Does This Limit Chart Indicate a Nonexistent Limit?
  • Thread starter Thread starter m_s_a
    Limit
12 replies · 3K views
m_s_a
hi,
find this limit
Yes, the fact that [itex]x\sqrt{A}= \sqrt{x^2A}[/itex] (and the fact that square root is continuous wherever it is defined) makes the problem simple.
In any case, m s a, this is clearly school work which should have been posted in the "Homework and Coursework" section so I am moving it there.
Also, as you should already know, you MUST show what work you have already done and what thoughts you had about it so we will KNOW what help you need.
Thank you all tried to find the end
but the fee is quite different
These endeavours
Where is the error??
These endeavours
I don't understand what you just wrote. :confused:
Can you properly state your question please?
CS
Yes,. the problem is what stewartcs pointed out. If x> 0, then [itex]x\sqrt{4+ 1/x^2}= \sqrt{4x^2+ 1}[/itex] and that has limit 1. But is x< 0, then [itex]x\sqrt{4+ 1/x^2}= -\sqrt{4x^2+ 1}[/itex] and that has limit -1. The "limit from above" is 1 and the "limit from below" is -1. Since those are different, the limit itself does not exist.
m_s_a said:
chart shows that the end does not exist
Correct, the limit does not exist.
CS
