Does the Immirzi Parameter Determine Black Hole Entropy in Loop Quantum Gravity?
  • Level: Graduate
  • Thread starter Thread starter Physics Monkey
    Parameter
60 replies · 19K views · last reply
Homework Helper
I would like to discuss a puzzle I'm wondering about in loopy approaches to quantum gravity.
The puzzle is roughly as follows:
The Immirzi parameter (IP) is a strange constant that appears in loopy approaches. Calculations of black hole entropy in loopy approaches seem to need to fix the IP to be a particular value to agree with semi-classical entropy calculations. On the other hand, http://arxiv.org/abs/0809.2280 suggests that the IP plays little role in establishing the semi-classical limit of certain spin foam models. So what gives? Have I misunderstood something elementary? Will we find that the IP is given by the black hole value via other means? If not, what do the loopy approaches describe when the IP is not tuned to the black hole value? It almost seems impossible to have a semi-classical limit of GR for all IP, but only be able to reproduce the semi-classical black entropy for a particular IP.
Please let's keep the discussion to the science as much as possible. Thanks!
I don't know. I wonder if it is true for all the major spin foam models (Barrett-Crane, EPRL, FK). Also, I don't know how exactly each of these can be joined to the canonical spin network framework that Krasnov was presumably using.
I'm glad to see you had the time to read that LQG paper! Since you have some time to devote to LQG, it would be efficient (for our discussion) if you would get the one "official" version under your belt by reading
http://arxiv.org/abs/1102.3660.
We may waste a lot of time if we jump around among different versions, as they were seen 3 years ago.
Things have settled down considerably since 2008! :biggrin:
The Immirzi plays an extensive role in defining coherent states and in studying the semi-classical limit of the current theory. As of today.
See page "Section V: Extracting Physics" starting on page 14 of the standard paper.
It will have a section on defining coherent states, and in particular the socalled "holomorphic" coherent states with SL(2,C) labels.
Page 8 gives a sketch of the mathematical role played by this parameter. The symbol used is gamma, see equations 42-47, 49 and 50. Basically it defines a class of SL(2,C) reps and a map from SU(2) to SL(2,C). Then gamma shows up in equation 57 on page 9.
This is the definition of the theory (it is defined by specifying transition amplitudes).
There is an alternative compact definition given in equation 60, where gamma also appears.
There is no inconsistency that I can see. Gamma is essential in defining the transition amplitudes that define the official version of the theory. And it is also essential in any discussion of the semiclassical limit of the present official version of the theory and in any other aspect of "extracting physics".
You might like to read the "extracting physics" section. It covers a half-dozen topics and is only about 6 pages long.
We shouldn't always be jumping around amongst different people's versions many of which have been superseded or effectively abandoned. More efficient to stick with the one version.
marcus, which is the paper where EPRL is related to the old LQG spin network states?
That's the only connection between the spin foams and old LQG, or are there others?
Atyy, I'm not sure what you mean by "EPRL".
There is one Loop Gravity theory, now. That is what the Zako school meant and the way the Zurich conference is coming together. It makes predictions and (besides completing, elaborating) the job is to test it.
In the defining paper 1102.3660 he gives three equations and then says "This defines the theory."
In folk vernacular, this nails the coonskin to the wall.
Every question we ask about Loop Gravity from now on, every conclusion we draw, refers to 1102.3660.
I can't be sure what you mean by EPRL because unless you specify that term might refers to some 2007 papers, or maybe some 2008 papers etc etc.
The first time I ever saw the present version of Loop was in March-April 2010 and it is RADICALLY different. It does not use a spacetime manifold! And the first reasonably complete presentation is 1102.3660---what I am calling the "offiicial" version.
Drastically redefining like this was a bold move, it might have misfired, but it looks like the Marseille group is carrying it off.
So what kind of "connection" are you looking for? The explicit mathematical connection is explained in 1102.3660 and is based on the Peter-Weyl theorem.
Remember we are in H-sub-Gamma, a graph Hilberspace.
All the possible spin networks are just the possible labelings of that graph Gamma, with irreducible representations.
Courtesy the Peter-Weyl theorem these form an orthonormal basis for the Hilbertspace.
It is in the paper---the connection with the usual idea of spin network---if you look for it.
The relevant section of what is now our defining LQG paper is on page 5. It is the section headed "Spin network basis."
