Do Maxwell's equations keep the same form in different Lorentz frames?
16 replies · 3K views · last reply
kent davidge
Do the Maxwell equations in the usual 3-vector form have the same form in any Lorentz frame? For example, the one that says ##\nabla \cdot \vec B = 0## will be valid in another, primed Lorentz frame? That is ##\nabla' \cdot \vec {B'} = 0##?
Yes. It is a tedious exercise, but you can work through it and prove it.
How is it tedious? Knowing the covariant form of Maxwell’s equations I find it pretty straight forward ...
It is tedious to me because using three-vector equations is always tedious when you know the covariant equations.
IIRC, MTW give some examples where the covariant (4-D tensor) equations can be used to derive the 3-vector equations more easily than the 3-vector view itself can, and one of the examples has to do with transforming EM fields.
The easiest way of doing it is first showing that the full covariant form implies the three-vector form. This in itself is just a couple of lines.
It seemed messy to me as well, but I suppose if you look up the dual of the Faraday tensor (here denoted as G) in terms of the E and B field components from wiki https://en.wikipedia.org/wiki/Electromagnetic_tensor or some other more reliable textbook, you can get ##\nabla \cdot B = 0## from ##\partial_a G^{a0} = 0##
Doing all the equations still strikes me as a pain, though.
It really isn’t. I would do it but I am on my phone and writing TeX on the phone is a pain.
So here goes (up to arbitrary unit-dependent constants). The main thing to remember is that (using Greek letters for indices going from 0 to 3 and Latin letters for those going from 1 to 3):
E^i = F^{i0} \quad \mbox{and} \quad B^i = -\epsilon_{ijk}F^{jk}/2 \quad \mbox{or} \quad F^{ij} = -\epsilon_{ijk} B^k.
From ##\partial_\mu F^{\mu\nu} = J^\nu## follows that
\rho = J^0 = \partial_0 F^{00} + \partial_i F^{i0} = 0 + \partial_i E^i = \nabla \cdot \vec E
and that
\vec J = \vec e_i J^i = \vec e_i \partial_\mu F^{\mu i} = \vec e_i [\partial_0 F^{0i} + \partial_j F^{ji}] = - \partial_t \vec E - \vec e_i \epsilon_{jik} \partial_j B^k
= - \partial_t \vec E + \nabla \times \vec B.
The remaining Maxwell equations follow in exactly the same way but for the dual field tensor with no source term. I honestly don't think that this is "a pain". It is just about splitting the sum in ##\partial_\mu F^{\mu\nu}## into the temporal and spatial parts.
Orodruin said:
B^i = -\epsilon_{ijk}F^{ij}$$
See, I find even just writing down this theee vector right here tedious. I mean, I always worry about making a mistake while writing the components of ##\epsilon_{ijk}##.
But much less tedious than actually doing it in the three-vector formalism ...
It's actually possible to obtain the electric and magnetic fields from four-vector relations alone—no rank-2 tensors, no Ricci-calculus notation. Haven't seen anyone else do it this way, but it works, and I find it helpful. Your mileage may vary.
The "trick," if you want to call it that, is that the four-tensor expression ##(\partial^{\mu} A^{\nu} - \partial^{\nu} A^{\mu}) U_{\nu}## is "like" the "cross product" between ##\mathbf U## and the "curl" of ##\mathbf A##. I use scare quotes because there is no such thing as a cross product or curl of four-vectors (unless one tweaks some definitions, which some people do), but the analogy is perfect if you use the "bac - cab" expansion of the vector triple product.
Here's what I mean. With Feynman notation, we have the following three-vector identity:
## \mathbf a \times (\nabla \times \mathbf c) = \nabla_{\mathbf c} (\mathbf a \cdot \mathbf c) - (\mathbf a \cdot \nabla) \mathbf c ##.
The analogy I'm drawing is with the right side of that expression:
## (\partial^{\mu} A^{\nu} - \partial^{\nu} A^{\mu}) U_{\nu} = \vec \partial_{\mathbf A} ( \mathbf U \cdot \mathbf A ) - ( \mathbf U \cdot \vec \partial ) \mathbf A ##,
where ##\vec \partial = (\partial^t, - \nabla) ## is the four-del operator (sorry for mixing arrow notation in there—emboldening ##\partial## doesn't work).
So the Lorentz four-force can be notated like this (##c = 1##):
##\mathbf F = q \left( \vec \partial_{\mathbf A} ( \mathbf U \cdot \mathbf A ) - ( \mathbf U \cdot \vec \partial ) \mathbf A \right) ##,
where ##\mathbf U = (U^t, \mathbf{u} )## is the four-velocity of the test charge and ##\mathbf A = (A^t, \mathbf{a})## is the four-potential. (And the Feynman notation here is extraneous superfluous [edited], since the particle's four-velocity has no dependence on four-position anyway.) If you write that in "1 + 3" component form, after some work (including the three-vector "bac - cab" rule) you end up with:
##\mathbf F = q \left( \mathbf{u} \cdot (- \nabla A^t - \partial^t \mathbf{a}), \, U^t (-\nabla A^t - \partial^t \mathbf{a}) + \mathbf{u} \times (\nabla \times \mathbf{a}) \right)##.
Then define the three-vector fields ##\mathbf e## and ##\mathbf b## to simplify that:
##\mathbf F = q \left( \mathbf{u} \cdot \mathbf{e}, \, U^t \mathbf{e} + \mathbf{u} \times \mathbf{b} \right)##.
Yes, but both ##\vec \partial (\mathbf U \cdot \mathbf A)## and ##(\mathbf U \cdot \vec \partial) \mathbf A## are four-vectors. I'm saying that you can start with the Lorentz four-force written in terms of them, without bringing the Faraday tensor into the picture at all.
My point is really that the Lorentz four-force is "like"
##\mathbf F = q \left( \mathbf U \times ( \vec \partial \times \mathbf A ) \right)##,
except that those individual operations involving ##\times## aren't defined (you've got to use the "bac - cab" rule).
Here, covariant electrodynamics (Lorenz gauge) with four-vector notation alone:
##\Box \mathbf A = \mathbf J##
##\mathbf F = q \left( \vec \partial (\mathbf U \cdot \mathbf A) - (\mathbf U \cdot \vec \partial) \mathbf A \right) ##.
Is all this entirely uninteresting? I don't know, I kind of like it. The d'Alembertian is like the Laplacian, and the second equation is like a vector triple product involving a curl. Ricci calculus is obviously incredibly powerful, but I'm just a hobbyist, and vector notation is far easier on my eyes and pea-brain.
Well, yes, it has to be. It is how the curl and the Laplace operator generalise to a 4D Lorentzian spacetime (i.e., the exterior derivative of a one-form and just the trace when the gradient is taken twice).
I don't see what is wrong with ##F = dA## and ##d*F = *J## from that perspective - if removing indices is what you are after.
Sure, the exterior algebra stuff is clearly superior... if you're comfortable with it. :wink:
