Does Heat Radiation Decrease the Number of Photons Over Time?
The discussion revolves around the concept of heat radiation and its relationship with the number of photons emitted over time, particularly in the context of a hot body placed in a room. Participants explore the implications of thermal radiation, temperature changes, and the dynamics of photon emission as the system evolves towards thermal equilibrium.
  • Participants discuss whether the number of photons decreases over time as the hot body cools, and question the assumptions regarding the comparison of photon numbers before and after the hot body is introduced. There is also exploration of the relationship between temperature, heat transfer, and photon emission rates.
The conversation is ongoing, with various interpretations of the problem being considered. Some participants have offered insights into the nature of thermal radiation and the factors affecting photon emission, while others express uncertainty about the clarity of the original question.
There are indications that the question may be poorly worded, leading to different interpretations. Participants are examining the assumptions about the system's behavior as it approaches thermal equilibrium and the implications of heat transfer dynamics.
Jahnavi
No .
The number of photons should decrease . As the rate of heat transfer decreases with time , the net electromagnetic radiation from the hot body to the surroundings decrease .
Heat radiations are composed of photons . Hence their number should decrease as time progresses .
Is the reasoning correct ?
I would request the experts to give their opinion .
One can also read the question as:
Is the number of photons increasing compared to before, when the hot body was not present in the room ?
Assuming the question is considering time after the hot body is placed , do you think my reasoning is correct ?
I think your reasoning is correct, but your assumption is not.
Could you explain why my assumption that time after the hot body is placed is incorrect .
Don't you think wording of the question should have been " Has the number of photons increased ? " if the question wanted to compare the number before and after the hot body is placed ?
If the emission rate of thermal radiation would depend linearly on the temperature, the number of photons would stay at same value when the hot object approaches thermal equilibrium with the room. However, the emitted radiation power is not a linear function of temperature.
What kind of function is it and what can you deduce from it?
Sorry, this was a bit hasty conclusion I made and doesn't take into account the heat capacities and surface properties in the room
But still, the idea of the problem is to find a physical law that shows that the emission rate of photons drops much faster than linearly when temperature is decreased.
Don't you think we just need to consider whether the rate of heat transfer decreases or not ?
As the temperature of hot body decreases , rate of heat transfer decreases . As a consequence , the photons comprising the heat radiations should decrease with time .
Please have a relook at the OP and let me know what is wrong with my reasoning .
Jahnavi said:
As the temperature of hot body decreases , rate of heat transfer decreases.
Yes, but the surroundings in the room will also heat up because of the object and start emitting more radiation. Also, there is radiation even in thermal equilibrium where the temperature is same everywhere. You need to show that having one very hot object in a room will produce more radiation than having the whole room at a slightly elevated temperature.
It's a rather poorly worded question, because the blackbody radiation emission of the warmer object is instantaneous and the electromagnetic radiation from it will then decrease as it subsequently cools unless it is continually supplied with a source of power. The question is too vague to be able to give it a very good answer.
Charles Link said:
It's a rather poorly worded question, because the blackbody emission of the warmer object is instantaneous and the electromagnetic radiation from it will then decrease as it subsequently cools unless it is continually supplied with a source of power. The question is too vague to be able to give it a very good answer.
Yes, the problem may also be about resolving a misunderstanding that some students may have, that the photons emitted by the object will "accumulate" and the number of them is a time integral of the emissive power.
Please confirm one thing .
What is your interpretation of the problem statement ?
Are you comparing
1) the time before and after the hot body is placed .
OR
2) the time after the hot body is placed till thermal equilibrium is achieved .
So let it be :smile:
If the body cools , the rate of heat transfer will decrease and subsequently the number of photons . No ?
The number of photons will be at the maximum value practically immediately when the object is placed. There would be no reason to compare to the situation before the hot object is in the room. The instantaneous rate of change (time derivative) of the number of photons is probably what is meant here, and we have to show that it is negative at any time.
That is correct. The problem is that because the question is so vague, they might tell you that is not the right answer. :wink: They might tell you the warm object increased the number of photons from what the room previously had.
Exactly :smile:
I asked this because of BvU's objection to my interpretation in post#2 and post#4 .
I agree. It asks whether the number is increasing, not whether it increases. That makes it a question about the ongoing state.
As to the point of the question, not all photons carry the same energy, and as the object cools the room warms. For both reasons, I don't think it is sufficient to argue that the rate of transfer of heat reduces.
Even at equilibrium, photons are being transferred.
Edit: i suspect the question setter intended the room to be taken as constant temperature. If the room plus object form an isolated system and the object has the greater thermal capacity then it may well be that the number of photons will increase over time.
I think the same .
Why ?
Irrespective of the heat capacity of the hot object , it will start cooling down till it's temperature becomes equal to the room temperature .
Rate of Heat transfer is proportional to the temperature difference (fourth power) . It will be maximum initially and gradually decreases. Same with photons .
First, don't confuse net transfer with total emission.
Secondly, even for net transfer, it is not the fourth power of the temperature difference; it is the difference of the fourth powers of the temperatures.
Each (black) body emits radiation according to the fourth power of its own absolute temperature. It doesn't care how its temperature relates to that of its surroundings. At equilibrium, both object and the walls of the room will be emitting photons.
  • · Replies 20 ·
