Do Alternative Explanations for Gluons Exist and How Can We Test Them?
38 replies · 5K views
Cody Livengood
TL;DR
I understand how the existence of quarks is inferred from the three particle-emitting cones or jets and by the quarks’ ability to deflect particles passing through the composite particle, but I don’t see how the existence of gluons is conclusively demonstrated by this rather than just being an interpretation of the observation.
I understand how the existence of quarks is inferred from the three particle-emitting cones or jets and by the quarks’ ability to deflect particles passing through the composite particle, but I don’t see how the existence of gluons is conclusively demonstrated by this rather than just being an interpretation of the observation. How do we know that two of the jets were produced by quark-antiquark pairs that fragmented into hadrons and the third was produced by a gluon that fragmented into hadrons? How can we tell the difference?
It fit the preductions of the QCD model, in which there are gluons.
The existence of all subatomic particle are "interpolation of the observation"
Same as say the Higgs boson, we think it exists due to the observation matches the models prediction to a very high statistical certainty.
Sooo... you're saying that we don't have any actual proof that gluons exist?
  • Skeptical
If there were no gluon, the number of events that look like the following is roughly zero.
Vanadium 50 said:
If there were no gluon, the number of events tghat look like the following is roughly zero.
I thought that experiment was used to verify the existence of quarks. The explanation is that two of the jets were produced by quark-antiquark pairs that fragmented into hadrons. I don't see how we know that one of them was caused by a gluon.
What is an actual proof?
Think about it for a while.
Do we prove things in natural sciences?
I suppose it would be an observation that we, for the time being, have no other explanation for. That still doesn't really answer my question though. I'm not asking this for fun. I'm working on a serious project. If we have no real reason to believe that they exist other than "it fits the theory," then it's okay to say so.
  • Skeptical
Of course it is ok to say so, that is the only reason we ever have to believe anything in science. That is how the scientific method works.
Did you think that science ever let's us know something in a different way?
*rolls eyes* I think you're taking my statement a little too far and ignoring the actual question at hand. Not helping.
Then see #6.
Actually, the problem is that you don't seem to be making clear what you want. If you wanted "an observation that we, for the time being, have no other explanation for" then there's already one in post #6. If you want something that couldn't possibly be anything other than a gluon then you have a fundamental misunderstanding of how science works. If you want something else, what do you want?
Ibix said:
Then see #6.
I want to know how we know it was produced by a gluon and not the third quark in the nucleus or by three quantum vortexes linked in a ring or anything else. What's the proof?
No, the three-jet events are clear indications for gluons!
Come up with a detailed mathematical model of how those operate and make predictions for ratios of different collision products based on that model. If those don't match experiment then it's not a possibility. If they do match experiment it's a possibility, and we'd have to find some prediction your model makes that differs from the standard model and try that experiment.
Models that include gluons currently predict experimental outcomes as precisely as we can measure, and no other model does (as far as I'm aware). But all knowledge is subject to revision if new evidence not matching current models comes along.
It does, the cross section (probability) of 3, 4, 5, ..jet events is best explained by the model of QCD.
There are also processes whos cross sections that depends on the gluon parton distribution functions, which fit the model of QCD more or less perfectly.
It is not only their existence, but also the rate of which 3-jet events are produced in comparison with 2 jet events.
Gluon is a spin one particle, so you get a certain angle distribution of the jets, which you can measure and compare with data. This is of course also been done.
There are no proofs in natural sciences.
But in a positron-electron collision, where is the "third quark in the nucleus"?
In order to undestand why the three jet events from electron-positron collisions, you need to know something about the models available to explain the experimental outcome.
And, it turns out that QCD is the model that BY FAR, explains all that data which has to do with hadron jets.
Quantum vorticies? I thought you were studying particle physics and not condensed matter physics?
I understand that this is some kind of school project for you.
Could you mention the name of the course, what level it is and syllabus, perhaps also the instructions for the project?
There is no proof. There is only evidence that supports or doesn't support the framework, model, or theory that you're using. In this case the evidence supports the idea that the tracks originate from the decay of a gluon and not something else.
It does help. The issue isn't the evidence for gluons, the issue is that you don't understand how the scientific method works.
The standard that you are rejecting here is the same standard by which we know anything scientifically. Insofar as you reject this evidence as "actual proof" then there is no such thing as "actual proof" anywhere in science.
As a refresher, in science we ideally start with a theory. From that theory we make a prediction about the outcome of an experiment we could run, this prediction is called a hypothesis. We then run the experiment and compare the actual observation to the hypothesis. If the observation is consistent with the hypothesis then we interpret that as being experimental validation of the theory. That is simply how science works.
So, the question is, why do you think that a different standard of scientific evidence should apply for gluons? Or equivalently why do you think that the usual scientific method should not apply to gluons?
One should also note that the QCD model can explain and predict a pletora of phenomena.
If one model can explain and predict 50 different things, or if you need 50 models to explain those things. The "one" model is preferred.
How so? How does it support that idea? I could say that it supports the idea that it was produced by three quantum vortexes linked in a ring or that the three jets were produced just by the three quarks and I could say that the experiment "supports the idea." Where is the proof (or whatever you want to call it) that it was produced by gluons?
  • Sad
you need to do the calculations.
It is quite an easy task to calculate the cross section and angular distribution of ##e^+ + e^- \to jjj##
We did that in my first QFT course, it was a problem in Peskin and Schroeder QFT book
Physical models are mathematical models, you can not just mash fancy words together, you have to do the calculations. You should know this is if you are taking a physics class.
Then you can show us the calculations using this theory you are proposing and also show that they match the observational data.
And predict other, not yet observed, phenomena, so that the theory is falsifiable.
in other words, the scientific method.
Physical models are mathematical models, you can not just mash fancy words together.
Could you translate into words what the proof is? Explain the evidence using words that actually mean something physical, like "Because two of the jets went straight and the third spiraled" or something like that. Otherwise, I still don't see the observation as proof for one model rather than another.
The language of physics is math.
  • Love
See @malawi_glenn's post #16. Basically, if we posit gluons then the maths describing them leads to accurate predictions of particle collisions. If you want to posit something else you need to come up with maths describing that something else and show that it makes the same predictions.
Note that the key thing here is the maths. The words are more or less irrelevant. So just saying "quantum vortexes did it" is useless without a mathematical description of what quantum vortexes are and how they interact to produce the observed collision products.
We do not have any mathematical models that make correct predictions and do not include gluons.
Not really. That's why we use maths for the job.
Again, the reason we believe gluons exist is the same reason we believe anything exists: mathematical models including them make accurate predictions.
That's honestly not good enough for me. I want to understand what is physically going on.
Well learn Quantum Field Theory then.
