Do Photons Produce Gravitational Fields?
26 replies · 5K views
blaksheep423
Do photons produce gravitational fields, even though they are massless? In other words, can a photon's gravity affect other photons or elementary particles?
Well in General Relativity, energy/momentum cause spacetime to curve, and photons have energy/momentum, so yes you can say that photons produce gravitational fields.
ok, then the next question I've been wondering about is this:
if gravity propagates at c, and photons move at the exact same velocity, could a photon traveling in a straight line be constantly affected by it's own gravity at any single point? if so, wouldn't the gravity of each point of the photon's path add up continuously, causing a "gravity boom" (which, as the curvature of spacetime keeps adding up, would in effect be a black hole), for lack of a better term?
on the other hand, since I've never heard of this happening, wouldn't gravity have to propagate at either a speed less than c, or greater than c, to prevent this from happening?
please let me know if i am phrasing this in an unclear way.
Only if the photon were emitting gravitytional waves - which it can't, as it cannot change with time.
Do photons accelerate in the weak-field approximation when their path is bent by a massive body? If so why wouldn't this result in gravitational waves?
Ich said:
Only if the photon were emitting gravitational waves - which it can't, as it cannot change with time.
Would a single electron emit http://en.wikipedia.org/wiki/Cherenkov_radiation" if it moves exactly at the speed of light in the surrounding medium? Is this a valid analogy to a photon causing a "gravity boom"?
Also: Wouldn't the gravitational field of a photon be Lorentz-contracted to zero along the movement direction and eventually cancel out?
Hey, I'm not on solid ground here. I mean, a sonic or cerenkov boom is indeed the addition of something generated by the respective particle. The particle does work. I can't see how a photon could generate something, as no proper time passes.
I dont't say that there are no discontinuities in the "field ofa photon", but they come from its point-like nature in this classical particle view. Maybe something more realistic can be learned from http://en.wikipedia.org/wiki/Monochromatic_electromagnetic_plane_wave" . Or maybe others have something more specific to say.
Excellent question. From much hated, but always right anthropic principle answer is obviously that such thing can not happen. From theoretical grounds it should be looked at quantum level, but on the other hand we don't know gravity on the quantum level. My answer for short: I really don't know, I would be glad to learn.
Well put, S. Vasojevic. It obviously doesn't happen. And I don't know nearly enough about quantum mechanics (or, to be honest, relativity. I am merely a physics undergrad) to try and comprehend what prevents this. It's just a question I couldn't answer myself and couldn't find an answer to.
So, of the myriad of possible solutions to this problem, most of which are well beyond my comprehension, could a potential answer be that gravity does not propagate at light speed? From what I've learned about it so far, there has never been any evidence or theory in which gravity propagates slower than light. I also know that the speed of gravity has been experimentally verified to within 1% of c.
Does anyone know if it is necessary in the Standard Model for gravity to propagate at c? Also, can anyone think of another solution to the gravity boom?
No. The power emitted by Cerenkov radiation goes as: [tex]\left(1 - \frac{1}{\beta^2_{med}}\right)[/tex]
which is clearly zero if it moves moves exactly at the speed of light in the surrounding medium.
Hard to say, as there is no power radiated in the EM case. Zero is zero.
A photon bends spacetime. It does not, by itself, emit gravitational radiation, although it might be part of a system that does.
So if a photon does not emit gravitational radiation, is this the reason that a "gravity boom" does not happen?
"Gravity boom" appears to be your own creation. It's difficult to discuss such a thing.
So a photon whose path was bent by a gravitational source, or which could even be in orbit around a black hole, would not emit gravitational radiation? But a massive object orbiting or having its path bent by a gravitational source would emit gravitational radiation, correct?
No single particle can emit gravitational radiation. You need a changing gravitational quadrupole moment, and that means you need multiple particles.
If you had a point particle orbiting a large gravitational source, could the combined system emit gravitational waves even if the point particle's mass was negligible compared to the source, so that the source itself was not being affected in any appreciable way by the point particle?
There is no quantum theory of gravity, so strictly speaking it is not really possible to answer the OP's question. However the spacetime for a brief and intense pulse of light is given by the Aichelburg–Sexl ultraboost. There is no gravity boom or event horizon.
if gravity propagates at c, and photons move at the exact same velocity, could a photon traveling in a straight line be constantly affected by it's own gravity at any single point? if so, wouldn't the gravity of each point of the photon's path add up continuously, causing a "gravity boom" ...
This is one of the most excellent questions I've seen posted on Physics Forum. Questions like this are inspiring, and take us out of our comfort zones where we think we understand things.
Take your question and ask about pulsed lasers instead. With this, there is a particle-like region that is not a massive particle. Since it's light and not a 'massive particle' it doesn't bend space like electrons, protons, and atoms 'n stuff. Massive particles travel less than the speed of light. All massless particles travel at the speed of light.
For massive particles there couldn't be a shock wave like built-up gravity waves, what you call a 'gravity boom'. This is known because some very complicated mathematical derivations of general relativity about massive particles in motion. Light is not massive so we need someone who has some idea of how light bends space and time to answer this. That's not me!
Anyone?
Edit: I hadn't read your post, Dale.
Wikipedia: "In general relativity, the Aichelburg-Sexl ultraboost is an exact solution which models the physical experience of an observer moving past a spherically symmetric gravitating object at nearly the speed of light."
I'm not sure this counts?? The object is massive so has a different stress-energy tensor...
Why do you say it doesn't bend space? Anything with energy should contribute to the curvature of spacetime, no?
edit: this thread has a short discussion of how light can curve spacetime...
But I didn't sat that... Or didn't mean to. Light doesn't bend space and time the same as massive particles. Good of you to bring it up.
My mistake, when you said "it doesn't bend space like electrons, protons, and atoms 'n stuff" I thought you were saying it was unlike those other particles in that it didn't bend space, but I guess you were saying it bends space in a different manner than massive particles (I should have noticed that you went on to say 'Light is not massive so we need someone who has some idea of how light bends space and time to answer this').
No problem. I wasn't concise enough. Just off hand, I might guess that 'accelerating' light might produce a shock wave. Light doesn't accelerate in vacuum but it might when running into a medium Also, what if the obsever were accelerating instead?
If you look into it a little more the Wikipedia description is actually an incorrect description of the AS Ultraboost, which is why I did not post a link to it:
First, the spherically symmetric gravitating object is not moving at "nearly" the speed of light, but actually at the speed of light. This is not possible for a massive object but is possible for light. Second, there is no event horizon which is different from the spacetime for spherically symmetric massive objects, but is correct for light. Third, the AS Ultraboost is one of a general class of solutions to the EFE called pp-waves all of which model radiation moving at the speed of light.
To be fair to Wikipedia, they are not the only ones who say that, but it is incorrect when you look into the details. Of course to a first-order approximation it is good as long as the mass is really close to c and far from the event horizon.
Wikipedia reference a technical (published in Phys. Rev. D) arXiv paper by accepted experst
http://arxiv.org/abs/gr-qc/9809003.
The authors of this paper have written a book, Exact Space-Times in Einstein's General Relativity,
https://www.amazon.com/dp/0521889278/?tag=pfamazon01-20
scheduled to be released in a month. Chapter 20, Impulsive waves, probably covers this material a little more pedagogically (but still very technically).
Thanks, Dale.
Dr Ronal Mallett might be able to explain that to you since he is basing his time machine on the theory that light can create gravity and bend space time. Try contacting him on myspace.
