must give off that power - t
the maximum operation voltage that the capacitor can operate at- V
the dialectric constant of several materials - ε
the breakdown field of those several materials - [itex]U_{d}[/itex]
and the mass density of those several materials - ρ
Design the capacitor that meets these requirements
Dialectic Material 1
ε= [itex]4ε_{0}[/itex]
[itex]U_{d} = 1 \frac{V}{nm}[/itex]
[itex]ρ = 2.5 \frac{g}{cm^{3}}[/itex]
Dialectic Material 2
ε= [itex]80ε_{0}[/itex]
[itex]U_{d} = .03 \frac{V}{nm}[/itex]
[itex]ρ = 1 \frac{g}{cm^{3}}[/itex]
Dialectic Material 3
ε= [itex]200ε_{0}[/itex]
[itex]U_{d} = .1 \frac{V}{nm}[/itex]
Metal 1
[itex]ρ=2.7 \frac{g}{cm^{3}}[/itex]
Metal 2
[itex]ρ=2.1 \frac{g}{cm^{3}}[/itex]
The machine which can make the capacitor has the following thickness restrictions
[itex]10 nm < t_{dialectic}< 10 μm[/itex]
[itex]10 μm < t_{dialectic}< 10 cm[/itex]
Equations
[itex]C = \frac{εA}{d}[/itex]
[itex]C = \frac{dQ}{dV}[/itex]
[itex]U = \frac{dW}{dt}[/itex]
the maximum energy stored in a capacitor is below
[itex]w = \frac{1}{2}εCd^{2}U_{d}^{2}[/itex]
[itex]V = U_{d}d[/itex]
[itex]U=CV(t)\frac{dV}{dt}[/itex]
[itex]U=\frac{1}{2}CV^{2}[/itex]
[itex]I=\frac{dQ}{dt}[/itex]
[itex]hp ≈ 746 W[/itex]
[itex]ε_{0} ≈ 8.85*10^{-12} \frac{F}{m}[/itex]
[itex]m = 10^{9} nm[/itex]
[itex]m = 10^{6} μm[/itex]
[itex]m = 10^{3} cm[/itex]
[itex]kg = 1000 g[/itex]
Attempt at a solution
I have no idea how to do this at all or where to begin. I just randomly chose material 3 for the dielectric material and started solving and go the following relations.
C = 3.082644628 F
Q = 678.1818182 C
[itex]w = 10 ε_{0}Cd^{2}[/itex]
I don't know where to go from here or if I'm even on the right track at all. Thanks for any help that anyone can provide. It would be greatly appreciated.
Can you relate electrical properties to material properties?
Do you know the equations for the discharge of a capacitor?
I don't know either of these equations. I could come up with the voltage as a function of time in the capacitor but because I don't know what else the capacitor is connected to I'm not sure how to go about this.
Thanks for your help.
Fwiw, a dialectic is a rational dialogue as a means for resolving disagreements (as made famous by Plato). The word you are looking for is dielectric.
Well, to get started you need to go through your notes and find the bits that relate things like the area of the plates and the distance between them and the amount of dielectric and so on to the capacitance.
Since the rate of discharge of an ideal capacitor depends also on the resistance connected to it so you'll have to use the information provided to work that out as well as what sort of supply voltage is intended. It's not just about equations: you need to draw diagrams too.
I got all those relations in post 1. I still don't see how it's solvable because you don't know the impedance of the rest of the circuit.
The max power a capacitor is able to supply does not depend on the load.
But you don't know the charge though right?
P = (1/2)QV
P = (1/2)QV
That formula gives energy (Joules), not power (Joules/sec).
If the capacitor is expected to be able to provided a certain power for a certain period of time, then there must be some fancy load that makes the energy draw constant despite changes in capacitor charge (thus potential difference). That means Ic*Vc = constant. More importantly, it also tells you total energy that you need to store, E = P*t, which is where capacitor energy equations come in.
