Mentor
- 37,280
- 16,415
Yes, I did. Post 29, second sentence.Raymond Potvin said:You did not say that the clocks were initially moving,
Sure, the best answer is @Ibix's answer $$\tau=\int_0^T\sqrt {1-v^2 (t)/c^2}dt $$Raymond Potvin said:If you can provide a better answer, please do.
With your method there is no way to solve it. The standard method works just fine.Raymond Potvin said:I'm afraid there is no way to solve that kind of problem
Note that the reason your method appears to work in specific cases is because since you are implicitly assuming v(0)=0 you can then use a(t) to determine v(t) which then allows you to use the standard formula. When v(0) is unknown then your approach fails, precisely because a(t) is not sufficient.