There really is no need for a "connection", is there? They are the same familiar spin-labeled graphs as before.
It's rather elegant that they arise in a GFT-like setting where you do not have a spacetime manifold! You have a Hilberspace of integrable functions on a group manifold, and the same old spin networks arise as an orthnormal basis of that vectorspace!
Ok, so basically it looks like the Immirzi parameter remains in the EPRL asymptotic analysis, but apparently not in FK. EPRL does connect to the old LQG formalism, but FK? OTOH, FK overlaps with EPRL for some values of Immirzi, so what is going on?
BTW, EPRL is http://arxiv.org/abs/0711.0146 .
I am not sure what you mean either by EPRL or by FK. There was a lot of confusion in 2007-2008 and when the dust settled there was something that didn't really look like either.
What do you mean by "FK"? Has it been shown to be Lorentz invariant? Does it have fermions? Does it have general spinfoams with more than 5-valent vertices, not necessarily dual to some triangulation? Has it been shown to give quantum cosmology with a quantum corrected Friedmann equation? Does it have a comprehensive entry-level presentation? Does it have a presentation in terms of Feynman rules?
Maybe it is not fully developed.
I didn't see any discussion of it lately, like at the Zako school.
So why are you talking about "FK"? Maybe it was subsumed in today's theory.
Let's refer to actual 2010 and 2011 papers.
If someone wants to read about the HISTORY there is a very nice history paper
http://arxiv.org/abs/1012.4707
"Loop quantum gravity: the first twenty five years"
It covers the past 25 years and it will certainly describe the various attempts.
atyy said:
Then let's avoid mentioning either of those papers. Today's Loop Gravity is very different.
I think it is pointless to argue now about which group had the biggest influence on todays LQG.
That is history.
We are on a completely new footing now. The presentation is clearer and better than it was back at the 2007 origins. Let's avoid free-floating references to stuff before 2010 and bothering with these acronyms.
Probably all these pre-2010 papers contributed important insights. These useful contributions and historical points would be brought out in footnotes and references in the current papers.
If you are really interested in the history, if the 2007 developments have a special fascination for you, maybe we should have a special history thread and try to go through that 1012.4707 paper "The First 25 Years."
Right now I see that as a low priority distraction. I want to understand the physics, not the history, and the physics is in 1102.3660.
That is history.
Well, I guess LQG has only one paper. What a small field.
Actually something over 150 LQG papers in 2010-2011.
I've suggested we use 2010 and 2011 papers in our discussion. There are loads and loads. More than we can keep track of really :biggrin:
I'd narrow it down further than that.
It's distracting to have quotations picked out of context from earlier papers which may have contributed greatly in their day but don't contain the most recent understanding.
It really helps to try to stay abreast of the field.
Just for fun, I did a check with Inspire:
http://inspirebeta.net/search?ln=en...2y=2011&sf=&so=a&rm=citation&rg=50&sc=0&of=hb
It finds 128 Loop gravity/cosmology papers in 2010 and 30 so far in 2011, so 158 in all.
You must subtract all papers that deal with EPRL and FK.
marcus said:
Actually something over 150 LQG papers in 2010.
I have to say that, for the last 10 yrs it's been extremely difficult to figure out what LQG is doing because everyone seems to have their own pet theory. At any given time, there were several spinfoam models, CDT, BF theories. Some papers are about semiclassical physics, like the one PM cited in the OP, others are not. Some methods are purely topological and therefore don't seem to have any propagating degrees of freedom. It's difficult for even a theoretical physicist to figure out that any particular approach is worth learning.
Perhaps at some point we can try to figure what old results apply in the new framework. Does the BH entropy calculation change, LQC and the bounce, etc?
Anyway, to try to say something on topic, I believe in the paper cited in the OP, they claim that the Immrizi parameter drops out because their analysis is semiclassical and the classical physics should not depend on the parameter. There were also a couple of papers that came out this month on semiclassical approaches, one on BF and the other on black holes (both listed in the running thread that marcus keeps), that also derive results that seem to be independent of the Immrizi parameter.
Basically, I disagree with marcus's reading of the current literature. My reading is as follows.
