Does the existance of relativity prove that gravity's wrong?
  • Thread starter GordonDengyo
  • Tags
    Relativity
In summary, although Einstein's work proves that Newton's gravity is not a complete theory, it is still used by physicists because it is a special case that works well in weak fields. It has not failed the test of time and is still used in many situations. However, it is important to note that Newton did not have a full theory and there may be room for improvement. Physicists continue to use and study gravity, but there are still unanswered questions about how mass generates gravity and how billions of stars can orbit a galactic core without colliding. More research is needed to fully understand this phenomenon.
GordonDengyo
If Einstein's work proves that Newton's gravity is wrong, why do physicists still use gravity as though it's a sound scientific theory? When Drake successfully circumnavigated the Earth in the 16th century, scientists realized that Aristotle's 'flat Earth' was wrong and this opened the way for Newton to imagine gravity. If gravity has already failed the test of time as proven by relativity, are physicists of today merely hanging on to an incorrect idea because they're incapable of thinking outside the 'box' created by Newton?
While strictly speaking the Newtonian theory of gravity is wrong, the theory that superceded it, General Relativity, still reduces to it in the appropriate limits (weak gravitational field/small curvature of spacetime). Strictly speaking the theory of Newtonian mechanics (F = ma) is wrong too, but at speeds much less than the speed of light we can't detect the difference. The same goes for the theory of gravity: anytime we use the Newtonian theory of gravity it's because its predicitions are nearly indistinguishable from the full theory's predicitions. This shouldn't be surprising since if the original theories didn't make correct predictions they never would have been accepted.
One place we do have to use GR instead of regular Newtonian gravity is GPS systems: due to time dilation effects GR is needed to give accurate locations, etc. So we use GR when we need it and Newtonian gravity when we don't need the full power of GR.
In the same way that we still use the flat Earth theory - for small regions of the earth, like Singapore.
Another important thing to notice is that Newton didn't have a full theory in the sense that he had no mechanism to explain why to masses attract each other. He even said essentially, I can't figure out why this happens so sooner or later someone is going to come along with a better theory that provides a mechanism that shows why things attract (GR)
GR does not invalidate Newton's gravity. The latter is a special case and works well enough in weak fields. It's possible to start with GR, make some simplifying assumptions and derive Newton's gravity.
"If gravity has already failed the test of time as proven by relativity, are physicists of today merely hanging on to an incorrect idea because they're incapable of thinking outside the 'box' created by Newton?"
It hasn't failed and no.
GR does not explain WHY mass bends space :)
The point I'm trying to get across is that gravity might be wrong, completely and utterly WRONG! Much of our current understanding(Big Bang, black holes, gravitons, etc.) is based on the idea that mass generates gravity. If this concept is wrong, then every one of those ideas that's based on the presumption that gravity is infallible is also wrong. This would include Einstein's own relativity which deals with objects with 'mass' when they near the near the speed of light and with 'massive' bodies. Physicists seem to be trying to make their observations and understanding 'fit' into their thoughts of gravity and relativity. If some aspect of reality doesn't seem to 'fit' into their preconcieved notion of how things should work, they merely ignore it or move on to something else. Take galactic cores for example. Physicists can explain how rings are formed on planets and why planets revolve around the sun in a thin plane. They can explain how stars are drawn into the thin disc of a galaxy but they ignore the question of how billions of stars can orbit around a galactic core without bumping into each other and growing into a black hole. Some of them suggest that a black hole is at the heart of every galaxy but if this were the case, logic dictates that this black hole would absorb stars out of the core and grow larger. Once larger, it would absorb more stars until ultimately it would swallow up all the stars in the core and begin on the stars in the disc. Of the billions of galaxies that have been catalogued and observed, not a single one exists as a 'donut' shape with a dark center.
In fact, if you ask any physicist, "How does mass generate gravity?", they all answer the same way; I don't know! I think that before another tax dollar is spent on researching some aspect of physics that's in any way relative to mass, all efforts should be put into answering the questions that have been ignored for hundreds of years. We should be absolutely certain that we are on the right path and that Einstein's work isn't merely an alarm telling us that Newton's work is entirely incorrect.
I'm sorry if I offend any physicists with my opinions but I'm in search of the truth. If anyone on Earth can explain how mass generates gravity I would love to hear it.
