Determining if the series converges
  • Thread starter Thread starter jdawg
    Series
7 replies · 1K views · last reply
jdawg
n=1∞∑[itex]\sqrt[n]{3}[/itex]*[itex]\sqrt[n]{n}[/itex]
I'm thinking that for this series I should use the nth term divergence test.
I know that the limit of each of them is 1, and the whole series converges to 1, but I can't remember why the limits are 1. Could someone please remind me? :)
Your typesetting is messed up. Is this the series you are evaluating?
$$\sum_{n=1}^{\infty} \sqrt[n]{3} \sqrt[n]{n}$$
If so, you are correct that ##\lim_{n\rightarrow \infty} \sqrt[n]{3} = 1## and ##\lim_{n\rightarrow \infty} \sqrt[n]{n} = 1##.
As you said, this implies that ##\lim_{n\rightarrow \infty} \sqrt[n]{3} \sqrt[n]{n} = 1## (the limit of a product is equal to the product of the limits - it's a good idea to check the proof of this if you aren't sure).
What does that imply about the limit of the series?
Sorry,that is what I meant! Since the limit doesn't approach 0 it diverges? But why does the limit equal 1 when you plug in infinity?
Regarding why ##\lim_{n\rightarrow \infty} \sqrt[n]{3} = 1##:
First note that ##\sqrt[n]{3} = 3^{1/n}##. Consider the log of this expression: ##\log(3^{1/n})##. Can you find the limit the log as ##n \rightarrow \infty##? Can you use the result to find the original limit?
Yes, that's right. The terms do not approach zero, so the series diverges.
See my previous post for a suggestion for ##\lim_{n \rightarrow 1} \sqrt[n]{3}##. The other limit, ##\lim_{n \rightarrow 1} \sqrt[n]{n}##, can be handled similarly but with a slight complication.
I'm sorry, I still don't quite understand what you mean. I get how you're rewriting the square root, but I got a little lost with the logs.
I claim that ##\lim_{n \rightarrow \infty} \log a_n = \log \lim_{n \rightarrow \infty} a_n## for any convergent sequence of positive values ##a_n##. This is because ##\log## is a continuous function. Let's assume we know this result for now - if you're not sure why it's true, we can come back to it later.
So in your case, ##a_n = \sqrt[n]{3}##, and we have what I will call Equation 1:
$$\lim_{n \rightarrow \infty} \log \sqrt[n]{3} = \log \lim_{n \rightarrow \infty} \sqrt[n]{3}$$
Working with the left hand side, we have ##\log \sqrt[n]{3} = \log (3^{1/n}) = \frac{1}{n} \log 3## by the basic property of logarithms that ##\log x^y = y \log x##.
Now take the limit of that expression: ##\lim_{n \rightarrow \infty} \frac{1}{n} \log{3} = ?## You should be able to get a numerical answer. Once you have that answer, do you see how Equation 1 allows you to find ##\lim_{n \rightarrow \infty} \sqrt[n]{3}##?