1. The key models are in fact EPRL http://arxiv.org/abs/0711.0146 and FK http://arxiv.org/abs/0708.1595 .
2. The semiclassical limit of a component of the EPRL and FK path integrals appear to go as ~ exp(iSRegge) http://arxiv.org/abs/0902.1170 , http://arxiv.org/abs/0907.2440 , http://arxiv.org/abs/0809.2280 .
3a. As Physics Monkey brought up, the Conrady and Freidel paper on the semiclassical limit of FK seems to get a term that is independent of the Immirzi parameter.
3b. The Barrett et al papers on the semiclassical limit of EPRL seems to me to contain the Immirzi parameter.
3c. I don't know whether the difference between the Conrady and Freidel results is because they are calculating the same thing in different models, or slightly different things in different models.
3d. I believe the EPRL and FK models overlap for some range of Immirzi parameter, so they are not entirely different models.
4. I haven't followed the LQG black hole literature, but the key original paper seems to be http://arxiv.org/abs/gr-qc/9710007 , with more recent papers being http://arxiv.org/abs/0905.3168 , http://arxiv.org/abs/0905.4916 , http://arxiv.org/abs/0911.3553 , http://arxiv.org/abs/1101.3660
... what old results apply in the new framework. Does the BH entropy calculation change, LQC and the bounce, etc?
The 22-pager I mentioned discusses what results apply in the new framework.
Much of the work in the past year seems to have been devoted to making sure.
There is a paper by Battisti and Marciano about the bounce.
You should be happier now that there is effectively one "official" version.
It is the Marseille group's version but it draws on everybody's work.
And it is formulated unambiguously as a theory, not as an "approach" or a theory-in-the-making.
It's a bold move, we'll see how it goes. There are risks in going from an "approach" or a bunch of tentative formulations to an actual theory.
For anyone who wants to follow the field, it has become a lot simpler to do this since
1102.3660 appeared and got recognized community approval by being featured at the Zakopane school.
Another key sign is the increased exchange of postdocs between Penn State and Marseille.
Ashtekar just took in Magliaro and Perini (who helped formulate the present version)
and the exchange is both ways.
We still don't know if the field will now cohere around this version. But what I see happening says yes, it will go. And in any case there is a theory which phenom'sts can test
I'm glad to find someone here who has been watching LQG for 10 years, as I gather you have from what you say.
I only started watching the field in 2003, not quite as long as you.
The FKand EPRL models are the same for Immirzi parameter <1 (which is the region needed for the Krasnov calculation to match the Bekenstein-Hawking result). Conrady and Freidel http://arxiv.org/abs/0809.2280 get a semiclassical limit without IP dependence , while Barrett et al http://arxiv.org/abs/0907.2440 get terms with and without IP dependence depending on their boundary states (Eq 53, 54). I wonder if Conrady and Freidel in fact assumed boundary states more like those in Barrett et al's Eq 54.
This is unwise in my opinion. I don't know any practicing scientists who restrict themselves to only the most recent work, especially not short review articles. For example, there is all kinds of juicy information in older works that get absorbed into the collective consciousness and stop being repeated. I would prefer it if people contributing to this thread felt free to bring in any paper they liked if it contains useful information about the physics in question.
This is interesting, the claim would be that new black hole entropy calculations don't depend on the Immirzi parameter? Or perhaps we should think of the IP as being absorbed into Newton's constant in the semiclassical limit? I shall have to try and track down the paper you mentioned, unless you have a reference off the top of your head.
Interesting, so you're suggesting that perhaps Conrady and Freidel assume something too specialized to see IP dependence?
Perhaps it would be useful to understand to what extent the Planck length, Newton's constant, and the IP are separate entities. They appear multiplying each other in a specific way in the black hole computations. The usual equation is [tex]\ell_P^2 = \gamma G_N[/tex] neglecting some constants (there is typo in one of Rovelli's lectures on this point). Nevertheless, in semi-classical GR what appears directly is [tex]G_N[/tex] while what appears directly in LQG seems to be [tex]\ell_P^2[/tex]. So I continue to feel that unless I'm making some trivial mistake, then somehow the semiclassicl limit should only work if the IP has a specific value. Otherwise we can compute black hole entropy in two different ways and get two different answers.
Marcus, I'm trying to be polite. Please stop lecturing us all on what papers/sections we should read before discussing. You've given those references in every thread over and over again, so we got it already. And yes, I can read the equations and see the Immirzi parameter appearing. It clearly plays an important role in formulating the full theory, nevertheless the claim is made in the paper I cited that it drops out in the semiclassical limit.
