Determine the cycle decomposition of the permutations
28 replies · 4K views
mathmari
MHB
Hey! :o
We have the following permutations in $\text{Sym}(14)$ :
- $\pi_1=(1 \ 2\ 4 \ 9)\circ(1 \ 3)\circ (6 \ 8\ 12)$
- $\pi_2=(2 \ 4\ 5 \ 8\ 7)\circ (1 \ 12 \ 6)\circ \ (13 \ 14)$
- $\pi_3=(1 \ 4 \ 5\ 8 \ 11)\circ (2 \ 4\ 6 \ 5 \ 1)$
1. Determine the cycle decomposition of $\pi_1, \pi_2, \pi_3$.
2. Determine $\pi_1^{-1}, \pi_2^{-1}, \pi_3^{-1}$.
3. Determine $\pi_4=\pi_1\circ \pi_2$, $\pi_5=\pi_2\circ\pi_3$, $\pi_6=\pi_2\circ\pi_1$.
4. Determine the signum of $\pi_1, \pi_2, \pi_3, \pi_4, \pi_5, \pi_6$.
1. We consider the composition fromright to left, or not? Thenfrom the last we consider the element $6$ that goes $8$ and since there is no other $8$ previously we have that $6\rightarrow 8$.
Is this the idea to get the cycles?
2. We get the inverse permutation by the cycle decompsition, right?
(Wondering)
Hey mathmari!
Yes, this is the way to decompose the permutation into disjoint cycles. (Nod)
We can choose.
We get the inverse by reversing each cycle in combination with applying the constituent cycles in reverse.
We can do this with the permutation as given, or with the decomposition.
We can for instance already write:
$$\pi_1^{-1}=(12 \ 8\ 6)\circ(3 \ 1)\circ(9 \ 4\ 2 \ 1) $$
It may be intended to do this with the decomposition of $\pi_1$ though. (Thinking)
Aren't the first two permutations already the decomposition into disjoint cycles? (Wondering)
As for $\pi_3$ we have the following:
$1$ goes to $2$
$5$ goes to $1$ and $1$ goes to $4$, so $5$ goes to $4$
$6$ goes to $5$ and $5$ goes to $8$, so $6$ goes to $8$
$4$ goes to $6$
$2$ goes to $4$ and $4$ goes to $5$, so $2$ goes to $5$
$11$ goes to $1$
$8$ goes to $11$
Is this correct? (Wondering)
Yes.
But the third permutation could still conceivably overlap both of them, so that they might not actually end up as disjoint cycles in the decomposition. (Thinking)
$1$ goes to $2$
$4$ goes to $6$
$11$ goes to $1$
$8$ goes to $11$
Is this correct?
Yep.
Can we write it as disjoint cycles? (Wondering)
Yep.
So we get $\pi_3=(1 \ 2 \ 5 \ 4 \ 6 \ 8 \ 11)$, or not? (Wondering)
Yep. (Nod)
Therefore, the cycle decompositions of the permutations are:
- $\pi_1=(1 \ 2\ 4 \ 9) \ (1 \ 3)\ (6 \ 8\ 12)$
- $\pi_2=(2 \ 4\ 5 \ 8\ 7)\ (1 \ 12 \ 6) \ (13 \ 14)$
- $\pi_3=(1 \ 2 \ 5 \ 4 \ 6 \ 8 \ 11)$
Right? (Wondering)
At the first two do we consider the product of the cycles or the composition as we had initially? (Wondering)
Right?
The cycles in $\pi_1$ are not disjoint are they?
Isn't $1$ in multiple cycles? (Worried)
Huh? :confused:
Which 'first two'?
Which question are we talking about?
Oh yes, you are right! (Tmi)
So, the cycle decompositions of the permutations are:
- $\pi_1=(12 \ 6 \ 8)\ (3 \ 2)\ (9 \ 1 \ 2 \ 4)$
Right? (Wondering)
Huh? :confused:
Which 'first two'?
My question is: Is there a difference between $(12 \ 6 \ 8)\ (3 \ 2)$ and $(12 \ 6 \ 8)\circ (3 \ 2)$ ? Is the product and the composition symbol equivalent? (Wondering)
Doesn't $\pi_1$ have two cycles with $2$ in them now? (Worried)
Ah no, there is no difference.
The product of cycles is defined as the composition. They are the same. (Nerd)
Ah yes!
I tried that again and now I get $(12 \ 6 \ 8)\ (3 \ 2 \ 4 \ 9 \ 1)$ but there must be a mistake (but I don't know wheat I have done wrong) because at the initlal permutation $1$ goes to $2$ but not here. (Wondering)
From the initial permutation $\pi_1$ we get:
$12 \rightarrow 6$
$6 -\rightarrow 8$
$8 \rightarrow 12$
$3 \rightarrow 1 \rightarrow 2$
$9 \rightarrow 1$
$1 \rightarrow 2$
$2 \rightarrow 4$
$4 \rightarrow 9$
Or not? (Wondering)
Ahh ok! (Malthe)
mathmari said:
Ah yes!
$12 \rightarrow 6$
$6 -\rightarrow 8$
$8 \rightarrow 12$
$9 \rightarrow 1$
$1 \rightarrow 2$
$2 \rightarrow 4$
$4 \rightarrow 9$
Or not? (Wondering)
Don't we have $1\to 3$? (Worried)
Anyway, here's a slightly different way to find it.
Let's start with $1$.
$1 \to 3$ for $(1\,3\,\ldots)$.
$3\to 1 \to 2$ for $(1\,3\,2\,\ldots)$.
$2\to 4$ for $(1\,3\,2\,4\,\ldots)$.
$4\to 9$ for $(1\,3\,2\,4\,9\,\ldots)$.
$9\to 1$, which completes the cycle $(1\,3\,2\,4\,9)$.
Now we start a new cycle with the first missing number, which is $6$.
$6\to 8$ for $(6\,8\,\ldots)$.
$8\to 12$ for $(6\,8\,12\,\ldots)$.
$12\to 6$, which completes the cycle $(6\,8\,12)$.
So $\pi_1=(1\,3\,2\,4\,9)(6\,8\,12)$. (Nerd)
And yes, that is the same decomposition that you have, although the numbers are in a different order. (Happy)
Ahh that means that my result is also correct, isn't it? (Wondering)
Yep. (Nod)
Ok!
As for the inverse permutations, do we reverse the cycles and also the elements of each cycle? (Wondering)
- $\pi_1=(12 \ 6 \ 8)\ (3 \ 2 \ 4 \ 9 \ 1)$
So do we get the following?
- $\pi_1^{-1}=(1 \ 9 \ 4 \ 2 \ 3) \ (8 \ 6 \ 12)$
- $\pi_2^{-1}=(14 \ 13) \ (6 \ 12 \ 1) \ (7 \ 8 \ 5 \ 4 \ 2)$
- $\pi_3^{-1}= (11 \ 8 \ 6 \ 4 \ 5 \ 2 \ 1)$
(Wondering)
mathmari said:
Ok!
Yep. (Nod)
Btw, since the cycles are disjoint, their order does not matter. (Nerd)
Yep. (Nod)
That means that since these are disjoint it is enough to reverse the elements inside the cycles? (Wondering)
Do we just write each permutation or is it maybe meant to find the cycle decomposition also of these ones? (Wondering)
We have the following:
$\pi_4=\pi_1\circ \pi_2=(12 \ 6 \ 8)\ (3 \ 2 \ 4 \ 9 \ 1)(2 \ 4\ 5 \ 8\ 7)\ (1 \ 12 \ 6) \ (13 \ 14)$
From that we get:
14 -> 13
13-> 14
6 -> 1 -> 3
1 -> 12 -> 6
12 -> 6 -> 8
7 -> 2 -> 4
2 -> 4 -> 9
4 -> 5
5 -> 8 -> 12
8 -> 7
1 -> 3
3 -> 2
2 -> 4
4 -> 9
9 -> 1
8 -> 12
12 -> 6
6 -> 8
Have I done that correctly? Because now for example the element $2$ goes to two different elements. (Wondering)
I suspect that when they write 'determine' that they mean to find a cycle decomposition.
Otherwise the answer would be trivial - that is, we could simply write the given transformations after each other. (Thinking)
From that we get:
14 -> 13
6 -> 8
I didn't check them all, but indeed it can't be right that $2$ is in this list twice, nor that it maps to two different elements. (Worried)
Why is it in the list twice?
We start from the right-most cycle, right? Then we have the element $2$ and see that this goes to $4$ and $4$ goes to $9$, so $2$ goes to $9$.
At the second cycle we have again the element $2$. When we reach this cycle do we check again the element $2$ ? (Wondering)
No. (Shake)
When we consider the image of an element such as $2$, we must evaluate all cycles from right to left. We are not supposed to start in the middle. (Worried)
Ok !
