Does Decoherence Von Neumann Interpretationrefute
92 replies · 17K views · last reply
Alfrez said:
Hmm... you are saying that in this earth, classical state is what we experienced while in other Many Worlds, they can experience a non-classical state that I won't be able to experience?
By shielding Einselection. I just want to experience a state of up-down simulataneously being up-down a legal quantum state.
Unless you are saying I can't experience both up-down state but only up or down one at a time? Hmm...
What we are experiencing is determined by how our brains work. We remember the past, not the future, because this is how information is stored in the direction where entropy increases.
We remember the past, but we are not able to percieve the 'other' braches. Hence, in the tree of all possible branches we recall the history of our past without being aware of any splitting, which gives us an illusion that history is linear, not a tree.
As a result, what we observe is very far from what actually happens. It is not an illusion, but it is just a slice, a deformed projection of 1 thread of a multi-threaded reality...
Alfrez said:
To be more distinct. Here's another example. By shielding Einselection in an isolated object. I can view its Ensumble of all histories such that the chair foot can be in superposition of up-down-side, etc. This is the consequence if you can shield Einselection without having to require that the entire chair should be in coherent state. This requirement only exists in pure Copenhagen collapse model. But then if Many Worlds is true, you can see the chair existing in only one state, the other states in other worlds. However, if you can view the chair in many states simultaneously. Then Many World is falsified.
Sorry, I don't understand the your logic, but I will try to answer.
To 'see a chair' means to 'absorb phtons from a chair'. Experiments (don't have links right now, can google it if necessary) show that after receving even 5-10 photons the decoherence becomes almost final. So you can't see chair in many states at the same time - as soon as you start receiving photons you decohere with some of the outcomes.
In the double slit experiment. When we observe it, we only see one outcome. We don't see the superposition. I understand this is what you meant. However, in Decoherence and Einselection, the Einselection shielded chair is in different states being in superposition of up and down. Now if I'm also shielded from Einselection, I'm in superposition of up and down too. So I'm guessing I'd see the chair in superposition as I'm also entangled with it in complex macro superposition. Note again this is not your typical quantum coherence particle and superposition but on the more complex concept of preferred basis problem in Decoherence. You familiar with this preferred basis problem in Decoherence?
What do you mean by 'shielded'? Isolated from the environment? Then how can you see it? You can't see shielded object. If it is not what you mean could you draw the experimental setup?
The preferred basis (which is in general arbitrary) you should use in order to reply questions 'what I would see' must be, of course 'YOU'
I mean I'm also inside the shield. Or let's take an example the two of us. In Decoherence concept. Our body has classical states because of so called Environmental Superselection where the classical states in the environment is bestowed upon our particles. Without the environment. We can be in any state in Hilbert State. Or maybe let's use this example where only you and me are in this universe without any environment or particles. Since no classical states are being bombarded upon us. We can exist in a superposition of up and down. So we can likely see each other as states of up-down-side or halfup-halfdown-side or 1/4up-1/8down..etc. in fact any state in the superposition. Well?
Alfrez said:
But there is a big difference. A buckyball is a quantum object which obviously can interfere with itself.
A chair.is also a quantum object, only much bigger. Thus in theory it could interfere with itself just like a buckyball, if it were prepared in a superposition. But the latter is close to impossible because you cannot isolate a chair from the environment in a similar way as you can do it for a buckyball. For example, because of its size it has substantial gravitation. How would you switch it off?
Moreover, to notice the interference of buckyballs experimentally, one needs a source of many identically prepared buckyballs; this is the main difficulty in the experiment. How do you produce a source of many identically prepared chairs? Not the best factory can guarantee that the quantum state of two chairs is even close to identical. It has astronomically many degrees of freedom, but the manufacturing process controls only a small number of them, perhaps 100 or 1000...
Alfrez said:
in case you are not familiar with the exotic world of Decoherence).
I am very familiar with decoherence, but there is nothing exotic about it. Exotic is only what people interested in exotic phenomena make of it
You can't compare a chair to a buckyball. A buckyball 60 carbon atoms are all in coherence with one another. In a chair made of plastic, wood, and some metal. How can they be in coherence??
