Jonathan Scott
- 1,274
kev said:If we define "real" as being defined by what we actually measure (which the way real is usually defined in SR and GR) then the frequency of a photon "really" gets slower as it climbs out of a gravitational well. If you define real as what an intelligent being would conclude is happening "behind the scenes" to explain what is measured, then the frequency of the photon is "really" constant as it rises. The modern interpretation of Relativity does not consider what is happening "behind the scenes", only what is measured.
No, I don't buy that at all.
If you think that it could ever make sense to say that a wave is slowing in frequency as it rises, where do the extra cycles go? For example, replace the photon's path with a rod rotating about its axis. If the whole rod did not rotate at the same frequency, it would gradually get more and more twisted. Observers at different potentials may consider that the whole rod is rotating at slightly different speeds, depending on their potential, but it doesn't make sense to suggest that the lower end is rotating at a different frequency from the upper end.
