Does a photon have dynamic mass from E=hv/c²?
  • Level: Undergrad
  • Thread starter Thread starter DonnieD
    Dynamic Mass Photon
76 replies · 20K views
pmb_phy said:
My I ask why? The reason it is used goes far beyond what you'll find in your intro to SR/GR classes.
Pete
Because relativistic mass is not necessary in teaching relativity.
The worst thing it does, is that it brings about the notion "photons do not have rest mass but they have relativistic mass" resulting into never ending discussions that lead nowhere.
pervect said:
The case of a heavy absorber is discussed in Taylor & Wheeler. It's not terribly hard to show that in the limit of a large mass of the absorber (m_absorber >> E/c^2, where E is the energy of the photon) that the amount of momeuntum gained by the absorber from the photon is negligible.
Consider a 400nm photon, at the upper edge of the visible spectrum. It will have an energy of about 5e-19 joules, and a momentum of 1.6e-27 kg-m/sec
If it impacts a 1 gm absorber, the absorber will move at a velocity of 1.6e-24 m/s to conserve momentum. The kinetic energy due to its motion will be negligible (about 1e-51 joules). So most of the energy of the photon goes in heating up the absorber, i.e. virtually all of the 5e-19 joules gets turned into heat.
The conservation of energy and momentum then tells us the energy, E, and momentum, p of the absorber
E = (9e13 joules + 5e-19 joules)
pc = (5e-19 joules)
We can then compute the mass sqrt(E^2 - (pc)^2)/c^2, and verify using standard series approximations that it increases by essentially 5e-19/c^2 grams due to the absorption of the photon, just as Taylor & Wheeler state.
The effect of the (pc)^2 term on the mass is negligible
Yes, we are in total agreement on this.
I think your observation that gravity causes the photons to travel in non-straight paths is interesting, but it doesn't affect the textbook answer.
Your observation is more of an illustration of how the system weighs more in a gravitational field. One does expect a heavier object to weigh more than a lighter object, and your analysis illustrates how that happens. But we don't even need to refer to a "gravitational field" to work the problem - in fact, it is easier if we do not, if we simply stick with the standard textbook definition of invariant mass.
Actually, the situation is more complicated (and more interesting) , please see my answer to JustinL. I believe that we need to go thru the slightly more complicated calculations if we want an exact quantitative result.
What tools are necessary in teaching is what may help the student in his work. Relativistic mass provides a good tool for that given all the applications it can provide and ways of looking at a problem that is difficult to look at in another way. For example; Suppose someone asked you what the center of mass of a system of particles is. You may have a hard time doing that so you might just do away with the question altogether and say that the center of mass is meaningless and has no use whereas the center of energy does have meaning. That would be a very weak argument. But other physicists (e.g. Rindler) had no difficulty with this problem. They simply use the regular formula replacing rest mass with inertial mass. That is but one example. Now suppose that there is a particle in a static gravitational field. The particle will have constant energy. But it won't be given by E = mc2 (were m is inertial mass). m would be P^0 whereas energy would be P_0. The list goes on.
Let me ask you this - How would you define the mass density of an ideal gas?
Pete
Pete
Here is an http://www.owlnet.rice.edu/~jigarb/density.htm as good as any.
This is getting interesting, let's see where it leads.
pmb_phy said:
Can you fill me in and explain what an "equivication fallacy" is and how I supposedly "changed" the meaning of both momentum and energy.
You switched from ordinary momentum to the generalized momentum that includes a stress term, and likewise, you added a stress term to the energy that was being considered.
AFAIK, nobody has ever argued that E/c²=m if you mix in a few new energy terms and pass to some notion of generalized relativistic mass.
As an aside, it may be possible that generalized relativistic mass becomes a useful notion -- if you agree, then it would be nice to see a precise definition and an example of it actually being useful. For 3-vectors, p = mv can almost never be true for generalized momentum (and velocity might even become difficult to define, depending on the situation), so I'm highly skeptical that generalized relativistic mass is useful.
ps - The term "equivocal" means "subject to two or more interpretations and usually used to mislead or confuse". If you are saying that I'm intentionally try to mislead people
I didn't mean to imply it was intentional: I simply meant I thought it was happening.
