Does Bouncing Increase the Impact Force Required in Collisions?
2 replies · 3K views · last reply
Judah
-An Egg Drop began at rest and fell through approximately 5-m. Assume that its momentum was changed in a time of 0.25-s. If your apparatus bounced when hitting the ground, would this require a smaller force than in #4, a larger force than in #4, or the same force as in #4? Explain….
-Note: My class is still on collisions: elastic, inelastic, and momentum/impulse therom
-The force from number 4 is 3.09 Newtons.
Mass of the apparatus is .078 kg.
Velocity final is 9.89 m/s.
What force is required for an object to bounce?
Does the force have to be larger than its weight?
Hi !
Can you show us your attempt for the problem ?
