Mentor
- 11,193
- 4,041
Jimster41 said:but they have been observed in nature (as I understand it) and bear explaining don't they?
Yes - and QM explains it.
Here is the explanation. Consider two systems that can only exist in state |a> and |b>. If system 1 is in state |a> and system 2 in state |b> that is written as |a>|b>. Similarly if system 1 is in state |b> and system 2 in state |a> that is written as state |b>|a>. From the principle of superposition you can have a superposition of the two states such as 1/√2|a>|b> + 1/2|b>|a> and is the state I will illustrate what's going on with. Such a state is called entangled - neither system is in state |a> or |b> - in fact it turns out they are now in mixed states - but I won't go into that here. Now let's observe system 1. Because it only has two states you must get |a> or |b>. If you get |a> then system 2 must be in state |b>, and similarly if you get |b> system 2 is in state |a>. Entanglement is broken and you can see the results are correlated by the way they are entangled. There is nothing mysterious going on - its fully explained by the principles of QM.
The issue is if you have an EPR type set-up where you observe each system at any distance apart. So that means if you observe system 1 you immediately know the state of system 2 that can, theoretically, be on the other side of the universe. That's all there is to it. It's not mysterious. Its simply an application of the principles of QM.
Thanks
Bill
