Does time dialation cause mass reduction in GR?
29 replies · 4K views
goldk
I love Physics!
I've been thinking about if... you were in a room with a window, bouncing a ball... and you were looking at another building where you could see a room with a person bouncing a ball, but ... their time was moving at half speed (Caused by gravitational time dilation only ( not speed)) ... you weigh 170 lbs with respect your scale and they weigh 170 lbs with respect to their scale.
To you.. their ball is also going half speed. ...
Now, somehow you give them your weight scale. Your scale is still on your time though. When they weigh themself your scale would read 85 lbs because the gravity there is only 1/2 the gravity of your time.
My question is... Is their mass half your mass?
This is the sticking point in your scenario. How, exactly, are you going to give them your scale while keeping it "on your time"?
Thank you for the question. I did say "somehow". It doesn't matter how they would weigh themself on your scale as much as it would be an observation from your perspective. It equally would be hard to set up this scenario in the real world.
Just think of ... from your perception... they would weigh less, but does that also mean the matter has less mass?
reference...
From Wikipedia... In physics, mass (from Greek μᾶζα "barley cake, lump (of dough)"), more specifically inertial mass, can be defined as a quantitative measure of an object's resistance to acceleration. In addition to this, gravitational mass can be described as a measure of magnitude of the gravitational force which is
1.exerted by an object (active gravitational mass), or
2.experienced by an object (passive gravitational force)
when interacting with a second object. The SI unit of mass is the kilogram (kg).
Mass is invariant in SR and in GR. If the scale is "somehow" designed such that it reads a smaller number for a moving object, then it isn't measuring mass.
How is mass invariant in Special Relativity when it is supposed to grow when the object is moving near the speed of light.
I am really more interested in gravitational time dialation.
In the scenario, I guess you could be in space with a telescope looking down on someone on a planet, bouncing a ball. Their time would be going slower with respect to your time. (For the sake of argument let's just say the gravitational mass is enough where the time on the planet is half the time with respect to your time frame.)
(without getting into large equations) Since it takes twice the time for the ball to reach the ground on the planet; then with respect to you, the ball is half the weight;... is it not?
There is more than one definition of mass. The mass DaleSpam is speaking of is the usual rest mass (or invariant mass) of an object in classical mechanics. This is always agreed upon by all observers. However, there is another type of mass, often called relativistic mass, that is important in special relativity. As you approach the speed of light in some observer's reference frame, this observer will note that you require a much larger force to accelerate. It's given by [itex]\gamma <br /> m[/itex]. This is what prevents someone from applying a strong enough force to propel you to the speed of light.
No, it isn't. Weight is calculated using the rest mass I mentioned above, which is invariant.
The invariant mass does not increase when the object is moving near c. What increases without bound is the total energy. Historically, some people doomed the term "relativistic mass" to refer to the total energy divided by c^2, but that is a concept which has largely been abandoned decades ago.
http://en.wikipedia.org/wiki/Invariant_mass
Gravitational time dilation has nothing to do with mass. You cannot just use Newtonian gravitation where gravitational time dilation is significant and expect to get sensible results.
What units plug in for γ? I know it is a time factor, but how do you use it?
No, it's the Lorentz factor. It is given by
[itex]\frac {1} {\sqrt {1 - \frac {v^{2}} {c^{2}}}}[/itex]
You can multiply by the time measured in some frame of reference to get the corresponding time measured in a reference frame moving with respect to it. Same for length.
EDIT: I can't seem to get the LaTeX working. Just do a google search for the Lorentz factor.
EDIT: Nevermind, fixed it.
Mark M said:
No, it's the Lorentz factor. It is given [tex]\gamma = \frac {1} { \sqrt{1- \frac {v^2} {c^2}}[/tex] You can multiply by the time measured in some frame of reference to get the corresponding time measured in a reference frame moving with respect to it. Same for length.
Thank you! This helps!
I think the equation E= γMc^2 can be used for both reference frames as far as velocity goes, however is it not just one way as far as gravitational time dilation goes?
In that equation, γm is the relativistic mass. However, it's just the mass, m, that is relevant to gravity.
I just realized that I left out a notable part of my scenario.
"In the scenario, I guess you could be in space with a telescope looking down on someone on a planet, bouncing a ball. Their time would be going slower with respect to your time. (For the sake of argument let's just say the gravitational mass is enough where the time on the planet is half the time with respect to your time frame.)"
If the planet (which has to be a neutron star) has enough gravity to double the time it takes for a ball to reach the ground and come back up... this is a conundrum... because with that much gravity wouldn't the ball's bounce period would be so rapid you couldn't even see it bounce? ?
