How Do You Calculate Distance Traveled in the Last 20 Minutes of a Drive?
  • Thread starter Thread starter zak100
The discussion centers on calculating the distance traveled by Stan during the last 20 minutes of his drive, given that he drove for h hours at a constant speed of r miles per hour. The correct formula to use is S = V * t, where S is the distance, V is the speed, and t is the time. The final distance for the last 20 minutes can be expressed as S = r/3, where r is the speed in miles per hour. Participants emphasize the importance of not assuming specific values for r and h, as the problem is designed to be solved algebraically.
  • Understanding of algebraic equations, specifically S = V * t
  • Knowledge of unit conversion, particularly between hours and minutes
  • Familiarity with the concept of constant speed in motion
  • Ability to interpret and manipulate variables in mathematical problems
  • Study the concept of unit conversion in physics, focusing on time and speed
  • Learn how to solve algebraic equations involving variables without assigning specific numerical values
  • Explore similar motion problems involving distance, speed, and time
  • Practice deriving formulas for distance traveled over specific time intervals
Students studying algebra, educators teaching motion concepts, and anyone looking to improve their problem-solving skills in physics-related scenarios.
zak100
Stan drove for h hours at a constant rate of r miles per hour. How many miles did he go during the final 20 minutes of his drive?
S= V* t
Let H=6 hours, r=10 miles/h
1 H = 60 min
6 H = 360 min
S=v t
S= 10 * 360 = 3600miles
S= 10 * (360-20)= 3400 miles
Miles in last 20 minutes = 3600 – 3400 = 200 miles
But this we can get directly by
S= 10 * 20 = 200 miles.
I can't understand some body please guide me.
Zulfi.
S= V* t
1 H = 60 min[/B]
6 H = 360 min[/B]
S=v t[/B]
S= 10 * 360 = 3600miles[/B]
S= 10 * (360-20)= 3400 miles[/B]
Miles in last 20 minutes = 3600 – 3400 = 200 miles[/B]
But this we can get directly by[/B]
S= 10 * 20 = 200 miles.[/B]
Zulfi.[/B]
Several things you have written don't make sense.
Most importantly, speed and time need to be in units which are consistent with each other.
Simply change 20 minutes into units of hours.Beyond that, the statement of the problem says nothing about total time nor about a specific speed (rate).
You're making this much harder than it actually is. A similar question would be "How far did he go in the last hour of his drive?" If you can answer that, you should be able to answer the question of this problem.
Hi,
Thanks for your response.
Okay I am converting everything into hours.
Let H= 6 & r (= v) = 10 miles/hour
S= v * t = 6 * 10 = 60 miles / hour
60 minutes = 1 H
1 min = 1/60 H
20 min =1/3 H
For 20 min
S = v * t = 10 * 1/3 = 3.33 miles
In Last 3 minutes, he covered = 60 -3.33 = 56 miles
Note answer is r/3. Some body please guide me.Zulfi.
Hi,
I think my solution is right. Because I have written:
S = 10/3 & i have supposed
r = 10.
So i can write:
S = r/3.
Zulfi.
zak100 said:
Hi,
r = 10.
So i can write:
S = r/3.
Zulfi.
You are not allowed to assume any specific value for ##r##. However, ##r/3## is correct for this problem; do you see why?
Hi,
<You are not allowed to assume any specific value for r>Book has solved several such questions by supposing values.
However, r/3 is correct for this problem; do you see why?
No I don't see. We have to find last 20 minutes drive i.e from 340 minutes to 360 minutes according to my assumed values. May be this is the reason you are against supposing values.
Zulfi.
zak100 said:
Hi,
Zulfi.
I am very much against you assuming any values, because when you do that you are NOT LEARNING! You WERE given values: h hours at a rate of r miles per hour--those are your values, end of story. Since you are supposed to be doing algebra, not arithmetic, you should not use numbers at this point. (However, you were given one number: 20 miinutes.)
Repeating what Ray said, the only numeric constant in this problem was the 20 minutes.
Here is the problem as you wrote it in post #1. All of the information needed is here. You should NOT make any assumptions about specific values for the speed or time.
In post 3 I said this:
zak100:
S= V* t
In your attempt at the solution, you used the equation s=Vt, and you plugged in V=10 miles/h. But that 10 is just a number you made up. Nowhere does the problem statement say that r=10 miles/h. It just gives the speed as r.
As for the time, t, you started off by saying that t=360 minutes, or 6 hours. But again, that 6 hour time just a number you made up. It is not stated in the problem.
So, think carefully. Ask yourself:
1. In the equation S=V t, what do the symbols S, V and t mean, and what does the equation let you work out?
2. What are you going to use for V in the equation, bearing in mind that you can't just make up a number?
3. What are you going to use for t?
4. How does the "final 20 minutes" come into this?
9K
  • · Replies 20 ·
9K
