DNA Melting Curves: E. coli and Low % GC Content Samples with Sybr GreenI Dye
  • Thread starter Thread starter dronee
    Curve Dna
The discussion focuses on DNA melting curves using Sybr GreenI dye to analyze E. coli DNA samples. The melting curve is characterized by a sigmoidal shape, indicating the transition from double-stranded to single-stranded DNA as temperature increases. Samples with lower GC content exhibit lower melting temperatures, necessitating adjustments in the graph representation. The influence of pH on the melting curve is also acknowledged, with higher pH levels potentially affecting DNA stability.
  • Understanding of DNA structure and the significance of GC content.
  • Familiarity with fluorescence techniques, specifically Sybr GreenI dye.
  • Knowledge of graphing techniques for scientific data representation.
  • Basic principles of thermodynamics as they relate to DNA melting.
  • Research the principles of DNA melting temperature and its dependence on GC content.
  • Explore the use of Sybr GreenI dye in quantitative PCR applications.
  • Learn about the effects of pH on DNA stability and fluorescence measurements.
  • Investigate graphing software tools for visualizing melting curves effectively.
Biochemists, molecular biologists, and researchers involved in DNA analysis and fluorescence techniques will benefit from this discussion.
dronee
You have a dye, Sybr GreenI which binds only to double stranded DNA (not single stranded). Once bound, it fluoresces strongly and can be used to monitor DNA melting (transition from double stranded to single stranded).
(i) on the axes provided draw the DNA melt curve for a sample of E. coli DNA which has been mixed with Sybr GreenI.
--> the axes shown has Temperature for x-axis and Fluorescence for y-axis.
on the same graph show the melt curve for a sample of DNA
(ii) with a lower %(G+C) content
(iii) from the same source dissolved in a buffer at pH>9 prior to the measurements.
(i) okay so I am thinking the shape of the curve is like an S
kind of like this: http://www.entelechon.com/wp-content/uploads/2008/10/dna_melting-300x178.gif
but is it exactly like that? or is the other way?
(ii) for this one i know that i just have to draw the exact same shape except more towards 0 since more GC content means higher melting point.
(iii) I am not sure about this one.
help please?
bump. anyone?
