Does weight affect braking distance for transport trucks?
  • Thread starter Thread starter phil4321
    Braking Weight
The discussion revolves around the relationship between the weight of transport trucks and their braking distances. The original poster questions a claim made by a driving instructor that a fully loaded truck stops faster than an empty one, suggesting that increased weight should lead to greater momentum and longer stopping distances.
  • Participants explore concepts of momentum and friction, questioning how weight affects braking force and distance. Some discuss the role of the coefficient of friction and how it may vary with weight. Others raise concerns about the complexity of real-world factors affecting braking in loaded versus unloaded trucks.
The discussion is ongoing, with various perspectives being shared. Some participants provide insights into the physics of braking, while others express skepticism about the instructor's claim. There is no explicit consensus, but several points of view are being examined, including the effects of inertia and the role of tire friction.
Participants note the complexity of real vehicle dynamics, including tire pressure, center-of-mass location, and braking system differences between loaded and unloaded trucks. There are also questions about the relationship between the number of wheels and friction, indicating a need for further clarification on these topics.
phil4321
Hi I am new to the forums and i'll try and keep this short and sweet.
A couple weeks ago i started going to driving school, its boring but necessary. On the first day she said (the teacher) that a fully loaded transport truck will take LESS time to stop than an empty one. her reasoning for this is the weight of the truck pulls it down and slows it faster. i know this cannot be right becuse the weight of that cargo is going to carry momentum and is going to be harder to stop. My dad has been driving truck for 30+ years and he agrees with me, so I am pretty confident with my side of the argument but i need a way to prove it. I've been looking on the net for the past while but the math involved with it is way over my head and i can't find one that involves weight either. Do i need to find the kinetic energy first before i can solve this. i found an equation to find the KE that take speed and weight into factor but i couldn't find an equation that finds braking distance when you know the kinetic energy. if some one knows an equation i could use for this, or some way i can find this out it would be greatly appretiated.
ps: a site supporting my side would work too but if i had the math to back it up she can't really argue with that. and that would really be supperior
thanks a lot
phil
it's an issue of momentum and friction force.
friction force is proportional to the "normal" force, [itex]F_n[/itex],, the component of all resulting forces acting on an object that is "normal" or perpendicular to the surface. often the normal force is simply the weight of the object.
there are, in classical mechanics, two constants of proportionality. 1. the coefficient of static friction, [itex]k_s[/itex], which governs the maximum force (parallel to the surface) needed to dislodge the object from sticking to the surface and skidding. 2. the coefficient of kinetic friction, [itex]k_k[/itex], which governs the force of friction when the object is skidding. these coefficients of friction are dependent mostly on the materials of the two surfaces rubbing together. (so there is some coefficients of static and kinetic friction for rubber against road.) usually the coefficient of static friction is greater than the coefficient of kinetic friction. (it takes more push to get your refridgerator to start sliding than what you need to keep it sliding.)
assuming that the brakes are applied to the maximum degree so that slippage between rubber and road (or skidding) does not occur, that's where the maximum braking can occur.
the bracking force is
[tex]F_b = k_s F_n[/tex]
the normal force is the weight which is proportional to the mass.
[tex]F_n = m g[/tex]
where [itex]g[/itex] is the acceleration of gravity. so the braking force is
[tex]F_b = k_s m g[/tex]
and that braking force is proportional to the deceleration [itex]a[/itex] of the vehicle
[tex]F_b = k_s m g = m a[/tex]
so the deceleration due to braking is
[tex]a = k_s g[/tex]
independent of the mass of the vehicle. the increased mass increases the braking force, but it also increases the momentum by the same factor. if the vehicle was on a slippery surface, [itex]k_s[/itex] would be less and the vehicle would decelerate more slowly. if the vehicle was on the moon, [itex]g[/itex] would be less and the vehicle would decelerate more slowly. also if the vehicle is pulling a trailer which does not have braking on its wheels, that increased mass from the trailer and load contributes to the momentum, but not to the braking force because only the pulling vehicle weight is pushing down on its wheels (that have brakes), so it decelerates more slowly.
if you know the velocity when the brakes are applied, the braking distance is:
[tex]d = v t - \frac{1}{2} a t^2[/tex]
and since the final velocity is zero
[tex]0 = v - a t[/tex]
then you can calculate the braking time
[tex]t = v/a[/tex]
and
[tex]d = v (v/a) - \frac{1}{2} a (v/a)^2 = \frac{v^2}{2 a} = \frac{v^2}{2 k_s g}[/tex]i think your teacher is wet. it is possible that the increased weight and normal force somehow increases this coefficient of friction (which would increase the deceleration), but she would need some kind of experimental evidence to support that.