Now I think I got the right results :
$\pi_4=\pi_1\circ\pi_2=(14\ 13) \ (6\ 3\ 2\ 9\ 1)\ (12\ 8\ 7\ 4\ 5)$
$\pi_5=\pi_2\circ\pi_3=(1\ 4) \ (2\ 8\ 11\ 12\ 6\ 7)\ (13\ 14)$
$\pi_6=\pi_2\circ\pi_1=(3 \ 4 \ 9 \ 12\ 1) \ (2\ 5\ 8\ 6\ 7)\ (13 \ 14)$
For the signum we have to write each permutation as a product of cycles of two elements, right? How can we do that? (Wondering)
We can write $(a\,b\,c\,d)$ for instance as either $(a\,d)(a\,c)(a\,b)$ or $(a\,b)(b\,c)(c\,d)$. (Thinking)
Note that more generally a cycle with an even number of elements can be written as an odd number of 2-cycles (signum -1).
And a cycle with an odd number of elements can be written as an even number of 2-cycles (signum +1). (Nerd)
I am looking aagain at the previous question, at the calculation of $\pi_4$. Do we get the same results if we use the initially given $\pi_1$ and $\pi_2$ and the same if we use the cycle decomposition of them? (Wondering)
I get the following from the cycle decomposition:
$\pi_1=(8 \ 6 \ 12)\ (1 \ 9 \ 4 \ 2 \ 3 )$
$\pi_2=(7 \ 8 \ 5 \ 4 \ 2)\ (6 \ 12 \ 1 ) \ (14 \ 13)$
$\pi_4=\pi_1\circ\pi_2=(8 \ 6 \ 12)\ (1 \ 9 \ 4 \ 2 \ 3 ) \ (7 \ 8 \ 5 \ 4 \ 2)\ (6 \ 12 \ 1 ) \ (14 \ 13)$
$14\rightarrow 13$
$13\rightarrow 14$
$6\rightarrow 12\rightarrow 8$
$12\rightarrow 1\rightarrow 9$
$1\rightarrow 6\rightarrow 12$
$7\rightarrow 8\rightarrow 6$
$8\rightarrow 5$
$5\rightarrow 4\rightarrow 2$
$4\rightarrow 2\rightarrow 3$
$2\rightarrow 7$
$9\rightarrow 4$
$3\rightarrow 1$
So $\pi_4=(14 \ 13) \ (6 \ 8 \ 5 \ 2 \ 7) \ (12 \ 9 \ 4 \ 3 \ 1) $.
And from the initially given forms:
$\pi_1=(1 \ 2\ 4 \ 9)\ (1\ 3)\ (6 \ 8 \ 12)$
$\pi_2=(2 \ 4\ 5 \ 8 \ 7)\ ( 1 \ 12 \ 6) \ (13 \ 14)$
$\pi_4=\pi_1\circ\pi_2=(1 \ 2\ 4 \ 9)\ (1\ 3)\ (6 \ 8 \ 12) \ (2 \ 4\ 5 \ 8 \ 7)\ ( 1 \ 12 \ 6) \ (13 \ 14)$
$13 \rightarrow 14$
$14\rightarrow 13$
$1\rightarrow 12 \rightarrow 6$
$12\rightarrow 6\rightarrow 8$
$6\rightarrow 1 \rightarrow 3$
$2\rightarrow 4\rightarrow 9$
$4\rightarrow 5$
$5\rightarrow 8\rightarrow 12$
$8\rightarrow 7$
$7\rightarrow 2\rightarrow 4$
$3\rightarrow 1\rightarrow 2$
$9\rightarrow 1$
So $\pi_4=(13 \ 14) \ (1 \ 6 \ 3 \ 2 \ 9 ) \ (12 \ 8 \ 7 \ 4 \ 5)$. Have I done something wrong or is it correct that we get different results? (Wondering)
The original $\pi_2$ was already disjoint and contained (1 12 6). But it's not like that in both your cases, is it? (Worried)
What do you mean? I got stuck right now. (Wondering)
You wrote (6 12 1) here.
4)$
And you wrote (1 12 6) here.
Shouldn't they be the same? (Wondering)
Did you perhaps accidentally write $\pi_2^{-1}$ instead of the decomposition? (Wondering)
Oh yes, you are right! I used theinverse accidentaly. (Tmi)
So we get the same result using the initial permutation and the cycle decomposition of it.