If you have some actual insight into what is going on, I would really like to hear it. I know you've spent a long time thinking about the theory. However, please stop spamming the thread with passive aggressive suggestions of papers/sections we should read. I'd like to think we're all looking for a little more than simply reading the answer, namely some real analysis and synthesis.
My apologies for the tone of this reply.
Interesting, so you're suggesting that perhaps Conrady and Freidel assume something too specialized to see IP dependence?.
Yes, but that's just my guess, based on the assumption that Barrett et al have the state of the art for EPRL (although there are later expositions that are clearer, I don't think anyone has challenged their results), and that FK and EPRL are the same for IP<1.
One thing I'm not clear about is the difference between the classical and semiclassical limit, and which is being taken where. The IP must disappear in the classical limit, and Conrady and Freidel say their result is consistent with that. Funnily, I'm not sure that everyone agrees that LQG needs IP<1 although that's what the black hole entropy calculations suggest. Eg. http://arxiv.org/abs/0909.0939 , which try to adjust EPRL and FK to harmonize better with canonical LQG say "the works that should be and will be considered closer in the spirit of the current paper, are the Freidel-Krasnov model [15] (especially in the range of in which that model does not overlap with EPRL)"
I wonder if he's thinking of http://arxiv.org/abs/1103.2723 , scanning it quickly it looks like the leading blakc hole entropy term has IP dependence but it the first correction doesn't, which is the IP independence claimed.
I should say that in case the irony hasn't been seen, all the recent Rovelli reviews have been about EPRL.
Yes, that's one of them. I'd cited the paper based on some of the comments I'd read, but had not really figured out what they computed. It seems like their model has the Immirzi parameter and the Chern-Simons level [tex]k[/tex] as free parameters, following http://arxiv.org/abs/1011.2961 I haven't checked the references, so I do not know if there is a physical significance to the level. The 1103.2723 paper claims that one recovers the usual value of the IP from the spherically symmetric model as [tex]k\rightarrow\infty[/tex].
In any case, the 1011.2961 paper states in the abstract that
"By defining a statistical mechanical ensemble where only the area A of the horizon is fixed macroscopically-states with fluctuations away from spherical symmetry are allowed-we show that it is possible to obtain agreement with the Hawking's area law---S = A/4 (in Planck Units)---without fixing the Immirzi parameter to any particular value: consistency with the area law only imposes a relationship between the Immirzi parameter and the level of the Chern-Simons theory involved in the effective description of the horizon degrees of freedom. "
and the 1103.2723 paper computes the leading correction to the area law.
Without knowing the fundamental significance of the level in these calculations, I wouldn't begin to consider the implications of the results.
The other paper I was thinking of was this one:
marcus said:
http://arxiv.org/abs/1103.2971
Gravity as a constrained BF theory: Noether charges and Immirzi parameter
R. Durka, J. Kowalski-Glikman
5 pages
(Submitted on 15 Mar 2011)
"We derive and analyze Noether charges associated with the diffeomorphism invariance for the constrained SO(2,3) BF theory. This result generalizes the Wald approach to the case of the first order gravity with a negative cosmological constant, the Holst modification and topological terms (Nieh-Yan, Euler, and Pontryagin). We show that differentiability of the action is automatically implemented by the the structure of the constrained BF model. Finally, we calculate the AdS--Schwarzschild black hole entropy from the Noether charge and we find that, unexpectedly, it does not depend on the Immirzi parameter."
They suggest that the IP is somewhere hidden in the translation between microscopic variables and the effective ones that they're using.
They cite a really interesting 2007 paper by Ted Jacobson. I think someone already gave the link but I will get it. As I recall he put the Loop community on notice that they would eventually have to face the problem of G running. And this would come out in the black hole analysis.
That is one of those papers where you wait for years for the other shoe to drop. He has written more than one of those.
T. Jacobson, “Renormalization and black hole entropy in Loop Quantum Gravity,” Class. Quant. Grav. 24 (2007) 4875-4879. [arXiv:0707.4026 [gr-qc]].
http://arxiv.org/abs/0707.4026
Ted Jacobson
8 pages
(Submitted on 26 Jul 2007)
"Microscopic state counting for a black hole in Loop Quantum Gravity yields a result proportional to horizon area, and inversely proportional to Newton's constant and the Immirzi parameter. It is argued here that before this result can be compared to the Bekenstein-Hawking entropy of a macroscopic black hole, the scale dependence of both Newton's constant and the area must be accounted for. The two entropies could then agree for any value of the Immirzi parameter, if a certain renormalization property holds."