Anyway. In Decoherence and Einselection or Environmental Induced Superselection. The classical state of the chair is due to being influenced by the enviroment. When you place the chair in a universe without any environment, the chair won't be classical as you can have states of up-down or 1/4up-3/4down, etc. Right? And if you are in front of the chair you can see its shapeshifting because no environment is classically einselecting you and the chair. This is possible theoretically right?
Are you saying that in the new world of Decoherence, any macroscopic object such as a car can be in coherence as long as you can shield it from the environment (which practically is close to impossible as you stated due to gravity)? I thought coherence in the buckyball mean there is uniform arrangement of 60 carbon atoms. So all things must have uniform something before it can be in coherence. But you said a chair can be in coherence too. So any combination of complex macroscopic object such as car can be in superposition if the environment can be shielded? Of course this doesn't happen in Copenhagen. But then Decoherence is not really proven yet just the best model we prefer.
Coherence has nothing at all to do with a symmetric arrangement of atoms.
It only means that you maintain the superposition (i.e., an approximately pure state rather than a mixture) long enough to be able to perform experiments with it. Decoherence means that the density matrix degenerates from a rank 1 matrix (corresponding to a pure state) to a diagonal matrix under the influence of noise from the environment. This degeneration is a continuous process that takes some time. If one can keep the interaction with the environment tiny, this time is very long, but it becomes smaller exponentially with the size of the system. This is a theoretically and experimentally very well established fact.
Nothing in quantum mechanics forbids an ensemble of cars to exist in a superposition. But decoherence would turn it in next to no time into a classical mixture. In practice, one cannot prepare such superpositions for large objects, because they degenerate even before they are created.
They are planning to send a virus in double slit. So you are saying that even though the virus is very complex and not uniform. It can still be in coherent state if it is shielded from the environment? Now why haven't they performed it yet? They can shield buckyball but not virus, why?
But then, Decoherence is not proven yet. It is still possible everything is as the Copenhagen says.. meaning classical object can't be quantum. It is only in Decoherence concept where it is possible because the wave function *allegedly* never collapse. So your statement a chair can be in superposition if it could be shielded from environment is just speculations and not a definite sure thing, right? Only if Decoherence is proven that the statement can be true.
A virus is MUCH bigger than a buckyball; so it requires far more experimental ingenuity to do interference experiments with it. The effort scales with a nontrivial power of the mass, not only linearly.
You err. Decoherence is extremely well established, both theoretically and experimentally.
Copenhagen does not say that classical objects cannot be quantum. It only says that they must be macroscopic. So there is nothing to speculate about.
Dmitry67 said:
Then it is a classical case of Wigner's friend experiment, explained here:
http://en.wikipedia.org/wiki/Wigner's_friend#Wigner.27s_friend_in_Many_Worlds
I noticed you and Fredrik (is it mainstream now?) seem to model the superpositions in say the double slit experiment as only of 2 possible consequences. One is that each state has own copy.. that is.. in other Worlds. Second is to interpret everything as just for calculations with no actual ontology. But there is another way to look at it. We can say that during superposition, the particle doesn't exist as a particle at all.. that is.. there is really no position... this means spacetime before measurement doesn't exist as a definite lorentz metric. This is one way to make sense out of it.
The consequence of this is that before measurement, say you were the particle being sent to a double slit (or doors) experiment and if you were sufficiently shielded from the environment, you would not experience a frog world view where you only see a history of you passing thru one slit while the other copies pass thru other slits and angles and are in other worlds (birds eye view). Instead what could happen is that when a particle (or even macroscopic object) is shielded from environment. Up-down state doesn't exist so I can imagine myself as pure ghost like as I travel thru the slits. Why is this not possible?? Hope Fredrik can comment too as he holds views similar to yours which I wonder is some kind of Many Worlds bias. A neo enhanced Copenhagen like I mentioned may be valid too.
