Why does a fan cool you in a sealed room if it adds heat?
19 replies · 6K views
sol_2001
Why does a fan cool a person in a sealed room if the fan should also increase the room’s temperature?
I am trying to understand why a fan can make a person feel cooler in a closed or sealed room, even though the fan seems like it should be adding energy to the air and slightly heating the room overall.
My reasoning is that the spinning fan blades do work on the air, so they push the gas molecules around and increase their motion. I would therefore expect the total kinetic energy of the air in the room to increase. I would also expect extra heating from friction and inefficiencies, such as the blades moving through the air, turbulence in the air, and internal losses in the motor and moving parts of the fan.
So my original question is this: if the fan is increasing the energy of the room and the room should be getting slightly warmer overall, why does the person feel cooler instead of warmer?
The main thing I am confused about is the distinction between bulk/organised motion of the air and random microscopic motion of the molecules.
More specifically, I am struggling with these points:
If the fan increases the motion of the air molecules, why does that not automatically mean the temperature increases?
How is air moving together in one direction different from particles moving faster in the thermal sense?
If kinetic energy is being added to the gas, what part of that energy counts as temperature, and what part is just bulk airflow?
If the room as a whole is gaining energy, why does the person still cool down?
I do not know the relevant equations yet. I am mainly trying to understand the concepts first, especially the difference between bulk airflow and random microscopic motion, and how a fan can make a person feel cooler even if it is adding energy to the sealed room overall.
My current understanding is that the fan does not truly “cool the room” in a sealed container. Instead, it probably adds energy to the room overall because the motor does work and there are frictional losses.
What I think might be happening is that the fan first creates bulk airflow, meaning the air moves together in a general direction. But I do not fully understand why that is not immediately the same thing as an increase in temperature.
I have read that temperature is more related to the random microscopic motion of particles rather than the organised motion of the air as a whole. So maybe the fan first increases the organised motion of the air, and only later does that energy get dissipated into random molecular motion and slightly heat the room.
At the same time, the moving air seems to help the person lose heat faster, possibly by carrying away the warm air near the skin and increasing sweat evaporation. That would explain why the person feels cooler even if the room overall is gaining energy.
So I think my confusion is not whether the fan adds energy — I think it does — but rather why added kinetic energy in the air does not immediately just mean a higher temperature, and how that can still result in a person cooling down.
That's essentially correct, it's called wind chill.
Hi @sol_2001. For simplicity just consider cooling by convection.
Suppose the air temperature is 25##^\circ## and your skin’s surface temperature is 30##^\circ##C. You will be cooled by natural convection. But it may not be enough for you.
Heat transfer by convection depends (amongst other things) on the velocity of the air relative to your skin. So a fan helps ( ‘forced convection’).
Of course the air will warm up because of energy from the fan (and from you!). After some time the air temperature might might reach 25.1##^\circ##C. You wouldn’t notice the small reduction in the rate of cooling. This is the typical real-life scenario.
In the unrealistic extreme case –given a high power fan, enough time and a well insulated room – the air temperature would rise indefinitely. It would eventually be higher than your skin temperature and you would be in trouble!
A simple test for this (at least in principle) would be to test how cool the room "feels" subjectively versus its objective temperature as measured by a thermometer.
I think that wind chill is the main cooling mechanism as confirmed by @greypilgrim is the main process here. Water loss through evaporation from the skin is a continuous, natural, and unavoidable process hastened by the fan. An estimated average of one pint of water daily is lost by humans through evaporative cooling.
Very big trouble! The room must also be sealed to avoid the possibility of external, cooler air entering in which case you will most likely suffocate first. Don't try this at home.
sol_2001 said:
Homework Statement: Why does a fan cool a person in a sealed room if the fan should also increase the room’s temperature?
Because the temperature of the skin is greater than the temperature of the air flowing over it.
Note how people living in desert regions insulate themselves from air that is hotter than their skins.
Heat always flow naturally from a hot source to a cold sink.
The rate at which that heat transfer happens can be increased by increasing the velocity of the airstream flowing over the skin.
Another way to increase that rate is by reducing the relative humidity (or water vapor contained in the air), thus increasing the rate at which sweet evaporates from the skin.
As the process of the fan cooling the person progresses, both, the temperature and the relative humidity of the surrounding air will increase.
As discussed above, the air in the closed room will gradually become hotter due to the thermal energy emanating from the work done by the electrical motor on the air, from the high temperature of its frame, and from the person's metabolism (via skin).
Simultaneously, the air in the closed room will gradually become more humid due to the constant sweeting of the person.
In that way, less and less thermal energy produced by the metabolism will accumulate in the body of the person, triggering his/her internal alarms that alert about excessive body temperature situation.
So taking all the messy physiological arguments out of the equation, place a thermocouple in a closed environment, and turn on the fan. What does it then register after (immediately) the fan is turned on? How is the result explained? I think that is what the OP is after.
I don't think so. OP asks about cooling a person, not a thermocouple. :oldsmile:
Perhaps, but helping the OP understand why it doesn't work on a thermocouple is part of helping them understand why it does work on a human.
Here it should be noted, that If they would fully insulate themselves, they would overheat due to the heat they produce themselves. They protect their skin from the sunlight and hot airflow, while allowing for evaporation, which is the only way for the body to cool itself in air hotter than it.
That would be the control or placebo thermocouple. A second thermocouple wrapped in wet toilet paper and placed in front of the fan would clinch the argument.
