Does Sound Intensity Change with Frequency Shift in Doppler Effect?
  • Thread starter Thread starter tjaeger
    Sound
tjaeger
A car with a 1000Hz siren moves away from you toward a cliff at 15m/s. You are stationary. What frequency of sound do you hear directly from the wall and what frequency do you hear reflected off the wall? Which sound is louder?
f' = f(v +/- vo)/(v +/- vs); where v = 343m/s, vo = velocity of observer, vs = velocity of the source
I found that the frequency of the sound you hear directly is 958Hz and the frequency of the echo is 1046Hz. How can I tell which one is louder?
Wouldn't you be hearing both frequencies (or a mix)? What does you text say about beats?
I think we are supposed to look at each case individually. The answer is given to be the 958Hz wave.
Plug everything into the equation.
f' = 1000Hz((343m/s +/- (0)m/s)/(343m/s+15m/s)
f'=958Hz
Remember, since the person is stationary, their velocity is 0. Also, since it is moving away from the observer, the frequency is going to be smaller as it moves away. Therefore, you add the denominator because the object is moving away and you want to divide by a larger number, which in turn, makes your final answer smaller.