A real vehicle is much more complicated than that. Tires have an effective friction coefficient that is not really constant. It decreases slightly with increasing normal force (weight). That usually implies that braking times are worse when more mass is added, which is one reason that race cars are kept as light as possible.
But there are many other factors to worry about on a large truck. A loaded semi is very very different from an unloaded one. The weight is obviously completely different. The tire pressures would also have to be changed. The center-of-mass location changes, which affects the optimal split in brake pressure between the different axles. There are probably details in the braking system which are changed to account for this. So comparing loaded and unloaded trucks to each other isn't very simple at all.
Assuming same speed, same brake friction, same road friction on a perfectly flat surface a heavier truck will always take longer to stop due to higher inertia. But it is possible that brake friction and road friction is increased due to more force pushing down, but I seriously doubt that it is enough to counter the change in inertia.
~Gelsamel
(And yes I'm too lazy to do any math, you'll just have to take my word for it).
No. As rbj showed, braking distances do not depend on weight when the friction coefficient is constant. More force can be generated by the tires with more weight on them, which exactly makes up for the extra inertia. But the case of identical friction isn't all that great of an idealization.
If you wouldn't mind me bringing this up as well, I had difficulty understanding this.
For a given weight of a truck for example, why does increasing the number of wheels not increase the friction acting on the truck? I would have thought more tires would spread out its weight but also offer more resistance since there is more contact with the ground?
alright picture this, instead of to semi's we have a car and a motorcycle.
which is going to stop sooner? obviously the bike. why? becuse it weighs next to nothing compared to the car. to me its not wether a heavier vehicle takes longer to stop, i know it does.
i just wanted to prove this drving instructor wrong, cause i know she is wrong. i just don't know how to do it
Actually, that's not true. A high performance sportscar and a sportbike stop in about the same distance. And given the big difference in mass like you pointed out, that kind of shoots down the idea that braking distance depends on mass (given equal friction coefficients and equal brakes). Both the sportbike and sportscar are able to brake at the edge of traction, which gives you the shortest stopping distance. The sportbike can out accelerate most sportscars, because it has a better engine power to overall weight ratio. That's where a sportbike has the edge, not necessarily in braking.
BTW, your driving instructor is definitely wrong in saying that a loaded truck will stop faster than an empty one. It will generally be the other way around, because a fully loaded semi does not have good enough brakes to stay at the limit of traction effectively on all 18 wheels during full-on braking.
Add together the weight supported by each tire, and you'll get the total weight of the truck. In the simplest approximation, the maximum frictional force a tire can generate grows linearly with how much weight is on it. So if each tire has the same friction coefficient, the total force will not depend on how many wheels there are. Reality is a bit more complicated, though.
You are changing so many variables that the example is pointless. By far the most important variable in stopping distances is the tires. But do a semi and bike have tires that are in any way comparable? Of course not.
Sportbike tires are very sticky. The tradeoff is that they last only a couple of thousand miles. They're designed for performance at the cost of almost everything else. In contrast, the tires on a semi are meant to last as long as possible and to minimize fuel consumption. It's no surprise that they perform poorly.
As berkeman mentioned, sports cars (which don't come with economy tires) stop as well or better than sportbikes. And the car tires are still less compromised than the bike tires. Stick some R-compounds on the car (which are probably comparable to sportbike tires), and no bike on factory tires could come close.
Anyway, as I mentioned before, the main reason that weight does influence braking distances is because tire friction does not grow linearly with the normal force. It is linear at lower weights, but it eventually starts to deviate a bit when you load the tire enough. Where that deviation starts to become significant is completely different for different tires.
Are you sure about that? I'd be very surprised if trucks couldn't generate enough line pressure to be on the edge of lock-up. Or do you mean that there isn't enough control over all of the axles to distribute the pressure optimally? Do big trucks have ABS?
Most big trucks do not have ABS, not even on the rears. That's why they often lock the rears at the end of hard stops when they are empty. And ABS would just lengthen the stopping distance anyway for full-on braking.
