Determining Missing Trigonometric Ratios
4 replies · 2K views
Euler2718
I'm not stuck per say, but I need to know if I have the right idea for solving the rest of these questions.
1. Homework Statement
For the following given trigonometric ratio and domain, determine the missing trigonometric ratio.
[tex]cos\theta = -\frac{1}{2} , \frac{\pi}{2}\leq \theta < \pi[/tex] find [tex]cot\theta[/tex]
I know how to do these normally, it's just the "find other trig. ratio" tacked on the end that's sort of distorting me. My attempt was finding the reference angle of the trig. value which turned out to be...
[tex]\theta_{r} = \cos^{-1}\left(\frac{1}{2}\right) = \frac{\pi}{3}[/tex]
Now, the question is looking for cotangents. Because the original (cosine) was negative, I postulate that you would be looking for negative cotangents in the restriction given (not negative angles, but negative relative to the quadrant). Thus in quadrant two, the answer would be
[tex]\pi - \frac{\pi}{3} = \frac{2\pi}{3}[/tex]
Thank you for reading.
on Phys.org
An alternative scheme would be to recognize the triangle whose cosine is -1/2 and from there construct the cot without the need of getting the angle.
No, ##\theta## is in the second quadrant. Once you know the angle in question, it's easy to get all of the trig functions of that angle.
Yes, that's the correct angle. Now find the cotangent.
It would be better to solve cos-1(-1/2) for the given range before worrying about the cotangent. If cos-1(x) = A, what is the general expression for cos-1(-x)?
Another approach is not to determine the angle at all. Just use the relationships between trig functions to go from cos to cot.
(and the Latin expression is per se)
Okay, I think I understand now. Thank you all who posted.
