Disk held up by a massless string: normal force integration error
5 replies · 4K views · last reply
John100861
(a) A disk of mass M and radius R is held up by a massless string, as
shown in Fig. 2.12. The surface of the disk is frictionless. What is
the tension in the string? What is the normal force per unit length
that the string applies to the disk?
ΣF=0
The first part is easy, we have 2T= Mg
T= 0.5 Mg
Now for the second part where I'm having trouble understanding Morin's solution:
I take the normal force on a small circle arc to be N, we know that the y component of the normal force must be balance with Mg for the whole disk, therefore
Ny = Nsin(θ)
dNy= Ncos(θ)dθ
Ncos(θ)dθ= Mg
And this is where I have trouble, I end up with Mg= 0 when plugging in the limits [0, π]
Morin's solution suggests that the normal force in the arc should be written as Ndθ but I don't understand why. Please point out what's wrong with my approach, and help me understand the solution, thanks.
You cannot define N in that way since it depends on the length of arc. Better to consider N as a force per unit length.
Pinpointing your error is not possible until you say how you are defining theta.
If it is the angle between the dashed line and the radius to an element ##rd\theta## of arc, the normal force is ##Nrd\theta##, and its Y component is ##Nr\cos(\theta)d\theta##.
Hi thanks for your reply! Yes I'm defining that to be theta. Could you please elaborate on this? It's still not clear to me why I can't define N that way.
The normal force on a small circle of arc will depend on the length of the arc. So you need it as (some variable) x length of arc, i.e. as a force per unit length.
Why does it depend on the length of the arc?
The tension in the string exerts a pressure on the cylinder. Over a small (effectively almost straight) section of arc the force is the pressure times the length.