Yeah, I was referring mostly to how the different axles of a fully-loaded semi have different weights on them, so there's no way you could get maximum braking out of all of them at once. Heck, even the dual tire assemblies work against you. And the tractor's 6 tires are going to be loaded differently than the other 12 tires. Plus, I think that for a fully-loaded semi, it would be pretty hard to gnerate enough brake force to get to max braking. I don't think I've ever seen the back 4 tractor tires of a loaded semi lock up under hard braking...
I know this is an old post but
1) When braking the front of the car nose dives causing the car body to pitch forward (till at an angel), does this alter the normal force of gravity (of the vehicles body mass) acting on the all of the tyres Fnorm = M*g*Cosine Angel (Inclined plane, like)?
I think not; because the road wheels are still horizontal with the road, (and presumably the direction of motion hasn’t changed), and all that has changed is only a proportional weight transfer from the rear to front wheels, but I’m not certain.
2) Towing a ‘non-braked trailer’. How do we factor in the Force (m*a) of the un-braked trailer? (The trailer has no brakes of its own)
----------------Force Braking = Ks_g* Mass vehicle = (Mass-vehicle + Mass trailer) * Accel
----------------Accel = (Ks_g) / Mass of the trailer-------------------
At first this looks right, but I’m not sure if we should consider some torque affect due to the diameter of the wheels, but I don't think so?
Willy
A couple weeks ago i started going to driving school, its boring but neccessary. On the first day she said (the teacher) that a fully loaded transport truck will take LESS time to stop than an empty one. her reasoning for this is the weight of the truck pulls it down and slows it faster. i know this cannot be right becuse the weight of that cargo is going to carry momentum and is going to be harder to stop. My dad has been driving truck for 30+ years and he agrees with me, so I am pretty confident with my side of the argument but i need a way to prove it. I've been looking on the net for the past while but the math involved with it is way over my head and i can't find one that involves weight either. Do i need to find the kinetic energy first before i can solve this. i found an equation to find the KE that take speed and weight into factor but i couldn't find an equation that finds braking distance when you know the kinetic energy. if some one knows an equation i could use for this, or some way i can find this out it would be greatly appretiated.
thanks a lot
phil
Of course the only really logical answer for that is :
"Wow, thanks ma'am; I never would have thought of it that way - I will certainly keep my eyes open for trucks, whether they are empty or loaded!"
And if your instructor was male you would say:
"Wow, thanks sir; I never would have thought of it that way - I will certainly keep my eyes open for trucks, whether they are empty or loaded!"
And I do believe a loaded truck will take longer to stop.
If you were to accelerate a truck for 10 seconds, and then apply the brakes to stop - the fully laden truck may certainly stop quicker, but only because it will only have made it to 10 - 15 mph, where as the empty truck may have already reached 30 mph or more!
But if you let both trucks wind up to 40 mph, the empty one is going to stop more quickly, though is more prone to having the trailer wheels lock-up in an emergency stop.
Momentum = M*V and the units are Kg*m/s,This can also be considered as measure of work required to alter your vehicles speed (or Ke (energy required), which is not exactly right, but close enough for the now)
F= m*a, and the units are Newton’s, and this is a measure of Force required (don't confuse your units). If your brakes (that is the brake drum and shoe, not tyres) are working well, then they will always provide the necessary force. But! Ke (momentum) requires work to stop, OR MORE PERSISLY you have to use up the energy, and (on a motor vechile) this is done in the form of heat. Ask your dad what happens when your brakes get to HOT!
So all, that you are left with is the maximum friction that your tyres can exert on the ground Vs change in momentum. As the weight goes up, so dose the friction, but momentum also increase and your tyres only can generate so much friction before they lose traction (blow/disintegrate) and your brakes can only get rid of so much heat!
I think Your teacher is confusing force and acceleration (F=mass*acell and Accel=F/m) with Velocity (Momentum = Mass*velocity)
Thus a loaded truck can take longer to stop, simply because the tyres and braking systems requierd, aren't good enough and/or you can't afford. (Tell your techer there is a maximum speed and weight limit for a reason!).
