AndrewUV
- 4
Hey Everyone,
I'm having trouble detecting my drug dissolved in ethanol using UV-Vis spectroscopy. The peak absorbance of the drug is at 240 nm while the peak absorbance of the ethanol seems to be around 190 nm. Are these peaks too close to each other to get an accurate measurement? In the wavelength scan of the drug dissolved in solvent, the graph has a higher peak up to 3 AU for ethanol at 190 nm and a lower peak of 1.5 AU at 240 nm for the drug. The peaks, however, are not separated... from the higher ethanol peak at 190 nm, it drops to only around 1.25 AU at 217 nm before going up to the drug peak of 1.5 AU at 240 nm. I've done a standard and that seems to work out fine. However, when I encapsulate the drug inside polymer and then dissolve that polymer to extract the drug again and detect the amount encapsulated inside, I get a number greater than 100%. So I'm detecting more drug than what I put in... would this have to do with how close the peaks are in absorbance and the ethanol peak possibly contributing to the absorbance? Thanks for your help.
Andrew
Andrew
