Dispersion Relations: Most Famous DR & Contexts Explained
  • Context: Undergrad
  • Thread starter Thread starter DaTario
The discussion revolves around the concept of dispersion relations (DR) in physics, specifically questioning the most famous DR and exploring contexts in which various DRs are applied. Participants discuss the significance of the equation v = λf and consider other notable DRs, particularly in solid state physics and wave mechanics.
  • Some participants suggest that the equation v = λf is widely recognized but question its status as the "most famous" DR, proposing that the E vs k dispersion relation is more significant in solid state physics.
  • One participant notes that the popularity of v = λf may stem from its simplicity and ease of understanding rather than its fundamental importance.
  • Another participant describes a practical application of dispersion relations in atmospheric studies using laser beams, illustrating the relevance of DR in experimental contexts.
  • Several participants discuss the relationship between energy and momentum in various systems, suggesting that dispersion relations can apply to a wide range of particles and phenomena.
  • Some contributions mention the mathematical representation of dispersion relations, including the ω(k) function and its implications for non-dispersive media.
  • There is a discussion about the historical context of dispersion relations, referencing De Broglie's work and its implications for understanding wave-particle duality.
  • Participants express differing views on the terminology used to describe dispersion relations, with some advocating for a focus on physical content rather than popularity.
Participants do not reach a consensus on which dispersion relation is the "second most famous," and there are multiple competing views regarding the significance and applications of various DRs. The discussion remains unresolved with respect to the hierarchy of DRs.
Some participants highlight limitations in introductory physics texts regarding the coverage of dispersion relations, suggesting that more examples could enhance understanding. There is also a recognition of the complexity involved in defining and applying dispersion relations across different contexts.
DaTario
Hi All,
The equation:
## v = \lambda f ##
is presented as a dispersion relation (DR) for it is a formula that specifies the velocity of a wave of certain frequency.
This equation seems to be the most famous DR in physics.
My questions are the following:
What is the second most famous DR? Which context this second DR fits in?
Best wishes,
DaTario
DaTario said:
Hi All,
The equation:
## v = \lambda f ##
Best wishes,
DaTario
Where did you discover that this is "the most famous DR in physics"?
For many of us who study Solid State/Condensed matter physics, the E vs k dispersion relation is more common (it is almost the "figure of merit" in this field since this is how we describe the band structure of materials). But one could argue that E vs k dispersion relation is itself a distant cousin of v vs. λ.
Zz.
I can see how, in a breadth sense, that equation is so popular. It's an easy equation that explains a lot when you consider geometry. I got my undergrad in physics before moving on to neuroscience and that's the equation that sticks out to me for DR. So it's popularity could be a statement of its easy digestibility more so than it being more fundamental or meaningful that other relations.
Zz.
I said "seems to be", not "I have discovered".
Once I was in a congress of laser applications in Santa Catarina (Brazil) and one of the works presented there was about a study of the atmosphere´s level of polution. They developed a set of laser beams, each one with a different color, all aimed to the sky, along the same line. The dispersion relation was known and taken into account in a manner that the slowest colors were emitted before and the faster ones, after. The time intervals were precisely adjusted so that at a given altitude, say 5 km above the ground, all the pulses would be at the same volume, producing a sort of explosion. From the collected light of this explosion they were able to infer the level of polution in the air.
I had no contact with the dispersion relation they used. :frown:
DaTario said:
Hi All,
The equation:
## v = \lambda f ##
Best wishes,
DaTario
I haven't studied dispersion so much but the equation you mention is mostly known as "the fundamental equation of wave physics".
If the velocity v is constant (depends only on the medium that the wave propagates) then there is no dispersion at all. When the frequency changes then the wavelength changes according to that equation as to keep the velocity constant.
If the velocity v depends on the frequency or wavelength like it is for example in optics ##v=\frac{c}{n(\lambda)}## where ##n(\lambda)## the refractive index of the medium that depends also on the wavelength ##\lambda## then we have dispersion.
Classifying DR by its popularity lacks physical content. "The simplest" is probably the more fitting term. ##v=\lambda f## with ##v=\textrm{constant}## describes the relation between frequency and wavelength of EM wave in free space.
And it also applies to the homogeneous string with fixed ends.
I agree, a dispersion relation is a functional relationship between energy and momentum, and this can be expressed for a variety of particles and systems- electrons, holes, phonons, photons, transverse waves, longitudinal waves, surface waves, etc.
I have seen some dispersion relations expressed as an $$ \omega(k) $$ function, which seems to be what you are referring to.
If we have $$\omega(k) = Constant \,\times k$$ it qualifies the medium as a non dispersive one, for $$ \omega / k $$, the phase velocity, will be constant.
A more complete dispersion equation for a string, for instance, is pointed out in wikipedia as $$\omega^2 = \frac{T}{\mu} k^2 + \alpha k^4. $$
Since
[itex]E=\hbar \omega[/itex]
This is no different then E vs k dispersion relation that I mentioned earlier. In solid state physics, this is the band structure of the material. Look for example, the band structure for some typical metals:
http://what-when-how.com/electronic...stals-fundamentals-of-electron-theory-part-3/
No "constant phase velocity" or group velocity anywhere.
Zz.
ZapperZ said:
Since
Zz.
Yes, I see. This extension of the concept of dispersion relation seems to be due to the work of De Broglie, who assigned wave atributes to the microscopic particle's phenomenology.
The index of refraction ## n(f) ## seems also to be another door to enter this subject.
Excuse me? "Microscopic particle's phenomenology"?
It is the solution to the many-body Hamiltonian, or to the Density Functional Theory. I wouldn't call those "phenomenology" anymore than the Schrödinger equation.
Zz.
The intelectual act of De Broglie was to suppose that the microscopic particles would be correctly described by using wave formalism and atributes. The band structure arises from collective effects of particles, which create periodic or quasi periodic potentials, on the energy levels.
The point in the OP was not to give importance to popularity. Sorry if this was the impression left. The point was to ask for contributions in the field of dispersion relations. I notice that in introductory books of physics, even in A.P. French book, examples of dispersion relations appear very rarely.
  • · Replies 45 ·
  • · Replies 29 ·
  • · Replies 21 ·
