Differentiating and Integrating the Lambert W function
The discussion centers on the differentiation and integration of the Lambert W function. The initial differentiation attempt using the chain and product rules is identified as incorrect, with the correct derivative expressed as w'(x) = 1/(e^w(x) + w(x)e^w(x)). The conversation highlights the ambiguity in the notation used for the derivative, emphasizing the distinction between dW(xe^x)/dx and dW(x)/dx. For integration, a method involving separation of variables is suggested, leading to the integral expression ∫W dx = ∫(W + 1)W e^W dW. Overall, the thread explores the complexities of working with the Lambert W function in calculus.
pierce15
Here was my thinking for differentiation (which, by the way, is wrong):
By the definition of the function, the following equations are equal:
$$W(xe^x)=x$$
By the chain rule and product rule:
$$\frac{dW}{dx}( e^x+xe^x ) =1$$
$$\frac{dW}{dx}=(e^x+xe^x)^{-1}$$
What is the error here? What is the correct way to differentiate it? Also, how would I integrate it?
P.S. Why is the fraction bar in the third equation bolder than in the second equation? They are typesetted the same way...
Hey piercebeatz.
Basically you use the chain rule: d/dx f(g(x)) = g'(x)f'(g(x)).
Note that W(x) in this case is W(x*e^x) or W(g(x)) where g(x) = x*e^x.
you have found
w'(e^x+x e^x)=1/(e^x+x e^x)
you might want to start with
w(x) e^w(x)=x
to find
w'(x)=1/(e^w(x)+w(x) e^w(x))
The expression :
$$\frac{dW}{dx}=(e^x+xe^x)^{-1}$$ is true, but ambiguous.
Do not confuse :
$$\frac{dW(xe^x)}{dx}=(e^x+xe^x)^{-1}$$
and
$$\frac{dW(x)}{dx}=\frac{W(x)}{x(W(x)+1)}$$
JJacquelin said:
The expression :
Do not confuse :
and
Looking back at the top, that was a pretty lousy use of the chain rule. I see what I should have done now.
Do you have any idea how to integrate it?
Have you tried using separation of variables?
^right very nice
\int W \text{ dx}=\int W \text{ d}(We^W)=\int (W+1)W e^W\text{ dW}
lurflurf said:
^right very nice
Sorry what did you do there?
^As chiro suggested separation of variables, which is equivalent to the substitution
x=W(x)e^W(x)
The LambertW integral :
  • · Replies 27 ·
  • · Replies 19 ·
