Does an R2S turbocharger,2 stage turbocharger and twin turbo mean the same
  • Thread starter Thread starter monty37
    Mean Turbocharger
The discussion clarifies the distinctions between R2S turbochargers, 2-stage turbochargers, and twin turbos. A 2-stage turbocharger consists of two turbos arranged in series, typically a low-pressure (LP) and a high-pressure (HP) turbo, allowing for controlled bypass. Twin turbos can refer to either two separate single-stage turbos operating in parallel or two stages of turbocharging in series. The R2S turbo is identified as a compound turbo system, integrating two turbochargers into a single unit, contrasting with traditional setups that utilize separate units.
  • Understanding of turbocharger configurations
  • Familiarity with automotive engineering concepts
  • Knowledge of turbo lag and its impact on performance
  • Basic principles of forced induction systems
  • Research the mechanics of 2-stage turbocharging systems
  • Explore the differences between parallel and series turbo setups
  • Learn about compound turbocharger designs and their applications
  • Investigate the performance characteristics of BMW diesel twin turbo engines
Automotive engineers, performance tuners, and enthusiasts interested in advanced turbocharging technologies and their applications in modern engines.
monty37
does the r2s turbo , a 2 stage turbo and a twin turbo mean the same ...well my idea of a 2 stage turbo is that where compression of air takes place in 2 stages ..so does it consist of 2 compressors?
There is no standard nomenclature with this.
2 Stage turbocharging is fairly clear - There are two turbos an LP and a HP (in series). There will be some measure of bypass and control.
Twin turbo/biturbo can either mean 2 stages of turbo charging (series), or two separate single stage turbos (parallel).
can you elaborate when you say 2 separate 2ingle stage turbos i.e parallel?
Say on a V engine. You could have one large turbo feeding both banks, or Two identical turbos, one to feed each bank.
A good example of twin single stage turbo engines are BMW diesels. These feature a small turbo which prevents turbo lag at low engine RPM, along with a larger turbo for higher RPM
Physicist3 said:
A good example of twin single stage turbo engines are BMW diesels. These feature a small turbo which prevents turbo lag at low engine RPM, along with a larger turbo for higher RPM[/QU
when there are 2 turbo's ,they are 2 stage na ..how do you still call it twin single stage ?
The R2s is basically a "compound turbo" in a single package where typical compound turbo setups run two separate turbochargers.
Echo.
Saw one on the LeMans audi testing at the shuttle landing facility two weeks ago.
  • · Replies 18 ·
  • · Replies 20 ·
