Does It Matter Which Vector You Start With When Using the Parallelogram Rule?
mpaige1
Determine resultanat force of vectors P (40N) and Q (60N). P is 20 degrees from reference plane and Q is 45 degrees from reference plane.
When using the parallelogram rule, should you always start with the lowest angle vector? (like in the bottom diagram of the attached image)
I solved the question using the parallelogram in two different ways and ended up with different answers. Is there a right way to do this?
Solution 1:
P vector, then Q vector with resultant vector starting at tail of P to tip of Q.
Law of Cosines yields,
R = 97.726N
Law of Sines yields,
Angle A = ∠15.039
alpha = ∠20 + ∠15.039 = ∠35.04
Solution 2:
Q vector, then P vector with resultant vector starting at tail of Q to tip of P.
R = 98.542N
A = ∠7.9803
alpha = ∠45 - ∠7.9803 = ∠37
Diagram attached.
You say "reference plane" which implies three dimensions. But in that case, there are an infinite numbers of candidates for P and an infinite number of candidates for Q. I will assume this is a two dimensional problem and you mean "reference line".
Do you understand why it is called the "parallelogram" rule? A parallelogram has four sides, two of which represent P and two which reresent Q- it doesn't matter which you "start with".
Solution 1:
R = 97.726N
It's impossible to say what you might have done if you don't say what you have done! Here, you have a triangle with two sides of lengths 40 and 60 and angle between them of 140 degrees. Applying the cosine law I do NOT get 97.726.
Angle A = ∠15.039
Solution 2:
R = 98.542N
A = ∠7.9803
Diagram attached.
All I can say is I get a completely different answer. I can't say what you are doing wrong. I presume you know that the cosine law says that [itex]c^2= a^2+ b^2- 2abcos(C)[/itex]. The fact that that is "symmetric" in a and b should tell you that it doesn't matter which side you call "a" and which side you call "b". What angle do you have between the two vectors?
Sorry, I used the wrong value for the angle in cosine. It should have been 155 and I used 160. This should be correct, the textbook I'm working from has the same as their answer. It could be wrong but I doubt it.
Here's the complete walkthrough of the problem:
R^2=〖60〗^2+〖40〗^2-2*40*60cos(155)
R = 97.726N
sin(A)/40 = sin(155)/97.726
A = 9.9612
alpha = 35.039
I'm not sure if the diagram I gave is showing up but it should have everything you need on there. No worries guys, it was a stupid mistake.