You mentioned if a chair could be isolated from enviroment, it can be sent thru the slits in a macro double slit experiment. But isn't it that the de broglie wavelength of massive object are so small, how can it still interfere? This is Copenhagen concept which many scientists like DrChinese still hold. Say, in Decoherence, what is the de broglie wavelength of the chair, before and after isolated from environment.. are their changes to the values depending on whether it is isolated or not??
About pure state and mixed state. So key to successful superposition is to create pure state. Buckyball is pure state. But you also said a chair or even car can exist in superposition... How can you create a pure state of the chair or car supposed isolation from the environment could be done (which is very hard if not impossible). But for theoretical understanding let's supposed the system is isolated from the environment, can't it be that inside the car, the dashboard or gear is interacting with noises from inside the car itself? So it can never be in pure state so no superposition is possible because the complex parts can itself be the source of noises amongst themselves. Or let's take the example of a fixed object like chair. Say it is composed of plastic, metal, rubber and wood. Can a pure state be created out of it? (Let's assume environment isolation were possible for sake of discussion of noises within the object itself).
In simple terms.. Can a rubber, a metal, a wood, a plastic be each in pure state and when combining them still be in pure state and not mixed state?? I think the reason why the Buckyball is easy is because of the uniformity which is easy to create pure state. I don't know how you can model a chair as pure state too. Pls. explain. Thanks.
The possibility of existing in a superposition is independent of a particular method of checking it (by a double slit experiment, say). The difficulty of performing an experiment increases with mass for many different reasons, of which what you mention may be one.
Yes.
No. Typically a buckyball is in a thermal (i.e., mixed) state. To prepare it in an approximately pure state is already a lot of work.
yes.
This noise must be regarded as part of the car; then it doesn't matter. (But if the noise can escape the car then it is interaction with the environment, which decoheres the car.
You see, one would need a car perfectly insulated against escaping noises, escaping light,
escaping energy, escaping CO_2 from the combustion... Impossible to build...
The usual way of creating a pure state out of a mixed state is by filtering all parts except the desired pure part. This can be done for photons but I have no idea how to do it
(even in principle) for chairs. There are no polarisation filters for chairs.
So one would have to create the chair directly in a pure state...
But I won't continue discussing such hypothetical settings.
A. Neumaier said:
There is nothing bizarre in von Neumann's statements. So there is nothing to refute.
You only need to upgrade your understanding of what the terms mean.
To say that consciousness collapses the wave function is equivalent to say that it takes consciousness to interpret the universe and change the interpretation when new information arrives.
Instead of modeling the system by a superposition in the absence of information, you model it by one of the participating eigenstates if a measurement result becomes known. Clearly, modeling reality (and changing the model) is a conscious activity and requires a consciousness.
This is nothing mysterious, and happens also in classical physics once you have a stochastic dynamics, where the collapse is called conditional probability.
Moreover, it has nothing to do with superluminal changes, since once one changes a molde to describe something, everything in the model changes instantaneously, although the system modeled isn't changed at all.
This already happens when you apply a coordinate transformation in a classical system...
What do you mean by ''in limbo''? The inside of the moon has lots of meaningful properties even in the absence of a sharp position (which it doesn't even have classically, by the way). Note that being in a superposition only means that there is no exact value of the position, not that there is no position at all. In particular, there is a mean position and a mean square deviation form this position, which together is adequate for most purposes.
Blood vessels work quite well without each of their atonms having precise positions to 10^1000 decimals of accuracy.
You are right that Neumann original meaning of consciousness collapsing the wave function was only related to pure mathematical interpretation. Meaning he didn't believe there was an objective reality to the wave function and one can move the Neumann cut of the collapse anywhere for calculation purposes only. It's a stretch for some to interpret Neumann wordings as saying there is an objective collapse where consciousness caused the collapse literally.. which is not the case. With this historical vagueness in perspective. It is very possible Mind doesn't have anything to do with Quantum Mechanics. Maybe the brain produce the mind as emergence. Thanks guys for all the clarifications.
I have only read page one of this thread, but, remember a non-local universe means that if a collapse occurs somewhere in it, the whole universe stops being a superposition.