GordonDengyo said:
...how billions of stars can orbit around a galactic core without bumping into each other and growing into a black hole.
Black hole quickly 'eats out' all the stars which orbit close enough. All other stars orbit safely around the black hole like they would orbit around any other body of the same mass (you are victim of a popular misconception about the black holes). Finally, the probability that star collide and bump into each other is so low that such collisions are rare even when the whole galaxies collide. And it was well known a long time ago.
P.S.
It is a pity I did not find the famous "General relativity is just a theory" in the post above :)
Most of your post #7 is simplistic and silly. Your original question is entirely reasonable.
But why pick on gravity? You don't know what mass is and neither does anybody else. Nor time, nor space, nor energy...Where do the free constants in the "standard model" come from?...why do we use those?...Simple: all those are the best theories/values we have and in most cases theory, however imperfect or incomplete, matches experimental results.
Science usually makes progress in baby steps since formulating theories is very hard work. Did science still assume a static universe after Hubble discovered recession of distant galaxies? (well, likely some did.) But each NEW theoretical or experimental result usually means something unusual, something previously not understood. So sometimes it takes even brilliant people time to comphrend the meaning of new results and sometimes they argue for decades...different versions of quantum mechanics versus each other and relativity for example.
For final truths, try religion.
Any answer to that will create the next 'how' or 'why' question. Any 4 year old kid can create an infinite chain of 'why' questions. :smile:
What is mass :rofl: Be it the Higgs or some other theory I think you need to know what mass is before you can say how mass generates gravity. If I'm not mistaken the LHC should amoung other things look for the Higgs boson which would be the source of mass if found(corrrect me if I'm wrong). There is a lot that goes into a theory like that. And I don't think physicsts blindly follow in Einstien's path. In fact I think most of them realize that either Einstein, QM, or both are incorrect in some sense because we you but them together they don't work...
I'm a little confused by what you mean when you say Gravity is wrong. Do you mean that something else is pulling my book to the floor when i drop it? Physicists aren't absolutely certain. Thats why we have lots of other theories. They are relatively sure that something along the lines of GR will do the trick
Nor was it intended to. Your taking it out of context. The point of it is to explain gravity not bending space :tongue:
jefswat, my point was that the question WHY is usually does not have any sense when applied to the fundamental things. Like, why 5 is a prime number? yes, I know that there are no such numbers that A*B=5, but WHY?
Newtonian theory works well for the vast majority of practical problems.Engineers,for example would not use relativity to work out the forces acting on a bridge it would be like using a sledgehammer to crack a nut.
Yes, something else is pulling your book to the floor, electromagnetism. Don't bother explaining that your book isn't made of metal or magnets, I understand that. It is made of atoms though and each and every atom is acted on by the electromagnetic field of the Earth. If I rub a balloon(not metal or magnet) on my head, hair or small pieces of paper(not metal or magnet) will cling to the balloon. This is exactly what happens to your book when you release it, it's acted on by the Earth's electromagnetic field and is pulled to the field until it can become 'grounded' once again. Physicists should have clued into the reality of what's going on in 1805 when Coulomb's law turned out to have the identical formula as Newton's law of gravity. They are one and the same force only one of them is real and one of them exists only within the minds of humans as a means of explaining the workings of the universe.
The similarity is only due to the number of dimensions of our space (it gives r^2 in the denominator). In fact, in GR it is not exactly the same formula for the strong gravitational fields. And for electromagnetism it is valid for charges in rest only. Also, in GR gravitation force is not a force at all. Electromagnetism is similar to the weak force which is very short range nand not /r^2 at all.
I can not blame you for thinking this way, even Einstein was trying to unify gravity and electromagnetism, while he should start from the weak force. So saying about the "identical formula" is like very old and naive classifications of the plants based just on their appearance, like "trees", "grass" made in the middle ages.
Finally, as the formula is NOT identical it is a total BS. Just a spagetti of the popular books.
So then how come the needle on my compass points north and not down? And how does EM explain Time dilation. Also I'm fairly certain the EM equations you are thinking of have also been proven out dated and better equations have been found(QED I think?)
But Newton's equations are wrong. They fail to even predict the orbits of all the planets(to a high degree of accuracy) where GR does. Physicists are trying to merge gravity with the strong, weak, and electromagnetic forces and so far have not been successful. I'm not trying to say GR is right I'm trying to say its better than Newton's. Regardless it is a model not the the universe actually works for sure.