This "Immirzi puzzle" topic is raised by Rovelli on page 16 of his December review paper and discussed briefly. You might be interested in what he has to say about it, if you haven't already read this. It may be very similar to what has already been said in some posts in this thread, but differences in perspective (if there are any) could be interesting.
Of course he cites the Jacobson 2007 paper about renormalization and BH entropy (here reference [144].
==quote 1012.4707==
However, the result is not entirely satisfactory in my opinion. It is not strange that a fundamental parameter in the theory could have a peculiar value such as γo: we do not understand the origin of other fundamental constants, such that the fine-structure constant. But it is strange, and perplexing, that there be such a peculiar parameter in the theory, which then cancels exactly with a number that characterizes a complicated statis- tical counting, in such a way to give a round number such as 4 in (43).17 I think that the sense that there is something important which is not yet understood is unavoidable.
17 In addition, as pointed out by Ted Jacobson [144], radiative correction could play a role, affecting the Area observable and the coupling constants. In particular, the G entering (43) is the Newton constant at large distance, while the G entering (44) might be the Newton constant GPlank at the Planck scale. So that we should rather pose
γ = γoGPlank/G (46)
and the numerical value of γo could perhaps reappear in the relation between Plank scale and infrared physics.
==endquote==
I thought that was an excellent reply! Expressed values we both share and very polite given the circumstances. I think both you and Fzero have read the recent LQG papers and some one of you even pointed out a typo! I think in the February "Lectures" paper. I appreciate your recognizing that there was a reconstitution of Loop in 2010 and proceeding from there.
My reciprocal apologies for strident repetition of this fact!
What you said about "we get it already" was very welcome indeed! For anyone else reading the thread, the papers we are talking about that redefine LQG as a theory (this is not for Atyy, Fzero, PhysicsMonkey since all are well known to them) are:
http://arxiv.org/abs/1010.1939
Thanks for pointing out the Jacobson paper. Some digging actually turned up a paper by Susskind and Uglum http://arxiv.org/abs/hep-th/9401070 that makes essentially the same point about the interplay between renormalization of the BH entropy and gravitational coupling. Further evidence for this is described by Larsen and Wilczek in http://arxiv.org/abs/hep-th/9506066 Both papers discuss the result in the context of matter coupled to canonical gravity in the limit of large BH mass.
marcus, why do you say there was a reconstitution in 2010? The 2010 papers are reviews - the reconstitution was in 2007/2008 with the EPR model (now superseded), and then FK and EPRL, which overlap for IP<1, as well as the demonstration of nice asymptotic properties by Conrady and Freidel, and Barrett et al. EPRL is the subject of all the 2010/2011 reviews.
Also, old LQG is still in play, Rovelli does cite Kaminski et al in the same breath that he cites EPR,FK and EPRL (http://arxiv.org/abs/1102.3660 , p10, just after Eq 59, "This vertex amplitude (56-57) has been found independently by different research groups [30-35]"). Kaminski et al try to fix EPRL/FK to agree with canonical LQG. The whole black hole business is also in canonical LQG, as is most LQC, even the Ashtekar and Henderson stuff. Only Vidotto's LQC tries to begin from EPRL.
atyy said:
marcus, why do you say there was a reconstitution in 2010? ...
Well should we start a separate thread? So as not to clutter up PM's thread about the Immirzi? Or can you propose a thread where this question is germane or already being discussed?
You say what we should do, if we should move this side-discussion somewhere.
  • The 2010 reformulation has no spacetime manifold.
  • The exposition stresses striking analogies with BOTH lattice QCD and Feynman diagram QED.
  • In the 2010-2011 Rovelli gives a particular Hilbertspace, then he gives three equations, then he says "This is the theory." Or he says, "This defines the theory."
  • He doesn't call it EPRL and the way vertex amplitude is computed is different from how I recall EPRL.
  • He calls it "Loop Gravity".
