Does matter accumulate in Earth's gravity well?
  • Context: High School
  • Thread starter Thread starter TimeSkip
    Gravity Matter
38 replies · 5K views
TimeSkip
I would like to understand if matter accumulates into the gravity well of the Earth?
After so many years of circling the sun I have this imagination of tritium, nitrogen, and ozone accumulating underneath the Earth into it's traditional orbit, and accumulating over time.
Is this possible and if so, is there anything we should be worried about in terms of gravity waves confronting this matter accumulated over time there?
Astronomy news on Phys.org
Well, yes. Gas dust and meteors are continually bombarding Earth.
Amongst other things, you see meteors and shooting stars streaking across the night sky, and you see the solar wind in the Aurorae, and we are constantly sweeping up gas and dust in our orbit.
Many tonnes of material fall to Earth every year.
Note, BTW that Earth loses a lot of matter too (mostly H and He escaping the atmo).
Calculations suggest that Earth actually loses more matter than it gains (~ 50,000 tonnes per year).
"Underneath"? :confused:
Yes, Earth accumulates matter on its surface as well as in orbit, and there is even matter in Earth's orbit around the Sun, as well as on Earth-crossing paths.
Well, the short answer is no, but why do you think there might be? What would gravitational** waves have to do with it?
** did you mean gravity waves or gravitational waves? They're very different things.
https://en.wikipedia.org/wiki/Gravitational_wave
https://en.wikipedia.org/wiki/Gravity_wave
Yes, I think I meant inside the gravity well of the Earth. Is that unclear? I suspect gases and matter are inside it as it traverses around the sun.
Certainly. There is no clear boundary between Earth's local space and interplanetary space. What is your concern again?
Isn't this worrisome? I suspect that we have significant amounts of highly enriched hydrogen to tritium over the millennia of years of the Earth orbiting the sun. What kind of effects would all this enriched material in the gravity well of the Earth have on the sun possibly if it at all does?
  • Skeptical
Shouldn't you be just as worried about the tonnes and tonnes of uranium, plutonium and other highly radioactive materials already on/in Earth?
Did you know that the reason the Earth's core is still molten (as opposed to cold and dead, like the Moon or Mars) is due to heat from radioactive decay of elements? That's a lot of radioactive material right under our feet. Way more than what you mention.
In what sense do you mean "enriched"? That normally means a material has been filtered and refined to keep only (or at least, more of) the parts you want (just the fissile isotope of Uranium, for example). That seems to me to be the exact opposite of taking a few thousand tonnes of matter and scattering it over the surface of the Earth.
Anything caught in Earth's gravity will end up on Earth or maybe in orbit
I have never yet heard of any science confirming the accumulation of material in orbit as you seem to think happens
Therefore I think your concerns are unfounded :smile:
As one other responder said ... underneath ??
I suspect your understanding of a gravity well is not quite right
First of all, why do you think tritium would be preferentially trapped? Second of all, tritium has a half-life of only 12 years, and so quickly decays to He-3 if it were to be trapped.
I stand corrected then about tritium. For what it's worth I think that it's interesting that matter might find its way collecting in the gravity well of the Earth over millennia.
As a side question it's interesting that aurora's don't happen as often over Antarctica, whilst probably heavier matter collects in the gravity well instead.
I think there's a whole "trail" of matter around the Earth as it has traversed throughout time around the sun.
  • Haha
I think that's based on misunderstanding what a "gravity well" is...and also what a "planet" is.
Stray dust that wanders near Earth generally ends up on Earth.
Sorry should I have written: Gravitational potential well?
Doesn't really help explain what you think is happening/where this matter is collecting.
Is hydrogen, nitrogen, and water molecules simply "sitting" in it?
Everything will fall (using "fall" in a general sense that can include orbiting) until it hits something like the atmosphere or the surface of the Earth.
Maybe it will help if we address the exactly what a "gravity well" is.
Below is a representation of gravity wells, both the Sun's and the Earth's (not to scale!)
The large "dip" is the Sun's gravity well, and the Smaller dip is the Earth's, which itself is in the Sun's gravity well. Things tend to settle to the bottom of a well. Since Earth's well is a localized dip in the Sun's well, anything that gets close enough to the Earth will tend to settle to the Bottom of that dip rather than all the way to the bottom of the Sun's well. ( The Earth's surface will however get in the way causing it to settle on the Earth's surface. Anything that is far enough away from the Earth will have its path dominated by the Sun' well.
So what do you mean by stuff collecting in the Earth's gravity well? The only way for stuff to collect in the Earth's well without building up on the Surface would be for it to go into orbit around the Earth, and it isn't that easy for the Earth to collect matter around it this way.
Source please?
Source please?
I only hypothesize that matter "may" accumulate in the Earth's orbit or gravity well if this makes any sense, as per the opening post question in the OP.
However, I am unsure if this is true. I suspect that the gravitational potential well is what contributes to this effect as more massive matter accumulates there possibly. I also, and interested if this has been modeled recently or so over time or even documented or debunked?
These are just basic assumptions about what may reside there. I'm not sure if any of this is true.
My further hypothesis is that due to this the nature of aurora borealis and aurora australis might be different.
I don't know much of what happens in below or "above" Antarctica.
  • Haha
Vanadium 50 said:
Source please?
Unfortunately, I just did a search and could not find anything of significate to that assertion. So, I take it back, but am interested if it is true or not in your or other's opinion.
Remember "observer bias".
How many aurora australis go unobserved because no denizens of the sparsely populated southern latitudes happen to be looking up?
It might be a small matter of documented spectrographic analysis of the australis auroras in comparison to the borealis to determine any truth to the assertion that there's any different matter orbiting around Antarctica vs. Artic Circle.
  • Skeptical
Again, source please.
If you don't have one, may I politely suggest you stop making stuff up and asking us to explain it? People get real tired of this game real fast.
I'll be vigilant about that from now on. Thanks.
The Earth's gravity well isn't underneath Antarctica, if that is what you're thinking!
Note that the following is not a valid physical model:
Of course not.
It's turtles all the way down.
  • Haha
Not correct. They happen there every time they happen in the northern hemisphere
Seriously, you didnt read what was written in answers to you earlier aye ?
Your understanding of a gravity well is not correct
There is NO up or down in space, therefore NOTHING collects at the "bottom" of the Earth
Everything that falls into Earth's gravity will usually end up on earth
TimeSkip said:
My further hypothesis is that due to this the nature of aurora borealis and aurora Australis might be different.
Again, as I have already stated ... there is no difference in occurrence between them
Below Antarctica is inside the Earth. Above Antarctica is in the atmosphere or out into space
Again, there is no difference other than variations in the way the aurora curtain sways. We know this because of satellites that image both regions and see aurorae at the same time at both poles
Not what I exactly meant, but isn't it deepest around Antarctica?
  • Wow
  • Skeptical
  • Haha
It's deepest at the centre of the Earth, not anywhere on its surface.
