Does a smaller or larger pool cue tip generate more spin?
  • Level: High School
  • Thread starter Thread starter adr147
67 replies · 14K views · last reply
adr147
ok - a question for you boffins out there!
playing snooker / pool, will a smaller or larger tip generate more spin?
logic tells me that the point of contact is larger on a larger tip but that the time in contact with the white is greater with a smaller tip. which matters more? (i know as a player the answer is the smaller tip but i would like to know why!)
Welcome to PF, Adr. I used to use an 11mm tip for years, and was irritated that my new stick was available only with 12 or 13. A couple of my more professional friends (one's a ref; one an instructor) insisted that a larger tip was better. Now that I'm used to my 12, I tend to agree. I can see the logic of it. For a given amount of offset on the cue ball, there is more of the tip in contact, as you mentioned. The duration of that contact has nothing to do with the tip size; it's all in the stroke. Of far more importance is the material of the tip. You'll get the most grab from a very soft one, but they don't last very long. A hard one can last a couple of seasons, but doesn't hold chalk very well and can tend to skid off of the ball. Most of us around here use Elkmaster medium hardness, which is a really good compromise.
Theoretically, it doesn't depend on how large the tip is. Because spinning depends on the friction force, the friction force in turn depends only on the tip's roughness, not its area.
for american pool 12mm would be my choice (talisman soft not an elkmaster!) - i am aware of the materials issue etc and have to say i play to a high standard and sell the equipment for a living but given the following were the case which would generate more spin?
the cues are identical
the distance the cue travels through the shot is the same
and its speed and angle are also identical
so the only variable is the tip size and shape. (a smaller tip by its nature will be more rounded)
so its the same, but we find it easier with a smaller tip? - the firmness of the tip makes a big difference the softer the tip the easier it is to generate spin.
I said theoretically.
You are right when saying the softer the tip, the better, because that softness plays a buffer role for the tip to 'grip' better to the ball. So may be the smaller tip is a little bit softer and that answers your question.
I beg to differ. The contact area does affect the friction force. Obviously, every mm^2 has a certain amount of friction. The more mm^2, the more friction.
edit: You guys slipped in a couple of extra posts while I was composing this. I've never heard of Talisman; where are you, Adr?
so assuming the tips are of the same hardness where are we now! - my physics is not up to this but i KNOW from playing its easier with a smaller tip.
No, I don't think so. Friction force = Force*C (C is the dynamic friction constant). The force here depends on how strongly you push the ball and the ball's weight.
i am in scotland - you?
all other factors remain constant, cue ball weight etc.
I am in the Netherlands. I just play snooker now and then and not good enough to see the difference in tip size.
If you say all other factors remain constant, I should say the softer the tip, the better because logically, it is softer and then easier to grab the cue.
but we need to assume that the hardness of both sizes is the same.
So again, they are the same theoretically. Just one thing I can guess : the smaller the tip, the better for the player to hit exactly at the point he wants. And that is the advantage.
this was my thought but i am not sure the physics prove it.
does tip thickness have any relation to weight class of the cue?
It could also be a psychological thing...some epeople feel more comfortable with the aim of a smaller cue..OThers like putting more power with a thicker cue.
May also be dependent on the ball size, since if i remmeber correctly snooker plays with a smaller radius on the ball.
The physics is just above: dynamic friction force does not depend on the surface area.
And with smaller tip, surely you can have more points on the cue to hit (this may not be physics).
again we would have to say they tips have the same thickness although in reality that's not likely and i suppose you would automatically make the smaller tip softer if it were the same thickness.
its definitely easier to aim at the point you need so mentallly that's a done deal.
a snooker ball is 2.25" so yes its smaller - as are the pockets but the table is a lot bigger!
another thought - the smaller tip is in contact with the cue ball for longer as you push through the shot so has less of a 'slapping' effect on the cue ball?
I have to leave for work now; I'll log back in when I get there (unless some damned client shows up). In the meantime, I'm in Canada, near Calgary. From my personal experience, I find a larger tip to be better in this matter. I was about to mention the aiming aspect before you guys beat me to it. I can't do that 'line your chin up with the cue' crap; I sight down the cue like a rifle. It was indeed my problem in switching to a wider tip that it took a while to extrapolate the edge contact as referenced from the centreline of the stick. I had the same problem when we switched from using an oversize cueball to one that's the same size as the object balls. Be back in a bit.
lol - i think we will not get to the bottom of this there are too many variables.