"It means that underneath the ocean where human consciousness is not present, the water only exist as possibilities. This means the weight of the water at the surface can fall down to the limbo region." - and so would the rest of the universe exist in possibility. If 'part' of the universe collapses, then the rest does too.
Also, reading this book published by Princeton University Press, decoherence does not falsify that there still exists a superposition. Remember, the wave function equation doesn't collapse. Take it to the logical conclusion. Still a superposition.
Also, I like to think of it as, if decoherence chooses which possibility exists, then we have no control over the world - i.e. will this be a red piece of paper, or a blue piece of paper. That would be chosen for us.
Edit: reading the other pages of this thread now. Very interesting discussion. Find a lot of points that I myself have come to conclude through logic, so it's good to know there is someone out there that is thinking along the same lines as me!
One cannot collapse it since nobody can observe the whole universe.
So your statement is empty.
You don't need to observe the whole universe. Just part of it. Remember non-locality?
If an 'observation' was made in the place where Pluto is now, then the rest of the universe collapses because of entanglement. Pluto doesn't stop being a superposition while the rest of the universe continues to be.
Only your logic collapses.
The state of a system cannot collapse through the observation of a subsystem. Indeed, since your fictitious claim cannot even be translated into a formal statement, it is impossible to give it an interpretation of it in terms of quantum mechanics.
Are you trying to say entanglement is not a fact?
How on Earth can you read such a strange assertion into my statements?
Entanglement, collapse, and decoherence are very different things, though there are relations between them. I am using my words with care not to mix things up.
Then if two 'particles' are entangled, which are on opposite sides of the universe, and one of those particles is observed, then the other one would collapse, no? Or have I been lied to? Because that is what I've come to understand from reading a variety of QM books.
I say are you suggesting entanglement is not a fact due to you denying this previous post:
That post relies heavily on what I've read, and I would hope that I have been told the truth. After all, you learn from others and you expect a bit of honesty that it is factual.
If all 'particles' are entangled, then you can apply the above to previous statements I have posted.
You didn't read the QM book property. QM is even stranger than you can possibly imagine. Remember that quantum properties don't exist before measurement, if no one is there on the other side of the universe to measure it, the properties like position doesn't even exist. So there is really no non-locality to it because locality doesn't exist in the first place. It is only upon this realization that you can be said to understand more completely quantum entanglement and Bell's Theorem.
But if someone were there to measure a particle, then wouldn't the other particle collapse? That's what I'm aiming to say, you don't need to 'observe' (measure) the whole universe to collapse every part of it because you are obviously in one area, the 'wavicle' is now a particle, which is entangled with the rest of the universe, so the other wavicles collapse?
No. Because in entanglement the twin particles don't even exist before one does measurement. You are assuming both particles are sent off to opposite directions like ping pong balls. But no. Only the wave function exist travels. Now if you measure one side, the particle part pops out, but if you didn't measure the opposite side or particle, the particle doesn't exist yet even though the wave function already collapse... it's like it's hold off in a buffer zone and not yet outputted to Spacetime when no one measures it. So the reason you can't collapse the whole universe by collapsing a region is because the wave function can initiate collapse isolation shield courtersy of lorentz metric regional quantum coupling quarantine. Something like that. Hope others can share the right words and mathematical formalisms to use.
If you measure a system X and can continue to observe it, the measurement prepares the system X in a new state that (in some approximation) is an eigenstate of the corresponding observable. This is referred to as a collapse.
The measurement does nothing at all to particles far away, no matter how entangled they are with X. But the state of the big system also changes by the measurement, though in a more complex way that cannot be described by the notion of collapse.
Thus if X and Y are entangled and far away from each other, measuring X collapse X but neither Y nor the universe; and measuring Y collapses Y but neither X nor the universe. If you compare the resulting measurements, and make a statistics over sufficiently many such measurements, you get the standard predictions for the behavior of entangled states.
No measurement collapses the whole universe. This can be affected only by God, who runs the whole universe and presumably can collapse it, e.g., by switching it off.