Relevant Equations: I do not know the relevant equations yet. I am mainly trying to understand the concepts first, especially the difference between bulk airflow and random microscopic motion, and how a fan can make a person feel cooler even if it is adding energy to the sealed room overall.
Evaporation of water will cool things down, and the fan promotes evaporation of perspiration, which cools you down. If you have a system that is isolated (no heat or mass in or out) and it has liquid water and dry air in it, some of the water will evaporate and the temperature will drop. If you put a fan in it, yes, the energy you feed into the fan will tend to warm up the system, but if the humidity is not 100 percent, then there will be evaporation, and the evaporation of any water in the room (e.g. perspiration) will tend to cool the system down. I'm guessing that the fan will win, and the room will warm up, but if the fan is blowing on you and you are perspiring and the humidity is not real high, it will cool you down even though the room warms up a little. If there is no breeze, then the air near your skin will become saturated, and then no more cooling. If the humidity is 100 percent, then there is no cooling even if there is a breeze.
(Hi very new to this and just trying to improve my problem solving through discussion with smart individuals so please be kind...😔)
I'd imagine the force of the wind from a fan is greater than the force that warm air has just sitting in a room, and so the force of the wind being pushed out of a fan moves the warm air away from you making you feel cooler than you were before you turned the fan on.
Possibly due to the kinetic energy of the moving blade there would be an increase of heat energy, but the increase could be so small that the power of the fast movement of wind cooling someone down would outweigh the feeling of the extremely small increase in temperature due to particle movement and collisions.
Perhaps more accurate measurements are needed to determine whether the room is actually cooling down rather than the breeze just making someone feel as though the temperature is dropping significantly throughout the whole space.
If you ever do get values it would be very interesting to try and figure it out mathematically rather than me just making amateur assumptions about the theory of such a scenario,
Nik :)
If the fan is just replacing warm air with different warm air, why would that feel cooler?
V0ttWotts said:
... the wind being pushed out of a fan moves the warm air away from you making you feel cooler than you were before you turned the fan on.
To answer @DaveC426913's (no doubt rhetorical) question in Post #14 and also to address the issue of unicorns...
It is not the removal of warm air per se that makes you feel cooler.
Consider a shorn white unicorn with a skin surface-temperature of, say, 40##^\circ##C. As is well-known, unicorns don't sweat and, being white, radiative heat loss can be neglected.
If 'incident' air of temperature 20##^\circ##C. blows over the unicorn, the unicorn's skin will be cooled and the air leaving the unicorn’s skin will have been warmed.
Note: The above is an oversimplification as there is a thin boundary layer of air local to the surface. The boundary layer mediates heat transfer between the skin and the moving air.
Perhaps check out 'Wet Bulb' vs 'Dry Bulb' temperatures in addition to 'Wind Chill' ?
FWIW, during thankfully rare UK heat-waves that coincided with Saharan dust incursions and dire pollen-count 'Spikes', only desk and wall-hung fans, plus big 'Air Mover' stirring stair-well, kept my wife and I on speaking terms, and the kitchen's eco-fridge/freezer's larder in single figures ºC...
Hey guys the newest and probably on the younger side here so please bare with my mistakes ,:smile:
This question is quite intriguing and i wanted to take a hit in answering it
so what i thing is A resting human naturally emits about 100 Watts of heat. This creates a continuous "thermal plume" where warm air rises off your body, creating a localized, slightly warmer column of air around you so the room is almost never evenly temperatured and so the bulk airflow generated by the fan carries the warmer current of air away from the person and spreads it evenly through the room lowering the general temperature of the room thus the heat from the body is carried outwards to the outer cooler temperature and along with the evaporating effect that the others mentioned . Of course if the room it completely insulated even the general temperature of the room will rise indefinitely and there comforting sensation would cease to effect
Parthib Roy said:
… carries the warmer current of air away from the person and spreads it evenly through the room lowering the general temperature of the room
How does spreading it evenly lower the general temperature. Wouldn’t it raise it?
It is worth going into evaporation in a bit more detail. You mentioned the locally warmer air around the body. In what other way does that air differ from that in the room at large?
Typically, it will be warmer outside than in the room, so heat is flowing in. Spreading the locally warmer air around the room will tend to slow that.
Two questions:
  • Is there a point at which the fan ceases to help the person?
  • Can there be a point at which the person would have been better off if the fan had never been turned on?
yeah i was a little wrong in my statement abt lowering the general temperature ,yes the general temperature would increase but the localized heated air around the persons body would be constantly be replaced with cooler air from other parts of the room.As humans perceive room temperature as rate at which heat is leaving the body, with a fan the bulk airflow continuously replaces that trapped, body-heated air with the "cooler" (relatively speaking) ambient room air. Even if the room air has warmed up to 26°C, it is still cooler than your core body temperature (~37°C) or skin temperature (~33°C).Without a fan the hot, humid air trapped in the "thermal plume" acts like a blanket, slowing down further heat transfer.
Yes ,If left running indefinitely in a perfectly insulated room, the air temperature will eventually rise to match or exceed your skin temperature. Once the room temperature crosses roughly 35°C (95°F), blowing that air over your body will actually transfer heat into you rather than away from you, rendering the fan worse than useless unless you have a way to sweat profusely.
Not necessarily. Can you answer the earlier question I asked?:
You were in the ballpark with this remark
but that's not quite it.