There's another version of the capacitor energy equation which involves the capacitance value: E = (1/2)CV2. For the given E = P*t you can draw a C versus V curve, where V would then represent the maximum required working voltage of the device of capacitance C for this application. The max voltage tells you the minimum thickness of the given dielectric, too.
So, it's beginning to look like an exercise in linear programming. It's not clear to me from the problem statement whether this is an optimization problem, and if so, what the cost function would be. Does cost of materials, weight, or overall size matter?
So I think I'm beginning to understand how to solve this problem. I just don't see how does the thickness of the metal have an impact on the capacitor since capacitance has to do with surface area and doesn't' involve the thickness of the metal?
Actually this doesn't make since. I'm getting that the smallest distance possible is 220 m between the plates
using V = [itex]U_{d}d[/itex]
GreenPrint said:
So I can then use this formula
[itex]\frac{Q}{U_{d}} = εA[/itex]
[itex]A = \frac{Q}{U_{d}ε}[/itex]
to solve for the surface area of the capacitor and picking a material?
Seems to me you can build a range of solutions given any choice of dielectric. So how do you go about "picking a material"? You can always increase the capacitance by making the area larger and decreasing the required voltage. The available thickness range of the dielectric may offer a way to select the range of solutions for each material, but without other constraining factors there isn't a way to pick a particular solution, or choose between materials.
I don't think it really matters. The assignment doesn't make it clear either but says that I should just compare different combinations so I think I'm supposed to take weight into consideration. It says nothing about size or cost.
So if I plot
C = [itex]\frac{2Pt}{V}[/itex]. Am I just supposed to pick a point. I mean I would imagine the smallest capacitor is best so I should pick a voltage close that would minimize this value? Since the max voltage is 200, how does this help determine the minimum thickness of the capacitor?
[itex]\frac{εA}{d} = \frac{2Pt}{V}[/itex]
I don't know the surface area or the distance between the capacitors. Thanks for all your help!
Those are things you have to determine.
Ok well
[itex]E = Pt[/itex]
E is energy in joules
P is power in watts
t is time in seconds
[itex]E = \frac{1}{2}CV[/itex]
C is capacitance in farads
V is voltage in volts
[itex]Pt = \frac{1}{2}CV[/itex]
Solving for capacitance
[itex]C = \frac{2Pt}{V}[/itex]
I don't know what values to pick for voltage and capacitance and am guessing that this is what I'm supposed to figure out. Just thinking about this. The smallest the capacitance then the smaller the capacitor. So I'm assuming that I want the voltage to be as large as possible. So I'm going to choose the highest operating voltage of 220 V
[itex]C = \frac{2(100 hp)(10 hr)(745.699822 W)(60 min)(60 s)}{(hp)(hr)(min)(220 V)} ≈ 2.440*10^{7} F[/itex]
So this is a rather large capacitor but is the smallest I can get I suppose.
So I know that
C is the capacitance
ε is the dialectic constant of the dialectic
A is the area of the plates of the parallel capacitor
d is the distance between the plates of the capacitor
If I were to choose a certain material I would still have two unknowns so I'm going to utilize this equation
[itex]V = V_{d}d[/itex]
V is the voltage
[itex]V_{d}[/itex] is the break down field
Solving this equation for d I get
[itex]d = \frac{V}{V_{d}}[/itex]
Plugging this into
I get
[itex]C = \frac{εAV_{d}}{V}[/itex]
Going back to this equation
I get
[itex]\frac{εAV_{d}}{V} = \frac{2Pt}{V}[/itex]
which simplifies to
[itex]εAV_{d} = 2Pt[/itex]
Assuming I just choose a material I'll have one unknown, the area of the metal plates. So I'll rearrange this equation for the area of the parallel plate capacitor and get the following equation
[itex]A = \frac{2Pt}{V_{d}ε}[/itex]
I want the surface area to be as large as small as possible to make the capacitor weight less so I want the quantity [itex]V_{d}ε[/itex] to be as large as possible. Looking at the particular materials this quantity will be as large as possible for the polymer A. After making this decision I am able to solve for the surface area of the parallel plate capacitors.