AFAIK all those different acronyms EPR, EPRL, FK, EPRL-FK, merely refer to different proposed ways of calculating a spinfoam vertex amplitude. That is not a whole theory.
Vertex amplitudes are crucial but you still have to back off and decide how you are going to formulate transition amplitudes between spin network states of geometry.
Then there is the question of coherent states. The new formulation comes with holomorphic coherent states. It also comes with a rigorous proof of lorentz covariance. It comes with a couple of rather elegant ways to calculate the vertex amplitude which are NOT the original EPR or EPRL or FK, ways as far as i know. I don't see any 12j symbols. What I see instead is a map from SU(2) group representations to SL(2,C) representations.
I'm not saying you can't go back and forth and establish EQUIVALENCES between these things. What I'm saying is that the 2010 reformulation looks much more substantial and more like a theory to me. BTW also more mathematically beautiful.
And Rovelli calls it a theory, rather than an approach. 2010 is the first time I recall him saying "This defines the theory."
So I call it 2010 reformulation rather than 2007 or 2008 or whatever because that was the year the pieces came together and he ran the theory flag up the mast. Now it could be shot down in various dignified ways---there is something there to shoot down. Maybe it will be and maybe it won't be.
Maybe this storm over the Immirzi and the Black Hole entropy will destroy it, and maybe it won't.
Please tell me if I'm missing anything important, Atyy. And if you still want to discuss and say I should use the term "EPRL" and the date 2007 or 2008, then just say and we can start a separate thread. In some sense it's partly just a matter of taste.
Meanwwhile, the current Immirzi emergency is potentially exciting, isn't it? Alarm bells going off. I have the highest regard for both Jacobson and Kowalski-Gllkman, so I think something transformative may come out of it.
In http://arxiv.org/abs/0902.0351 which is the follow up to http://arxiv.org/abs/0809.2280 , Eq 133 contains the Immirzi parameter. Their comment on the relationship to the result without the Immirzi parameter is "One can show (directly or using the results of [5]) that these terms drop out when the saddle point approximation is applied to a bulk region consisting of several 4–simplices."
In http://arxiv.org/abs/1003.1886 , Fairbairn comments on the relationship between his calculation (Barrett et al) and that of Conrady and Freidel's "In this paper, we summarise the results obtained in [1, 2, 3], where an asymptotic analysis of the 4-simplex amplitudes for the Ooguri model [4] of topological BF theory and for both Euclidean and Lorentzian versions of the EPRL model [5] of quantum gravity was performed. For an asymptotic analysis of the whole amplitude Z(M) for a closed manifold M of Euclidean signature see [6, 7]."
So my guess is that the large spin limits taken here involve assumptions that make it not a black hole (although still involving the IP in some cases). In http://relativity.phys.lsu.edu/ilqgs/panel050509.pdf , p3, Ashtekar, following Perez, says he expects an isolated horizon to be dominated by small spins.
Atyy, thanks for the links and summaries. It's a pleasure being able to connect with an extra pair of eyes and memory for making connections. I'm still (ploddingly) assimilating what I quoted from Rovelli's december review paper, the section on BH entropy that referred to Jacobson's 2007 paper (one that's been in the back of my mind since it came out, waiting for the other shoe to drop.)
Here is the passage I quoted earlier:
http://arxiv.org/abs/1012.4707 (page 17)
==quote 1012.4707==
However, the result is not entirely satisfactory in my opinion. It is not strange that a fundamental parameter in the theory could have a peculiar value such as γo: we do not understand the origin of other fundamental constants, such as the fine-structure constant. But it is strange, and perplexing, that there be such a peculiar parameter in the theory, which then cancels exactly with a number that characterizes a complicated statistical counting, in such a way to give a round number such as 4 in (43).17 I think that the sense that there is something important which is not yet understood is unavoidable.
17 In addition, as pointed out by Ted Jacobson [144], radiative correction could play a role, affecting the Area observable and the coupling constants. In particular, the G entering (43) is the Newton constant at large distance, while the G entering (44) might be the Newton constant GPlanck at the Planck scale. So that we should rather pose
γ = γoGPlanck/G __________________ (46)
and the numerical value of γo could perhaps reappear in the relation between Planck scale and infrared physics.
==endquote==
Then there is the fact that the February papers, in many respects an excellent complete summary of the theory, omits all discussion of BH. I'm curious to see how this gets resolved.