Note: A very good truck can exert a breaking force (including brakes, tyres, and load) 0f about 1.2 G,’s. A formula 1 car is about 5 G's and cost about $1,000,000. (G’s = G force) and at 5 g’s your chest is pressing so hard against your rib cage it’s hard to breath, also, the average Air-Force fighter pilot will pass out at about 8 G’s, so the limiting factor is the driver).
willyadventur said:
Momentum = M*V and the units are Kg*m/s,This can also be considered as measure of work required to alter your vehicles speed ...
A posting that starts out like this is a real worry.
MOMENTUM and Work don't even have the same unit - so to think if you think that Momentum is a measure of the work needed you are sorely mistaken.
If you double the speed of a truck, you double its momentum, but the work needed to stop it is 4 times as great.
triple the speed, triple the momentum, but 9 times the work needed.
Dear PeterO
Please consider your statement very carefully (which is correct and is supposed to rebut mine)
“If you double the speed of a truck, you double its momentum, but the work needed to stop it is 4 times as great. triple the speed, triple the momentum, but 9 times the work needed”.
Please read my posting carefully “Momentum can be considered as a measure of 'work required' to 'alter your vehicles speed' (or Ke (energy required), which is not exactly right, but close enough for the now). I also said “be careful about confusing your units”, because confuses the hell out of others
Can you see the correlation in your own statement?
I’ll give you a hint it is something about
speed^2 or maybe M^2
Or maybe the MOMENTUM^2
Background information
Momentum = M*v --- (mass times velocity)
v= m/s ----- (m=meters)
Therefore Momentum = M * (m/s)
And the momentum impulse exchanged from one object to another is
N*s = (M*9.8)*s (this means applying a force of 1n for 1 second)
Are you with me so far??
KE= 1/2mv^2 = __(1/2)(kg*m^2/s^2) = __1/2 Mass * V^2 =____= Mass * V^2 / 2_____= joules
Energy = (joules) __ = M*(m/s)^2 __ = M * M^2 / s^2___ = 1 N•m =___1 Joule
(In this case 1n.m is not torque : It is equal to the energy expended (or work done) in applying a force of 1 Newton through a distance of 1 meter (or 1 Newton meter = 1 Newton force applied over a 1 meter distance?).
The formula for Ke is 1/2M*v^2 = 1 joule__ = M*(m/s)^2 = M*v^2----------and Momentum = M*v = M*(m/s) ------ (M=Mass and m=meters)
Are you still with me and starting to see the correlation here??
And Kenetic energy = Momentum^2 / 2*mass
SO you still don't think that the MOMENTUM of a truck driving down the road IS not RELATED to the ENERGY that is required to stop it? OF COURSE IT IS! It all depends on how you want to go about Calculating it and in What Units. But for basic, stick to the basics and don’t interchange your calculations, unless you really know them well.
‘O’ Dear
Dear PeterO
Momentum = m*v (mass times velocity)
v= m/s
Therefore Momentum = m * (m/s)
Energy
Ke = m^2/s^s
1 Joule = 1 N•m = 1 kg•m^2/s^2
The formula for Ke is 1/2m*v^2 = m^2/s^s----------and Momentum = m*(m/s)
‘O’ Dear
willyadventur said:
Dear PeterO
v= m/s
Energy
Ke = m^2/s^s
‘O’ Dear
I am perfectly aware of what momentum is, and I am perfectly aware of what Kinetic energy is. I also know that a change in momentum can be measured by the impulse of a force - Force*time, and that a change in KE can be measured by the Work done by a force - Force* distance.
I also know that you should never ue momentum and Energy in the same sentence other than to say that momentum and energy are completely different quantities.
Energy can be transformed from one type to another - with a braking system the Kinetic energy is converted to heat energy.
Momentum can not be transformed into anything, since there is only one form of momentum. Instead it can only be transferred to another body. Hopefully that other body is only the Earth.
I also stand by my opening statement that any explanation that starts off “Momentum can be considered as a measure of 'work required' to 'alter your vehicles speed'" should be instantly dismissed since it will contain a mish-mash of conflicting concepts and units and have only a passing resemblance, if any, to the Physics of the situation.
