Does the Rocket Equation Accurately Describe Net Force?
The discussion revolves around the application of the rocket equation and its validity in calculating net force for a rocket. Participants are examining the formula Fnet=[m(Vf-Vi)]/Delta T and its implications in the context of rocket motion, particularly considering changing mass during thrust.
  • Participants are questioning the accuracy of the net force equation in relation to a rocket's changing mass. Some suggest rephrasing the equation for clarity, while others emphasize the need to verify its correctness. There are discussions about average force and the implications of Newton's second law.
Multiple interpretations of the net force equation are being explored, with some participants suggesting that the equation may not be valid for a thrusting rocket. Guidance has been offered regarding the need to consider the Tsiolokovsky rocket equation for accurate calculations, and there is a call for clearer problem framing to facilitate further assistance.
Participants mention specific measurements related to the rocket's mass and angles, as well as the timing of the thrust reaction. There is a noted lack of access to a solution manual for verification of the formula's correctness.
cashman91
is this equation true
net force is equal to the mass times the change in velocity all over time
thanks a lot
thanks a lot
Well if it was reexpressed as
[tex]F_n_e_t=m(\frac{v_f-v_i}{\Delta t})[/tex]
Does that help?
It should be the average force over time delta t in place of Fnet.
the formula malty gave is correct but how can you verify this formula is correct
I get where shooting star is coming from but i need to find the net force of the rocket
so far all i know is my two inclinometer reader posted scores of 53 and 54 degrees with a time of 1.03/1.07 seconds the mass of the rocket and the mass of an empty and full engine
i can solve the net force but i need to verfiy the formula is correct or not
this formula came out of a Nelson physics 11 book i don't have access to the answer manual if i did it would tell me if this formula is correct or not
malty and I have given the same formula.
Does the book define what is net force? Why don't you tell us what is meant by that? It's also a good idea to state the problem completely and show what you've done so far.
See attached jpeg for my attepmt
I need to find the
F(thrust)
F(net)
Acceleration
Fg
Vmax
I can find Eg and Ek easily myself but the problem is with the rest
Vf would be zero becasue the rocket is at the top of it height
soooo... would Vi be 65.0m/s
If Vi is 65.0 m/s then using your formula
Fnet would equal 8372.878 Newtons**
** the (mass of the rocket full with engine)+(mass of the rocket empty)/2** is the mass of the rocket assuming the reaction is constant
am i correct?
The equation [itex]\bar F = m(v_f-v_i)/\Delta t[/itex] is a direct consequence of Newton's second law and the mean value theorem for an object with constant mass. That equation is not valid for a thrusting rocket since the mass of a rocket. You need to use the Tsiolokovsky rocket equation, [itex]\Delta v = v_e\ln(m_{init}/m_{final})[/itex]. For more details, see https://www.physicsforums.com/showthread.php?t=199087".
Tsiolokovsky rocket equation i have the intial mass(beofre lauch) and final mass(after launch)
we timed how long the reaction(white smoke) took before the rocket flew so how could i findout the Ve of my rocket
thanks inadvance
cashman91
Now perhaps you understand why I'd asked you to state the problem completely. There was no indication in your first post that mass was changing. Let's wait for the attacment to get approved.
figured out my Vav is 31.71 m/s
height is 68.82m and time is 2.17s
Vav=(delta d)/(delta t)
still nedd help
anything
If you post the problem framing it properly in a single post, then people would be more inclined to help you. Maybe the whole thing is there, but nobody has the patience to gather up the pieces and fit them to find out the original problem.
I'm trying to help you.
  • · Replies 47 ·