[itex]A = \frac{2(100 hp)(10 hr)(m)(nm)(60 min)(60 s)(m)(745.699822 W)}{200(8.85*10^{-12} F)(.1 V)(hr)(min)(m)(hp)10^{9} nm} ≈ 3.033*10^{10} m^{2}[/itex]
Am I doing something wrong as this is going to be a huge capacitor?
I'm going to just use square plates. I could use circles or whatever, but no matter the shape it's going to weight the same etc.
[itex]A = l^{2}[/itex]
A is the area
l is the length
Solving for the length I get
[itex]l = \sqrt{A} = \sqrt{3.033*10^{10} m^{2}} ≈ 1.742*10^5 m[/itex]
I can now solve for the distance between the capacitors
[itex]d = \frac{V}{V_{d}} = \frac{(220 V)(nm)m}{(.1 V)10^{9}nm} = 2.2*10^{-6} m[/itex]
Going back to the restrictions on the machine the dialectic must be between 10 nm and 10 μm. Checking that these conditions are met I convert these values to meters
[itex]\frac{10 (nm)m}{10^{9} nm} = 1*10^{-8} m[/itex]
[itex]\frac{10 (μm)m}{10^{6} μm} = 1*10^{-5} m[/itex]
So it looks like I meet these restrictions or am I doing something wrong as this is a huge capacitor.
Also what does the thickness of the metal plates have to do with anything? Why does the assignment mention that it has a restriction on it's thickness. My guess is it just make it as small as possible and to use the metal which weighs the least. I'm kind of confused.
... see post #4.
What electrical property of a metal depends on it's thickness?
Do you have an equation that relates some electrical property to a thickness or a length?
You are now on the right track -
You have been provided with a great deal of information to digest all at once ... just take it one step at a time.
Oh lol I always spell that wrong.
I honestly don't know if I know the answer to this question. My first thought was charge. However all the charge accumulates on the faces of the plates so it has nothing to do with this. I thought perhaps the electric field, but that's only inside the dielectric =). It's been a semester since I have taken electromagnetism. I'm not sure what property you are refereeing to.
Oh the resistance of the plates? This is dependent on the thickness of the metal, but what does this resistance matter? Hm. I'm not really sure about this. I just assumed the plates have zero resistance.
Other than this property I don't think I'm aware of any others.
Oh the resistance of the plates ... s is dependent on the thickness of the metal, but what does this resistance matter? Hm. I'm not really sure about this. I just assumed the plates have zero resistance.
Is that a good assumption considering that you have been supplied with the resistivities of different metals?
OR are you expecting to use those in a different context?
The DC resistance of the capacitor will affect it's performance. i.e. the maximum current flows when you short-circuit the capacitor (after charging it to it's maximum rated voltage).
Any real capacitor is modeled by an ideal capacitance in series with a small resistance.
Hm very interesting. Let's see here.
[itex]P = \frac{V^{2}}{R}[/itex]
P is the power - this is given in the problem to be 100 hp
V is the voltage - I choose 220 V
R is the resistance
Solving for resistance
[itex]R = \frac{V^{2}}{P} = \frac{(220 V)^{2}(hp)}{(110 hp)(745.699822 W)} ≈ .649 Ω[/itex]
[itex]R = \frac{ρl}{A}[/itex]
R is the resistance
ρ is the resistivity of the metal
A is the area - this was already calculated to be [itex]3.033*10^{10} m[/itex]
l is the length (in this case the thickness)
So solving for thickness I got
[itex]l = \frac{AR}{ρ}[/itex]
Now I only have two metals which are the aluminum and graphite, I also got to take into consideration their weight densities when choosing a metal. I can't just pick a metal because I would have to calculate the weight after first calculating the thickness.