That is not a change in definition. I was explaining what the general formula for momentum was and that reduces to what you call the "ordinary" momentum for a single particle. There was no switching going on. I was filling in where I believed tjere was a hole.
AFAIK, nobody has ever argued that E/c²=m if you mix in a few new energy terms and pass to some notion generalized relativistic mass.
Have you ever seen anyone every discuss such a situation using the most general form of mass there is at all?
What I call useful I'm sure you will have another idea of what is useful. I call "useful" that which gives the correct answer for any legitimate question in relativity. Because nobody uses it in practive today cannot be taken as any form of proof that it won't be used 300 years from now. But I did give an example of a stressed rod many times in the past. To see that derivation please take a look at the web page I created specifically for this purpose.
http://www.geocities.com/physics_world/sr/inertial_energy_vs_mass.htm
There is also an article in the Am. J. Phys. Called "The inertia of stress" which you might want to look at if you have access to this journal.
Skeptical? You seemed to be saying earlier in this thread that you were 100% sure that generalized relativistic mass is useful. And there is no reason to keep referring to it as "generalized relativistic mass" since the term has a ring to it as if it was special in some sense whereas the cases like a free partilce is actually a special case.
The term you used has that meaning. I recommend that you just say what you mean instead of using glossy language.
Best wishes
Pete
you say that, but you don't support it.
I myself don;t like getting into these discussions on mass so I think it is best for me to agree to disagree with those opposed to inertial mass (aka relativistic mass) and whomever wishes to talk to me about it can PM me.
Kind regards all
Pete
My $.02 - now that we've hopefully resolved the basic issues we can talk about some of the more advanced issues.
Inertial mass is actually a second rank tensor, as Hurkyl points out.
Relativistic mass is usually understood to be a scalar quantity, another name for energy (so it is not the same as inertial mass.) Pete's usage in this area is IMO non-standard, and causes a lot of confusion.
Invariant mass is also a scalar - it is the invariant length of the energy-momentum 4-vector for a point particle - or the invariant length of the energy momentum 4-vector for a system with a finite volume.
Interestingly enough, the total energy-momentum of a non-isolated system with finite volume does not transform as a 4-vector. This is behind some of what Pete is (IMO) trying to say.
If one reads Taylor & Wheeler, "Spacetime physics" closely, for instance, one will see that they are always careful to say that the mass of an isolated system is a Lorentz invariant, not that the mass of any arbitrary system is Lorentz invariant.
How does one deal with relativistic systems with a finite volume? Via the stress-energy tensor, which always transforms properly (i.e. covariantly) as a rank 2 tensor.
Given a particular frame of reference, the total energy in a given volume can be expressed as the integral of T_00, and the components of the momentum can be expressed as integrals of T_0i.
Given these volume integrals for the total energy E and mass p in some volume V in special relativity, the mass contained within a volume can be (and as far as I can tell from a close reading of the textbooks) is defined in special relativity as sqrt(E^2 - (pc)^2) / c^2, in spite of the fact that the above quantity is not always Lorentz invariant.
(I haven't seen any textbook specifically say that the mass of a non-isolated system is defined in this manner - rather, the above formula is offered as a general definition of mass, and the comment is made additionally that the above quantity is an invariant for isolated systems. I believe it is correct to say that the quantity is still defined for non-isolated systems, but is not invariant).
In other words, in spite of the name, the "invariant mass" of a system is actually an invariant only if the system has zero volume, or if the system is isolated.
For one source for this in the literature, see http://arxiv.org/abs/physics/0505004 or the peer-reviewed
http://www.springerlink.com/content/534j31t61675w010/
by the same author.
nakurusil said:
Correct, it is good to see that you finally understood the problem statement.
My point was (go back and read the post) that for this particular case the approach works.
No, you previously very clearly stated that the mass did not increase. In suddenly changing your opinion now you are trying to make it sound like you always claimed it did increase. And on top of that, condescendingly implying that I was the one claiming the invarient mass didn't increase and you proved me wrong... a complete switch-a-roo. It is because of attitude like this that it was easy to tell you were a sockpuppet of the banned clj4.