I know I was just poking fun. Your concern is a good one. As someone else said, solving a problem just raises 2 more "whys"
Both of these statements are in a sense wrong. Newton's equations are not so much wrong as they are inaccurate. They do an amazingly accurate job of predicting the orbits of the planets, even Mercury's orbit, over centuries. General relativity is a pretty small effect, even on Mercury. General relativity results in a small precession of Mercury's perihelion angle: 43 seconds of arc per century, or 3 million years per 360 degrees. The time scale on which general relativistic effects become apparent (unless you are looking for meter-level accuracy) is much, much greater than that for all but Mercury.
That 3 million years is about the same as the solar system's Lyapunov time. Beyond this time scale any predictions are pretty much garbage, even those with a full relativistic model.
I think that general relativity proved that gravity is correct. Consider a Mossbauer effect experiment, with a Mossbauer source on top of a 100 foot tall tower, and the Mossbauer detector at the base of the tower (and vice versa). Experiments show that the photons gain energy (just like Newton's apple) while falling from the tower, so either the source or the detector has to be moved vertically to compensate for the energy gained by the photons. Harvard did this experiment using the Fe^57 source mounted on a loudspeaker coil.
A classical theory proved a phenomenon in the real world to be "correct", and the way to see that is to consider a quantum physics experiment? :wink:
The experiment you describe is interesting, and I appreciate that you posted it. I just couldn't let that first sentence slide :smile:
GordonDengyo said:
Much of our current understanding is based on the idea that mass generates gravity.
In GR the source of gravity is not mass; it is the stress-energy tensor. The stress-energy tensor includes energy, momentum, pressure, and stress, all of which together "generate" gravity.
Mute said:
Strictly speaking the theory of Newtonian mechanics (F = ma) is wrong .
In accelerators like the Fermilab Tevatron, where protons and antiprotons are accelerated to energies equal to 1000 rest masses, the Newtonian mechanics formula F = ma is still correct. Each revolution, RF cavities (where the electric fields provide the force) add a few thousand electron volts to the total proton energy, and the total energy keeps increasing. When particle velocities approach the speed of light and a no longer increases, the relativistic mass m (NOT the rest mass) increases instead. This is also true for the particle momentum p = mv, which approaches mc. It is also true for antimatter like antiprotons.
Bob S said:
I think that general relativity proved that gravity is correct. Consider a Mossbauer effect experiment ...
You don't need to go so far as invoking general relativity to debunk nonsense such as this:
GordonDengyo said:
Yes, something else is pulling your book to the floor, electromagnetism. ... Physicists should have clued into the reality of what's going on in 1805 when Coulomb's law turned out to have the identical formula as Newton's law of gravity. They are one and the same force only one of them is real and one of them exists only within the minds of humans as a means of explaining the workings of the universe.
All it takes is observing that planets have moons, and that moons can have satellites of their own (e.g., the satellites we have on occasion put in orbit around our Moon). Think about it.
Coulomb's law and Newton's law of gravity are superficially similar in that both are inverse square laws. That the two laws have a difference in sign (like charges repel but masses attract), that mass has magnitude only but charge has sign and magnitude, and a largish conglomeration of mass is close to electrically neutral makes gravitation and electrostatics considerably different.As noted by many, general relativity did not so much disprove Newtonian gravity so much as disprove that Newton's law of gravitation is universal. Newtonian gravity still has its place. There is no reason to use general relativity to model the motion of a satellite in low Earth orbit. Uncertainties in atmospheric drag, Earth's non-spherical nature, solid body tides, and even ocean tides vastly overwhelm the tiny error induced by ignoring general relativity.
Strictly speaking, all scientific theories are incorrect. We just don't know yet where some of them (e.g., general relativity) are "wrong". Looking for absolute correctness in a scientific theory is asking too much of science.
That's because they both assume Euclidean geometry. The inverse square law is a feature of Euclidean geometry. Is the radiation level from a radioactive source one and the same force as gravity, since they both follow the inverse square law? How about the noise level from a siren? How about the intensity of light from a lamp? Same thing as gravity because it follows the inverse square law?
Thanks for being careful to emphasize that you were specifically talking about "relativistic mass", that avoids all sorts of confusion. The more common approach in modern physics is to say F = dp/dt and to say that p is a non-linear function of velocity which increases without bound as v approaches c and to use only the rest mass, but of course your approach works too.