That is entirely possible. All that I can say is that from personal experience, I can get a lot more juice on the ball with the 12 than I could with the 11. Tip thickness and hardness are identical. (Some idiot sold me a diamond tip rather than a medium once, and it literally wore out my shaper while I was trying to scuff it up enough to hold chalk. )
LOL - TRY A TALISMAN BUFFALO IN HARD GRADE ITS LIKE GLUEING HALF A MARBLE TO YOUR CUE!
Danger said:
No, thanks. :bugeye:
lol very wise - or just remove the tip altogether and shape the end of the cue it would have a similar effect!
All the comments about tip size itself are ok but the main issue is that for thinner and more flexible shafts you get a whipping action which increases the amount of spin you put on the cue ball. So it is not just a property of the diameter but also the materials used to make the shaft.
As far as frictional effects go, tip size is relatively unimportant. Just make sure the tip is soft enough, round enough, and well chalked to maintain good contact. Without considering shaft flex the "english" you obtain is purely a function of how far off center you strike the ball and how hard the ball is struck.
Flex does two things, it increases the contact time and it allows the tip to roll along with the ball so through part of the contact period the tip moves farther off center imparting spin more effectively.
Regards,
James Baugh,
P.S. I worked up a nice little analysis of the Masse shot. In the idealized case the angle that the ball turns off its initial pass is purely a function of where it is struck and how much down-angle you apply. I had a sudden inspiration while shooting and realized felt quality only matters with respect to how quickly the spin takes effect and not the degree of turn.
R.
J.B.
in snooker how hard you strike the ball will not change how much it spins - only cueing further through it will ?
Good post, Jambaugh. The only problem that I have with the 'whiplash' effect of a flexible shaft is that it also tends to slap the ball in the direction opposite to the imparted spin. That not only sends it in the wrong direction, but also increases the likelihood of a miscue. That's one reason that Predator cues (and to a lesser extent my Steel Stick) are designed to be rigid.
edit: Adr, you sneaked in again. The harder you hit the ball, the less effect the spin will have. Keep in mind that the ball always travels in the same direction that it's 'facing' before deflecting. The harder you hit it, the farther it goes before the spins kicks in. The same applies to an object ball after being struck by the cue ball.
edit#2: Okay, I've been at work for an hour, and nothing has happened. I'm going to close up for 10 minutes and go buy some beer for lunch. Back shortly.
edit#3: By the bye, I was going to mould myself a tip out of silicone sealant so that I'd never have to shape it or chalk it. Unfortunately, the regulations stipulate that it has to be 'leather or a leather-like material'.
ard147: Not quite correct. The harder you strike the ball the more spin but the ratio between "spin"=angular momentum and linear momentum will be the same.
Hence the effect of the spin with respect to the cue deflecting on a bank will be unchanged. In fact I think most effects will be functions only of this ratioL/P. Where it will make a difference is when you have dissipation of momentum due to rolling friction distinct from dissipation of angular momentum due to contact friction. These differences are too small to worry about excepting in certain very long shots and certain very short shots.
To Danger: Your point about the farther a ball goes before spin kicks in matters for draw and follow (an masse) but not for side-spin. Also I know a guy who fashoned a neoprene tip from a "superball". He said it gave him outstanding power on breaks but if I remember correctly he said it didn't affect spin as much... then again he isn't as well versed on the use of spin effects.
To All: I was looking for the file where I typed up the masse physics. If I find it I will post a link to it.
i hit further through the ball and lower down in order to generate more backspin and i can without hitting it any harder screw it back the full length of a snooker table.
you can buy tips made of rubber that need no chalk and last forever but they are sh!te!
Damn, but I am enjoying discussing this with fellow players!
I don't know whether or not there is a particular amount of curvature and/or reversal that determines whether or not a shot is a masse. I regularly curl the cue ball around another by using just side and bottom spin with my stick still as parallel to the table as I can get it. I always considered that to be a masse, and it definitely doesn't work if you strike hard.
As to the cue-off-of-the-bank scenario, the rail itself alters the trajectory. If you hit the cue ball into the rail at moderate power, it will rebound at approximately a mirror-image angle (assuming no side-spin). The harder you hit it, the less angle you get. The rail compresses under the impact, then springs outward to its normal shape. That pushes the ball at 90 degrees to the rail in addition to the normal rebound, so it actually underbanks.
edit: Dammit! Will you stop sneaking in while I'm composing? :biggrin:
The follow-through on any shot should be around 6"; the placement and angle determine the result. The execption to that is on the break shot, where you should be trying to put your stick through the rack. (Not in snooker, of course, but my primary game is Valley Rule/BCA 8-Ball.)
As for the rubber tips, however, the rules definitely still prohibit them.