Everyone makes mistakes, but unless we can admit to ourselves that we've made a mistake, we can't learn from them. I hope you can take this with you in the future and I wish you well.
While the discussion is now ended, I would still like to help you learn the results here as you are still misunderstanding some pieces.
nakurusil said:
As such, m'>m, m'=m or ... m'<m !
Surprise, surprise, the photon doesn't always add to the invariant mass of the system!
That is incorrect. The simple solution given before is general. You can translate to any inertial frame and the photon will still be there. So translate to the rest frame of the box, and calculate the result of adding the photon in that frame. The result as shown previously is that the invarient mass increases. Always.
nakurusil said:
3. It is a bad idea to use thought experiments in the style "photon in the box", which give variable results depending on initial and final conditions, depending on momentum directions in order to prove that "photons can contribute to the invariant mass of a system". Because sometimes they don't add any mass and other times they even subtract, thus making the whole issue muddled.
No, add a photon to a closed system and it will always increase the invarient mass. Please, please take the time to think this through so you can gain something from this discussion.
nakurusil said:
I have expunged "relativistic mass" and "photon contribution the the invariant mass of a system " from my course notes and I am very happy with the results.
I somehow doubt such course notes exist. Assuming you are indeed clj4, who admitting he is Adrian Sfarti when I mentioned I believed Sfarti's papers would get rejected from inclusion in last year's Grossmann Meeting on General Relativity published conference proceedings, then the only record I could find of you ever teaching was as a guest lecturer in a CS course.
If I am wrong, feel free to email me (bj0umow02@sneakemail.com) and I appologize in advance.
Also, I appologize about my comments on Sfarti's papers as there was no way for me to know you were him at the time. Actually, it is usually rare for presented material to be withheld from conference proceedings, so they probably will go through fine. It is too time consuming to adequately peer-review conference proceedings, but if they do make comments on your papers, I hope you take them to heart and stop believing that you are defending the mainstream view against a sea of "crackpots" even though many people have taken time to help point out how your arguments actually conflict with current mainstream theory. People aren't "out to get you", they are trying to help you learn.
I wish you good luck in your endeavors and hope you never lose the thirst for learning.
Returning to the original topic, there was a question I had that got buried earlier:
Going back to the hollowed mirror sphere example pervect brought up, the photons add an energy density inside, but also apply pressure on the walls of the sphere which would strain the sphere. Is there someway to show how this pressure/strain would add to the inertial mass of the sphere, or would that somehow be double counting the effect of the photons?
Requiring one to write "rest mass" instead of "mass" has the benefit of added precision and the drawback of being more cumbersome. I define this requirement to be useful iff the benefit outweighs the drawbacks.
When I talk about the "usefulness" of relativistic mass in this context, I mean in the above sense: does the notion of relativistic mass have sufficient utility to justify encumbering the notion of rest mass?
Er, I did. Equivocation is one of the standard logical fallacies.
I talk about this in an arrticle I wrote for the wikipedia. (For those who care about such things, I need to point out that this should only be considered to be wikipedian reviewed and not peer reviewed).
http://en.wikipedia.org/wiki/Mass_i...simple_examples_of_mass_in_general_relativity
If you consider the simplest case of an isolated sphere, the tension terms in the walls of the sphere are exactly counterbalanced by the pressure terms in the interior of the sphere, and they make no net contribution to the Komar mass of the sphere + photons.
So if you have an empty sphere, and add photons to it, the mass of the system of sphere + photons increases by E/c^2, where E is the energy of the photons you added to the sphere.
I don't think I go into all the gory details, see for instance http://www.efunda.com/formulae/solid_mechanics/mat_mechanics/pressure_vessel.cfm for how to compute the stresses in a sphere.
Also note that one particular type of mass from general (and not special) relativity is being used in this calculation, a type of mass known as Komar mass.
GR does not have a single, general definition of mass, but has several different definitions that apply under different circumstances.
The Komar mass formula is one of the simplest, and applies to any static system, such as our mirrored sphere. (Actually, with enough care, the Komar formula can also be applied to stationary systems, like rotating spheres or Kerr black holes, but some of the details get a bit more complex).
It should be noted here that we are using the Komar formula, and that for the isolated sphere it gives the same answer for mass as the special relativistic formula.