Like Naty1 said, your original question was reasonable. Your post #7 is simplistic and silly. Your post #15 is completely contrary to the facts.
Your supposition that “electromagnetism” is the force responsible for pulling the book to the floor as “each and every atom is acted on by the electromagnetic field of the Earth” is fundamentally flawed and is easily dispelled. Here’s why…
The planet Mars has no global magnetic field (magnetosphere) and at best, it only has very isolated magnetic fields at various locations around the planet attributed to local iron concentrations. Even so, Mars manages to muster roughly 1/3 as much gravitational attraction as the Earth’s rate gravitational attraction regardless of an object’s orientation around its surface. How, in the complete absence of a global magnetic field, do objects free-fall to the Mars surface at the same rate regardless of their location?
The answer is evident. Objects are attracted per the gravitational field of Mars, which is essentially uniform in all directions per the planet’s center of mass. Objects cannot be attracted to the planet’s surface via electromagnetism because Mars is lacking of a magnetosphere. This is essentially true of Venus as well. The Pioneer Venus Orbiter (1979~1981) measured the intrinsic magnetic field of Venus to be just 10^-5 that of Earth, comparatively, no magnetosphere to speak of. How then, does Venus produce the rate of attraction that it does in the absence of any significant magnetic field? Again, the means of attraction is by gravitational fields, not electromagnetism.
You must remember to look at the entire picture when attempting to derive theories and they must in essence hold true when applied to all models. Gravity is present on all heavenly bodies to lesser and greater extents, but it is also clear that not all of these heavenly bodies possesses a significant magnetosphere that could proportionately explain the heavenly body’s observed rate of gravitational attraction.
Associated Links…
NASA reference to Mars lack of global magnetic field…
http://mgs-mager.gsfc.nasa.gov/
Additional NASA on Mars…
http://science.nasa.gov/headlines/y2001/ast31jan_1.htm
Mars…
http://www-ssc.igpp.ucla.edu/personnel/russell/papers/mars_mag/
Venus…
http://www-ssc.igpp.ucla.edu/personnel/russell/papers/venus_mag/
It just so happens Newton's gravity works as a pretty good approximation, quite beyond the accuracy of the data Newton had at hand.
Magellan's expedition circumnavigated the globe first and Aristotle never ever said the world was flat. Nor was it ever a common belief in the western world.
Newton also believed "That which causes fermentation" was a fundamental force of nature.
We're perfectly capable of thinking outside his 'box'. Tell me, why do you keep measuring your height in inches or centimeters when you know for a fact it's not an exact number of them?
I wasn't going to say anything else but I like that :smile:
I don't remember gravity making electrons or protons fly off into space either(As if there aren't enough nails in the coffin)
  • #31
Aha! And my Physics prof thought I was crazy for stating my height in plank lengths! :bugeye:
  • #32
whos to say that gravity is a pull and not a push.
  • #33
It's not a push.
  • #34
why is it not a push . i thought gr describes it as following the curves in space.
1. Does the existence of relativity mean that gravity is not real?
No, the existence of relativity does not disprove the existence of gravity. In fact, relativity and gravity are closely related and are both fundamental concepts in our understanding of the universe.
2. How does relativity explain gravity?
Relativity explains gravity as the curvature of spacetime caused by the presence of massive objects. According to Einstein's theory of general relativity, massive objects like planets and stars cause a distortion in the fabric of spacetime, which we experience as gravity.
3. Can relativity and gravity coexist?
Yes, relativity and gravity can coexist. In fact, relativity is one of the key theories used to explain the behavior of gravity. While relativity may have challenged our previous understanding of gravity, it has not disproven its existence.
4. What evidence supports the existence of both relativity and gravity?
There is a wealth of evidence supporting the existence of both relativity and gravity. This includes observations of the bending of light around massive objects, the predictions of the precession of Mercury's orbit, and the detection of gravitational waves.
5. Can relativity and gravity be tested?
Yes, both relativity and gravity can be tested through various experiments and observations. Scientists continue to test and refine these theories to better understand the workings of the universe. So far, they have stood up to numerous tests and have provided consistent and accurate explanations for the behavior of gravity.
  • Beyond the Standard Models
10K
  • Astronomy and Astrophysics
15K