Time is slower on the star, but the inertial mass seems huge. I'm probably still stuck in neutonian physics. :redface:
Firstly, let's ignore gravitational time dilation. Let's say the ball is being dropped on the star, as in your example. Because of the extreme gravitational pull, the ball will reach the ground in a very short period of time. Now, factor in time dilation. The up-and-down bounces can be thought of like the ticks of a clock. So, our observer in space will see them occurring slower than the observer on the star. Since the gravitational pull of the star is very strong, these periods may still be very rapid. But not as rapid as they are measured by the observer on the star.
Yes, I already mentioned this mistake above. Newtonian gravity is an approximation to GR only in the weak field limit (small mass, low speed, large distances). In any scenario with a significant amount of time dilation you are outside the regime where the approximation is valid. So trying to cobble together time dilation and Newtonian gravity is going to cause problems.
In GR the distant observers observation of a slow fall tells the distant observer something about the spacetime between them and the object, but tells them almost nothing about the mass of the falling object.
Can you be more specific? What problems?
In this case the problem is thinking that the "slower" fall observed due to gravitational time dilation represents some change in mass that needs to be accounted for. That is not the case, the slower fall still follows a geodesic of e.g. a Schwarzschild spacetime with the same mass parameter as detected at a higher altitude.
In other cases that I have dealt with they reached the conclusion that the laws of physics are different in different locations using similar reasoning.
The other thing to remember is that different masses fall at the same rate anyway.
So if you drop a feather and a cannonball on the Earth's surface, they'll both accelerate at 9.8 meters/second locally. So you can see that it would be futile to measure the rate at which something falls to determine it's mass.
Yet it seems that was the idea that started the thread as nearly as I can guess - an attempt to guess at something's mass deduced from how fast it falls.
I'm not sure what went wrong where, but clearly something is "funny" with the line of reasoning. Either that, or I've totally misunderstood the point :-(.
This is strictly true only as long as the mass is small enough to be a test mass. Ocasionally someone will mention that dropping even a feather moves the Earth slightly (which is true to some extent, though the details are complicated by the fact that the Earth isn't actually a point body so most calculations of how much it moves are suspect).
You all are great! Thank you for your input!
QUOTE]
Yes, I was trying to figure out if the mass was smaller, greater, or the same with respect to an observation point far away from the star. My question stemmed from a controversy concerning the schwarzchild proton theory. My thinking was that if we could prove that the mass actually shrinks with the elongation of time (time stopping in a black hole) then the theory's validity would hold better. I love to think about these things, but I have limited knowledge. Calculus 3 in college was a blurr :redface:
DaleSpam said:
The mass is the same, it is invariant, as I mentioned earlier.
Shoot! I thought I was onto sompthin! :eek:
In this case the problem is that you think that there is one "right" theory and all other theories are "wrong".
And so you think that by pointing out which theory is "right" you have made an argument.
But the thing is that all theories are "wrong".
As pervect explained your reasoning is faulty. But it does not mean that you question is faulty.
Not sure that schwarzchild proton theory is a valid topic here.
Please bear in mind that you can't prove things in science you can only confirm (or falsify) them.
Do you believe you are a psychic? You seem to believe that you know what I think even when I have not said any such thing.
My thinking is that there are at least four different sorts of mass in General Relativity. This is in contrast to SR, which only has a couple of candidates - one of which is mostly used in popularizations and one which is generally used in more serious paper - and Newtonian mechanics which has only one.
Furthermore, my thinking is that mass in General Relativity is an advanced concept, and that it would be much more productive to study something simple, first rather than worrying about all these different sorts of mases and their definitions and distinctions - many of which which won't make sense until one is more familiar with the basics of the theory in any event.
Trying to shoe-horn General Relativity into high-school "F=MA" physics is unlikely to be productive in the long term. Or to be productive in the medium term, even.
I'd suggest studying the principle of extremal aging, which will yield one an ability to correctly figure out how objects move in SR and GR, possibly using an undergraduate text like Thorne's "Exploring Black Holes" as a textbook.
Even learning some non-relativistic Lagrangian mechanics would be helpful - as the first baby steps of finding out that although you learned "F=MA" in high school, it's not the be-all and end-all of physics.
Thank you, I will definitely check out your suggestions.
Let's say we have scales high above the surface of the planet. We attach a rope to the scales that extends down to the planet's surface and then we calibrate scales to zero. Now we weigh test mass at the top of the rope and at the bottom and then factor out the change in strength of gravity and compare two measurements.
Result should be that the same mass measured at the bottom is smaller than as measured at the top.
And argument is that gravitational binding energy is lost when you bring mass to the surface and almost all of it can be attributed to the test mass. By energy mass equivalence test mass has been reduced by amount equivalent to gravitational binding energy.