[itex]ρ_{R, aluminum} = 2.82*10^{-8} Ωm, ρ_{aluminum} = 2.7 \frac{g}{cm^{3}}[/itex]
[itex]ρ_{R, graphite} = 1*10^{-5} Ωm, ρ_{graphite} = 2.1 \frac{g}{cm^{3}}[/itex]
I'm going to convert the restrictions on the metal now
[itex]10 μm = 1*10^{-5} m[/itex]
[itex]\frac{(10 cm)m}{100 cm} = .1 m[/itex]
I also be using the following formula to calculate mass
m = Vρ
m is the mass
V is the volume
ρ is the mass density
or in the case of a rectangular 3d shape
m = Alρ
A is the face area
l is the thickness
I will then use the following formula to calculate the weight
[itex]F_{g} = mg[/itex]
[itex]F_{g}[/itex] is the force of gravity on the object
m is the mass of the object
g is gravity (I will use 9.81 [itex]\frac{m}{s^{2}}[/itex])
Combing these equations I get
[itex]F_{g} = Alρg[/itex]
For aluminum
[itex]l = \frac{AR}{ρ} = \frac{(3.033*10^{10} m^{2})(.649 Ω)}{(2.82*10^{-8} Ωm)} ≈ 6.980*10^{17} m[/itex]
Hm doesn't seem like aluminum will work on this one...
For graphite
[itex]l = \frac{AR}{ρ} = \frac{(3.033*10^{10} m^{2})(.649 Ω)}{(1*10^{-5} Ωm)} ≈ 1.968 m[/itex]
It looks like I'm screwed or did I do something wrong because this doesn't meet the thickness requirements that the machine can make?
So check your figures - you may have to go back and try a different design.
I believe that my figures are correct. I don't see how any other set ups would result in smaller values, just thinking about it logically as I did in my previous posts as which dielectric =) to use and just went from there.
Well I have looked through my figures and it would appear as if perhaps when I calculated the resistance using the power equation I got .649 ohms and this should be the total resistance of both plates? If so than I would have to divide this quantity by two in order to calculate the resistance on just on plate then I'm assuming. So using the particular dialectic I had chosen (polymer A) graphite would have a thickness of .984 m, and aluminum would have a thickness of 3.49*10^17 m. Neither of these values are within the range.
This is concerning to me because the only other design I have available to change is the dielectric. The dielectric has no effect on the resistance of the plates of the capacitor. So the resistance by the power equation is always going to be the same. The only thing I can change is the cross sectional area of the capacitor so perhaps this calculation is incorrect. However going through this calculation, it is clear that is dependent on the surface area of the plates so perhaps I should look into picking a different material.
I don't know if my logic is correct though.
However... looking back onto this calculation the only way in which the dielectric has anything to do with the surface area is
[itex]A \alpha \frac{1}{V_{d}ε}[/itex]
So in order to make the surface area as small as possible I want the quantity [itex]V_{d}ε[/itex] to be as large as possible and this occurs for polymer A. So I do believe that using this logic that my choice in dielectric is the best option.
I guess my question is that since the mas voltage the capacitor can operate at is 220 V then do I have to use 220 V in my calculations?
Hmmm... rereading post #1, it does not look like you have been given resistivities.
How odd.
The thickness restrictions appear to be those of the dielectric.
However, it is unclear why there are two. I suspect a typo and one of those is the thickness restriction on the metal? (I'm thinking, the first one?)
Anyway - choosing the simplest parallel plate cap design, you have a block with cross-sectional area A made like a sandwich. Left to right you have metal,thickness1 - dielectric,thickness2 - metal,thickness3.
You can rewrite the various equations from that structure.
Keep it general - don't put the numbers in yet.
Let the general equations choose the materials and dimensions.
You will have to play around with it - maybe sketch/graph some relations - to get a feel for what's going to be important.
The area divided by the density tells you how the mass varies with thickness.
Bear in mind that you don't have to stick to the simplest design - you can have more than one dielectric between the plates, the plates can be different metals, there can be more than two plates, you can make the capacitor cylindrical, all sorts of options are available.
The problem is about making choices that show your understanding - which is why I cannot help you directly, only point at interesting things.
