Dimensional Analysis and units of time
This discussion centers on the dimensional analysis of time and distance, specifically regarding the concept of a "light minute." Participants clarify that a light minute is indeed a unit of distance, equivalent to the distance light travels in one minute, which is 60 times the distance of a light second (299,792,458 meters). The speed of light can be expressed as 1 light minute per minute, leading to confusion about unit conversions and dimensional consistency. Key calculations reveal that light travels approximately 111,600,000 miles in one minute, and participants address algebraic rules for manipulating units in equations.
  • Understanding of dimensional analysis
  • Familiarity with the speed of light (c) and its units
  • Basic algebraic manipulation of units
  • Knowledge of unit conversion between feet, meters, and light seconds
  • Study dimensional analysis techniques in physics
  • Learn about unit conversions between metric and imperial systems
  • Explore the definition and implications of the speed of light in various units
  • Review algebraic rules for manipulating units in equations
Students and professionals in physics, engineering, and mathematics who are working with unit conversions and dimensional analysis, particularly in the context of speed and distance measurements.
gtguhoij
If someone is using the minute as their unit of time, what unit should they choose for length so the speed of light will be one in those units?
time = x(min)
distance = 1(y)
y = unknown unitsI think the answer should be 1(y)/ Min. This is not correct becase 1(y) is unknown. Any help?
I have the answer but am confused
How far does light travel in one minute?
A light minute.
gtguhoij said:
A light minute.
Is that a unit of distance, then?
I think so but from your question it seems it is not. Why is it not?
Do you mean something like 17,987,547,480.00 meters/minutes? except it is = 1 y/minutes?
Where y is an unknown unit of distance.
But how do I make y/minutes = 1 for velocity of light?
I am sorry I am just confused.
A question is a question. A question is not a statement.
Is a light minute a unit of distance?
Yes
gtguhoij said:
Yes
And if you measure distance in light minutes and time in minutes, what is the numerical value of the speed of light in those units?
gtguhoij said:
1 light minute.
That has the wrong dimensions for speed. Speed has dimensions of ##LT^{-1}##.
Let‘s try a different approach. You are trying to convert to a new unit of velocity (nuv) which has magnitude 1. It is given that the new unit of time (nut) is 1 minute. You are trying to figure out the new unit of distance (nud). In these units, velocity is measured in nud’s per minute. The question is how many ft are in a nud so that when you convert the speed of light from ft/ns to nud’s/min you get 1 nud/min.
Whoops I calculated time and velocity.
##d = vt##
##t = d/v = ##
##v = \frac {186 000 miles }{second} * \frac {60 sec}{1 min} = \frac{111 600 000 mile} {min} ##
## t = \frac {1L ~Min} {11 160 000 ~miles~min} = ##
##\frac {1c} {1116000~miles~min } =## ##\frac {186 000~ miles} {11160000miles~min } = 0.0166 min##
My one question is shouldn't it be ## \frac {0.0166} {min}##. How do I move the minutes units to the top? I am pretty sure there is an algbra rule I just can't remember it. I am pretty sure it is different rule then what I used in the first part of ## t = ... ##
I referenced this site rule number 3 for the first step in ##t=...## https://algebrarules.com/.
If I made any mistakes let me know.
##d = vt##
##t = d/v = ##
I'm lost for words. I have no idea what you are trying to do: ##c = 1## light-minute per minute, by definition.
This might help...
You do not need to use c = 186,000 miles/second.
An apostrophe is the symbol for 1 foot.
It appears you are told that c = 1’/ns. This means c = 1ft/ns.
So light moves 1 foot each nanosecond (approximately true in a vacuum).
How far (in feet) does light travel in 1 minute?
This distance is the size of the required unit (which you call ‘y’), because light travels a distance ‘y’ in 1 minute. So speed = 1 y/min.
The question simply wants the value of y expressed in feet.
And in terms of other units: 1 light minute is 60 light seconds. A light second is 299 792 458 meters by definition.
Therefore a light minute is 60 \times 299\,792\,458 meters.
I get what to do now to get the correct answer. Is the math correct in post #11? Even though it doesn't answer the question.
No. One light minute divided by the speed of light equals 1 minute. There’s a typo in the velocity equation (1 too many zeros). In the time equation, the units of velocity in the denominator are wrong and there are issues with your calculated value of a light minute (it looks like you are mixing different time units, seconds and minutes).
  • · Replies 24 ·
