Does the use of error bars pertain to this experiment?
This discussion centers on the appropriateness of using error bars to evaluate the results of a real bench experiment compared to two computer models. The real test yielded a result of 2.70, while one model produced 2.71 and the other 2.80. The participant seeks to determine if the 2.80 result is acceptable relative to the other two. The consensus is that with only one result from each test, error bars may not provide a meaningful interpretation, and the situation may require a qualitative assessment rather than a purely mathematical one.
  • Understanding of error bars in statistical analysis
  • Familiarity with Normal distribution concepts
  • Basic knowledge of deterministic vs. random sampling
  • Experience in interpreting experimental results
  • Research the application of error bars in single-sample experiments
  • Learn about statistical methods for assessing the acceptability of experimental results
  • Explore techniques for estimating mean and standard deviation from limited data
  • Investigate the implications of deterministic models in statistical analysis
Researchers, data analysts, and statisticians involved in experimental design and result interpretation, particularly those working with limited data sets and seeking to validate model outputs.
hydronicengr
I'm currently performing a real bench experiment that would essentially validate the results of those generated in two different computer models.
Essentially, there is one (real) test setup, one computer model, and another (but different) computer model.
I have ONE result from each of the tests, so in total I have three numbers. The real test setup and one of the computer models are similar to each other at 2.70 and 2.71, respectively. The other computer model is 2.80.
I want to see if the last computer model result of 2.8 is "acceptable" or falls "within range" of the other results.
I was told to use error bars, but I'm not sure if this would be the best approach.
If you have one result from each test and this result is not the average of many other replications of the test, then I can't think of any reasonable interpretation of your question which has a convincing mathematical answer.
Perhaps you have a sociological problem, not a mathematical problem. Are you preparing a report or briefing or article that will be evaluated by other people. If so, you should look at other reports or briefings that they liked and copy whatever methods were used.
Your request to determine whether 2.8 is "acceptable" doesn't define a specific mathematical problem. The best I can do to mind read what you want is to day that you want to assume that the number 2.70 and 2.71 are drawn independently from the same Normal distribution and you want to compute an estimate of the mean and standard deviation of this distribution. Then you want to draw a bar whose center is the estimated mean and whose width is a certain number of the estimated standard deviations. You can certainly do that. It isn't a mathematical proof of anything.
If two of the numbers come from deterministic models, it would require some verbal contortions to explain how they come to be viewed as "random" samples. I suppose you could claim that the decisions made in creating the simulations involve some random choices.
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
  • · Replies 25 ·
  • · Replies 26 ·
  • · Replies 16 ·