The simpler special relativistic formula could actually be used here - note that for the isolated system of sphere + photons it gives the same answer. Note also that the SR formula does NOT have any pressure terms - there are only momentum and energy terms in the SR formula.
It greatly simplifies things to consider the mass only of an isolated system - you can get numbers for the mass of a non-isolated system, but you should realize that they are coordinate dependent.
pmb_phy said:
That is not a change in definition. I was explaining what the general formula for momentum was and that reduces to what you call the "ordinary" momentum for a single particle. [..] There is also an article in the Am. J. Phys. Called "The inertia of stress" [..] And there is no reason to keep referring to it as "generalized relativistic mass"
Regardless of whether Pete's "generalisation" is reasonable, it is distinct from the usual concept of relativistic mass. (And why haste to sacrifice the niceties of that mass concept, except to use invariant mass instead?)
That article considers some material that is painted with electric charge. The article basically presumes the total relativistic mass of the system to be (naturally) the relativistic mass of the material ([itex]m_r[/itex]) plus the mass-energy required to pull the electric charge distribution onto place. The total energy/momentum result by multiplying that with [itex]c^2[/itex] or with its velocity.
Then the article claims* to demonstrate obtaining the same results by calculating the momentum as "[itex]m_r[/itex]v + stress momentum + field momentum (E x B)" and the energy as "[itex]m_r c^2[/itex] + stress energy + field energy ([itex]E^2 + B^2[/itex])". (In this sense the article concludes that there is inertia in stress, as in mass and in classical EM fields).
Now, Pete seems to be asserting that (when we consider individual components of this system) the stress term should be associated with the intervening material (rather than with the external charge distribution applying the forces.. which is presumably ascribed only the field's energy/momentum). It isn't shown whether or not the intervening material actually behaves as having increased inertia physically.
*The technicalities seem a bit odd, I'll look into the references a little - the whole stress thing seems like a hack to avoid a paradox which other authors claim never existed..
Modern authors over the last 40 years seemed to have left this part of relativity out of there texts for the most part. The only one that comes to mind is Rindlers 1982 intro to SR text. It appears that new students wouldn't touch a book that was written before they were born, supposeldy they believe that they can't learn anything from them that they can from a newer text. But such texts by, say, Moller are a gem of a textbook. I myself haven't even gotten to read Moller but that's due to a lack of access and a lack of $.
Pete
Pete
Apparently, this is Moller's text:
http://www.archive.org/details/theoryofrelativi029229mbp
(Off main topic:
Recently, I've been interested in old pre-1925 relativity books, especially those pre-GR books. It's interesting and inspiring to see the physical, mathematical, philosophical, and pedagogical approaches taken to understand relativity back then. And it certainly is possible that some idea or technique which has not been continued in the modern textbooks can be useful for pedagogy or even cutting edge research.
One of the most interesting are the works of A.A. Robb, starting with his 1911 book "Optical geometry of Motion" http://www.archive.org/details/opticalgeometryo00robbrich
which (I think) was the first to use the word "rapidity" (for the Minkowskian analogue of angle) and has the foundations of the Bondi k-calculus and the beautiful but not well-known formula for the interval between a local event and a distant one in terms of three clock readings from a radar experiment [as featured in texts by Synge, Geroch, and Burke]. Some of his other books: http://www.archive.org/search.php?query=robb AND (geometry OR relativity) suggest that he was one of the first to emphasize the causal order... in fact, recovering practically all of the structure of Minkowski spacetime from the causal order... in a methodical but tortuous way.
More from archive.org: http://www.archive.org/search.php?query=subject:Relativity. Enjoy.
Thanks for that insightful opinion Rob!
There was some comments before about a gas of massless photons which had mass itself and the weight of a box of such a gas. There was an article published on this topic
The mass of a gas of massless photons, H. Kolbenstvedt, Am. J. Phys. 63(1), January 1995
I have this one and am in the process of placing my journal files on CD. Since this one was already scanned and on disk I thought I'd post it. Its a very interesting read! :smile:
http://www.geocities.com/physics_world/Kolbenstvedt_1995.pdf
Best wishes and enjoy
Pete
