Does gravity affect a magnetic/electric field?
This discussion explores the interaction between gravity and electromagnetic fields, emphasizing that gravity influences electromagnetic radiation, such as light, despite light having no rest mass. It highlights that in general relativity (GR), the source of gravity is the energy-momentum tensor, which includes both mass and momentum. The conversation also notes that electromagnetic fields interact with gravitational fields, leading to observable phenomena like redshift and blueshift. Key resources mentioned include Maxwell's equations in curved spacetime, which provide foundational knowledge for understanding these interactions.
  • Understanding of general relativity (GR) principles
  • Familiarity with Maxwell's equations
  • Basic knowledge of electromagnetic radiation (EMR)
  • Concept of the energy-momentum tensor
  • Study Maxwell's equations in curved spacetime
  • Learn about the energy-momentum tensor in general relativity
  • Research the effects of gravitational fields on electromagnetic radiation
  • Explore the concepts of redshift and blueshift in astrophysics
Physicists, students of general relativity, and anyone interested in the interplay between gravity and electromagnetic fields.
PWiz
Since light, a form of electromagnetic radiation, gets bent in a gravitational field even though it does not have any rest mass, it is obvious gravity is a force that does much more than just attract two masses towards each other. Since it affects electromagnetic radiation, it has led me to ask: does gravity(or a particularly strong gravitational field) have an affect on an electric/magnetic field or vice versa? There seems to be some connection here.
P.S. I haven't started with GR yet, so please don't expect me to follow a very advanced conceptual understanding of the theory.
It is only in Newtonian gravity that the source of gravitation is exclusively masses. Once you go to GR, the source of gravity (really, of space-time curvature) is the energy-momentum tensor - an object that contains both masses and momenta of the contents of the space-time. There is also some feedback, space-time provides the setting for how electromagnetism behaves, so yes, to some extent electromagnetic fields and gravity do interact.
All forms of electromagnetic radiation (EMR) "seems" to interact with gravitational fields, even radio waves are bended by gravitation. As general relativity (GR) does not include forces in its description, what determine what will happens with the EMR in GR? The space curvature. If a beam is collinear with the "force lines" of the curvature, per example, as when a light ray goes against the gravitational field of a massive body, we will have a red shift. (This is not the cosmological red shift caused by the expanding universe). If the light ray is going to a massive body, then it will be a blue shift. (These are observational results). This is interpreted by Einstein as the effect of gravitation on clocks. And the red shift and blue shift are seeing as a result of time accelerating or reducing its ticks. In other words, those phenomena are seen by relativity as an special case of the general effect of Gravitation on time. In the other hand, when the light rays are not collinear with the gravitational field, then we have the bending of the rays. All these phenomena "look" as if "light" interacts with the gravitational field, however, GR forbid us to think that way. Gravitation curves space, and curved space determine the trajectory of objects and the passing of time inside that space. So PWiz your common sense deduction goes against GR. Personally I have never felt comfortable in this schema.
@Orodruin Hmmm, I've heard of the term "energy-momentum tensor" a lot in the past few days. The greedy feeling of wanting to grasp the entire concept mathematically is indescribable :H (Getting closer by the day though...!)
@DaleSpam Thanks, I've added Maxwell's equations to my must-learn list :)
@LUIS FONDEUR You've given me a new insight on this. Thanks for adding clarity to my concepts.
  • · Replies 0 ·
  • · Replies 44 ·
  • · Replies 20 ·
