Differentiating x² + 2xy - 3y² + 16 = 0
  • Thread starter Thread starter thomas49th
    Differentiating
20 replies · 18K views · last reply
thomas49th
A curce has equation:
find the co-ordinates of the points on the curve where dy/dx = 0
I don't have a clue. Do I convert them into parametric equations?
Differentiate Implicitly.
You should get [itex]\mathrm{d}y/ \mathrm{d}x[/itex] within the differentiated equation twice. Factorise [itex]\mathrm{d}y/ \mathrm{d}x[/itex] (by taking it to one side) and rearrange it so that it is only on one side. Then solve for co-ordinates.
i tried looking at implicit differentiation here http://www.maths.abdn.ac.uk/~igc/tch/ma1002/diff/node49.html
and my book but i don't understand it.
dy/dx (x² + 2xy - 3y² + 16)
= 2x + 2y - 3y² + 16
Apparently i should use the chain rule somewhere?
Thanks
Thanks
We should write that first line as
d/dx (x² + 2xy - 3y² + 16) = d/dx (0)
i.e., it's "d/dx" and not "dy/dx" in front, since we want to take the derivative with respect to x.
Then use the chain rule, and when needed the product rule. For example:
[tex] \frac{d}{dx}(x^2 y^4)<br /> = 2x \cdot y^4 + x^2 \cdot 4 y^3 \frac{dy}{dx} [/tex]
so if i do:
i get
2x + 2y - 3y²
how am i ment to use the chain rule? I don't see.
dy/dx = dy/du x du/dx is the chain rule. What is u and y
Let's suppose u = y^4, and we want to differentiate that with respect to x.
d/dx (y^4)
= d/dx (u)
= du/dx
and by the chain rule
= (du/dy) * (dy/dx)
= 4 y^3 * (dy/dx)
Moreover:
d/dx (2xy) is not 2y. You need the product rule here, applied to the functions "x" and "y".
Hi thomas49th! :smile:
Simple question:
Simple answer:
y is 3y², and u is y. :biggrin:
oh yes they are …
d(3y²)/dx = d(3y²)/dy dy/dx = 6y dy/dx. :smile:
im still lost completely. I know the chain rule. I don't see how y is 3y² nor why u is y. Can you show me why. Why do you set u equal to y?
Your original problem was implicit differentiation of x² + 2xy - 3y² + 16:
that is, d/dx of x² + 2xy - 3y² + 16.
Obviously , d/dx of x² + 16 is really easy, and d/dx of 2xy is fairly easy … I assume you can do that …
So that leaves d/dx of 3y².
You know how to do d/dy of 3y².
So you use the chain rule: d(3y²)/dx = d(3y²)/dy dy/dx = 6y dy/dx.
Does that make sense? :smile:
is d/dx of 2xy
= 2(x+y)
= 2x + 2y ?
i don't think it is. I've used the product rule (dy/dx = v du/dx + u dv/dx).
I know about the chain rule, quotient and product rule. I just don't know how to differeriate parametric equations and equations with both x and y in (i can do y = ... but not y² + yx + x²).
d/dx of x² + 16 is really easy, it's 2x. easy peasy. This implicit differentiation is really confusing me. I can't find it in my book!
thomas the idea is really simple.
if you have y^2 then different as if it was x , you should have 2y. simple right?
Now all you have to do is multiply the 2y by dy/dx. Just write 2y . dy/dx and that's the answer.
So whenever you different with the letter y, do it as if it was x but just multiply it by dy/dx. This is because of the chain rule, since y is a function of x.
thomas49th said:
is d/dx of 2xy
= 2(x+y)
= 2x + 2y ?
d/dx of 2xy
= d(2xy)/dx = yd(2x)/dx + 2x dy/dx = 2y + 2x dy/dx.
so the final answer is
2x + 2y + 2x . (dy/dx) -6y . dy/dx
NOTE is it 2y + 2x . (dy/dx) or 2y . (dy/dx) + 2x
So now I've differntiated it i need to find these co-ordinates
Well ill set 2x +2y + 2x . (dy/dx -6y . dy/dx = 0
2x + (2x . dy/dx) = (6y . dy/dx) - 2y
But now I am stuck with how to treat these dy/dx...
You're right … it's definitely the first one.
(2y . (dy/dx) would be the d/dx of y²)
Then, as you said in your first post:
So just put dy/dx = 0 in 2x + 2y + 2x . (dy/dx) - 6y.dy/dx
that gives you … ? :smile:
(going to bed now … :zzz:)
ahhh YOU ACUTLALY SUBST FOR dy/dx = 0
2x + 2y = 0
y = x
please say that is right...
Night Night.
2x + 2y = 0
y = x
Night Night.
Not quite but you are really close.
2x + 2y = 0
Divide both sides of equation by 2:
x + y = 0
And then
x = ?
No. It is NOT right.
2x+ 2y= 0 is right. But you solved that equation wrong!
2x + 2y = 0
y = x
Night Night.
… yawn … stretch … rubs eyes …
It's right! :biggrin:
well … apart from the minus sign! :rolleyes:
Now put y = -x into the original curve equation x² + 2xy - 3y² + 16 = 0, to find the points where dy/dx = 0, as required. :smile:
y = -x
silly mistake about the minus
right anyhow
= x² - 2(x)² - 3x² = -16
-4x² = -16
x = +-2
SOOOOOOOO ill sub x = - y
y² - 2y² - 3y² = 0
well that's easy y = +-2
so (2,-2),(-2,2)...how do i not know it's (-2,-2) (2,2)?
thomas49th said:
x = +-2
y² - 2y² - 3y² = 0
erm … you're missing the obvious … you have x = ±2, and x = -y.
So you don't need to put y back into the equation, do you? :wink:
yeh just sub x = 2 go get one y co-ord then x = -2
