Determine the thermal transmittance of the floor
  • Thread starter Thread starter stevenH
    Thermal
To determine the thermal transmittance of a floor in contact with the ground, one must calculate the overall heat transfer coefficient using the dimensions provided (20m by 10m) and the materials involved. The first step involves calculating the thermal transmittance of the floor itself, followed by the transmittance coefficient of the wood block surface, which has a thermal conductivity of 0.14 W/mK. Additionally, incorporating an EPS insulation membrane with a thermal conductivity of 0.035 W/mK will further affect the transmittance coefficient. For assistance, it is recommended to search for "thermal transmittance" online for relevant formulas. Engaging directly with knowledgeable individuals can also provide tailored guidance.
stevenH
Hi I am new here but I am really stuck with this question, I am just looking for any pointers on how to complete this question, thanks in advance for any replys... stevenH
A floor in contact with the ground and having four exposed edges measures 20m by 10m.
i)Determine the thermal transmittance of the floor
ii)If the floor is surfaced with 15mm of wood block having a thermal conductivity of 0.14
W/mK, determine its thermal transmittance coefficient
iii)If the floor has a thermal insulation membrane of EPS having a thermal conductivity of 0.035W/mK in addition to its wood block finish, determine the transmittance coefficient.
i guess your exam is over by now but if you are still "really stuck" on this problem I would suggest Googling "thermal transmittance" and i you'll get some pretty simple formulas to calculate this.
I'm really not trying to be a smart *** here and if you are still stuck PM me and i'll send you a solution;)
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
