Do photons experience zero time between emission and absorption?
  • Level: High School
  • Thread starter Thread starter spacecadet2563
15 replies · 3K views
spacecadet2563
Not a great question but I heard someone say that time does not move for a photon. T=0.
So therefore both its Emission &Absorption are simultaneous events. I say no. If both of these events are supposed to be considered different events than there would need to be a time interval between them. Is that correct? Thanks for responses. I will have to think about the previous ones...no way
"Proper time" does not exist for the photon.
However, there must be a sense of causality,
The Emission-event occurs before the Absorption-event.
They are distinct-events with a nonzero-displacement-4-vector, even though that displacement vector is lightlike (null, has square-magnitude zero).
No. The time experienced along a null path is not zero, rather it is not defined.
No. Or, more precisely, you need to define whether you are talking about the interval along the path between two distinct events (which may be zero, but isn't "time" in that case) or the coordinate time somebody defines, which will be non-zero between emission and absorbtion events.
These two concepts are distinct in relativity but not in Newtonian physics. Failing to grasp this is one reason people end up with contradictory ideas about relatvity.
I don't think there's any simple way to describe how a photon moves. It is not at all like a regular missile.
The information that is involved in it's trajectory comes from a much wider region than you would expect.
Consider this Mach-Zehnder interferometer experiment:
1) Each photon reaches the first half-silvered mirror and effectively follows both paths.
2) Using mirrors, the photon paths are rejoined at another half-silver mirror where an interference pattern forms.
3) In parts of that pattern, destructive interference keeps photons from reaching those parts.
4) Now block one of the two paths ...
5) Photons will now reach those previous dark zones.
The photons that light those zones are photons that did not encounter the block. But because they could have, they were able to reach the dark zone.
It's called a counterfactual - something that didn't happen but affected the final outcome because it could have.
I say no.
For future reference:
PF does not allow personal theories. PF supports established, peer-reviewed standard model science.
That does not mean you have to know everything about current established, peer-reviewed standard model science; it simply means you have to not declare it's wrong.
If you do not like what our standard model of physics says about things like spacetime and relativity, it is not appropriate here to describe your own personal ideas. The appropriate thing to do is to ask where you are misunderstanding our current models.
This is the PF way.
This is the PF way.
Never declaring anything wrong.
There are two types of time in relativity: proper time and coordinate time. This statement is not true for either.
Indeed, emission and absorption are not simultaneous events. This statement is a statement about coordinate time since the proper time between emission and absorption is not defined.
Yes, there is an interval of coordinate time between emission and absorption.
I say no.
It would be better to just read what physics does say about photons, than to you make your own assertions.
If you want to simulate what a photon does, then at the moment that the "emission" occurs, you need to capture all the information about what that photon can encounter in every possible direction it could be following. So, using that Mach-Zehnder interferometer experiment I mentioned before, what is important is not whether the block was there at the moment of emission, but whether it would be there when the photon would reach that point in any of its potential trajectories.
It's as if: 1) all of that information is collected at the moment of emission; 2) the interference pattern is calculated; and 3) a random destination is picked weighted by the values in the interference pattern.
But, in all cases, the absorption will occur an amount of time after the emission that is determined by the time it takes light to follow that randomly selected path.
Part of @Dale response to you (@spacecadet2563 ) was this:
In light of @Dale's statement, let's consider the speed of neutrinos. It was originally thought that neutrinos were massless and that they therefore must travel at the speed of light. But, about 25 years ago, experiments by Takaaki Kajita and Arthur B. McDonald showed that neutrinos change during flight. They "oscillate" among their three possible neutrino flavors as they cruise through the universe. Well, they can't do that without proper time. Proper time must be defined for them - and holding to the commonly held presumption that they are not interacting with anything in flight, that would mean those neutrinos must have non-zero mass.
So the fact that photons have no proper time is a more significant statement than it might first appear. It means that photons can't change in flight. The end result is as if they follow those superposition of paths and ultimately land on some select destination - but that entire process isn't an evolution of the photon - it is just a single emission/absorption process.
I would guess that if someone said that "time does not move for a photon", they were likely alluding to this characteristic of massless particles. But as you can see, it's really not that simple. And trying to describe it is also not simple because our language is tuned for describing how classical objects move through Newtonian space and time.
Its all really one event not two would be a safe assumption.
Event has a technical meaning in relativity. It is not one event, but it is one process that does not involve an evolution of the photon itself.
The proper time for a photon is considered ##\tau = 0##, but most people would say that is not defined, because, apparently, it involve infinity which would cause the math to collapse. But the math is simple: as the velocity approaches speed of light
$$\lim_{v \to c^-} \gamma = \infty$$
$$\lim_{v \to c^-} \tau = \lim_{v \to c^-} \frac{\Delta t_0}{\gamma} = 0$$
$$\lim_{v \to c^-} L' = \lim_{v \to c^-} \frac{L_0}{\gamma} = 0$$
The limit ##\displaystyle \lim_{v \to c^-} \tau = 0## does not mean that light is "stopping" or having no duration because in reality it never reaches zero (goes towards zero infinitely, but never reaches it). Consider this: The same photon leave the Sun, after about 8 minutes reaches Earth, and later Jupiter. The photon can't reach Earth and Jupiter in exactly the same moment. Obviously, the emission and absorption can't be the same.
You failed to specify from whose frame of reference. They only can't say that for a FoR that is less than c wrt Earth/Jupiter.
That does not, in itself, rule out the photon's case.
In everyone's case the story is the same: the photon is emitted, then reaches Earth, then absorbed on Jupiter... All the observers use the same Lorentz transformation equation.
Yanni said:
The proper time for a photon is considered τ=0, but most people would say that is not defined, because, apparently, it involve infinity which would cause the math to collapse.
Whether or not something is defined is a matter of definition. We choose the definitions for our convenience. There are two reasons that restricting the definition of proper time to timelike worldlines is convenient:
1) we can then say that proper time is the time measured by a clock. This gives proper time a clear operational meaning.
2) we can then say that proper time is an affine parameter. With respect to pulses of light, this is the more important one because it reminds you that even though light-like paths do not have proper time they do have affine parameters.
The affine parameter for a lightlike path makes it clear that the various events on the worldline of a pulse of light are not the same event. So the second reason is particularly relevant to discussions like this one.
None of these limits are relevant to lght. They are limits as you apply Lorentz transformations to timelike vectors, but light is not described by a timelike vector, it's described by a null vector. The operation of Lorentz transformations on null vectors is fundamentally different from their operation on timelike vectors: they hyperbolically rotate timelike vectors, but they dilate null vectors. So you can't say anything useful about null vectors by taking limits of things that apply to timelike vectors.
This is not correct. Such a statement would only be correct for a timelike worldline, not a null worldline.