You also said " “be careful about confusing your units”, because (it) confuses the hell out of others." Your explanations certainly showed the units "confuse the hell out of you" - not sure about others
Dear PeterO
Does
Kinetic energy = Momentum^2 / (2*mass),
um, Sure it does ,
(but I wouldn't want to confuse Ke with momentum)
MomentumF • t = m • Δ v.
a force of 800 N for 0.9 seconds, then we could say that the impulse was 720 N•s. This impulse would cause a momentum change of 720 kg•m/s. In a collision, the impulse experienced by an object is always equal to the momentum change.
Can we correlate m/s to Distance, Um yes
Work = Force X Distance, but I'm no expert
Can we correlate m/s and distance to Acceleration, Um I think so
Force = Mass X Accl
In this case the colliding object is the tyres which provide the force (mass) to change momentum. And the brakes do work on the Ke in the form of friction and heat
In my original post (two posts ago) I was merely trying to explain an easy way to correlate the change in momentum in the vehicle to brakes to Heat (Ke) to force to tyres without having to go through many sets of various equations for each component. Which I pretty sure I have done. And if I was a computer programmer, who's model would they like best, the long version or the shorter algorithm?
willyadventur said:
Dear PeterO
Does
um, Sure it does ,
Can we correlate m/s to Acceleration, Um I think so
Force = Mass X Accl
Hopefully they would like the accurate description. There is no need to bring momentum into it at all.
Wow. I can't believe the hogwash.
Not a single person commenting has driven a truck or has trucking experience
Not a single automotive technician commented or questioned
Yet so much expertise and numbers
After reading this thread I understand why engineers deliver inferior products to the public because of too many irrelivant numbers and thinking too hard about things till they believe they know so much about things they don't quite understand. You try to solve for X using numbers but experience holds the answers and does not tally or worry over the many formulas.
This one goes down in the DUH file, I can think of a double dozen hard working adults who never finished high school that would call this a no-brainer. Suprisingly this one is way over your heads but is the first thread I've seen consider weight in the stopping equation which is important as all hell but the heads in this thread are way off que!
I am working on virtual modeling, simulation & analysis of Heavy Trucks with Adams/truck.
I need to check the Braking distance at Emergency Braking , I found some results from my simulation , Now I need the fundamentals of braking formula to know more about the theory , please help to find:
1) Relationship between (Formula) : Truck weight (m: mass), Wheel Normal Force , Braking force ,Braking torque , Friction coefficient (μ )
2) Min braking force that lock up Wheels , how it change with truck load? I mean the braking force that need to lock up the wheels is different for empty & fully loaded Truck??
3) Weight effect on Braking force that cause wheel lock up
If there is any books or publication refer
Please give me some ideas to connect my analysis results with theory.
Rather than look up books on how it is supposed to work, I think you would do better to contact a truck company eg Volvo or Mack and try to get some information from their engineers. They would have a far better idea of how it all works.
Peter
Hi everyone, I'm New here (this is my first post). In doing some searching on Google, I came across this thread and thus elected to join.
I know its really old (or at least the original part of the thread) but I figured I could contribute to some extent here for those who come across this in the future and/or anyone how has posted and comes back across this.
The driving school teacher was correct in that a loaded truck / trailer has "potentially" a shorter stopping distance then an unloaded one. The key word there is "potentially". You have to realize that the brakes don't stop the vehicle, the tires do. So if the brakes can convert and dissipate enough energy (kinetic to heat) then the heavier loaded truck can potentially stop sooner.
The reason is cause of how much braking force each of the 18 tires are contributing to the the total braking force.
For the unloaded truck / trailer, the front two wheels are doing about 75% to the total braking and the remaining 25% is being done by the remaining 16 wheels (I.e., they other 16 wheels are contributing very little). This is exemplified by the common a situation of the trailer wheel locking up even under light braking as posted in a previous post cause the trailers tires only contributing about 5% of that remaining 25%. Anything more and they are locked and sliding.
Once the trailer is loaded, the remaining 16 wheels now can generate more total stopping power. In this case, the front wheels only need to contribute about 20% of the total and the rest distributed between the remaining 16.
So in the case of the unloaded truck, you are requiring the two front wheel to do a vast majority of the braking where as load, all 18 wheels are doing more far share.
The same principle applies with cars, mid and rear engine cars that are of equal wheel base and equal weight will out stop a front engine car. This is cause the front engine car ends up with a much higher weight (dynamically) on the front tires and thus they have to do a vast majority of the braking (rears are contributing very little) where as on the case of the rear engine car, the rears are doing a much larger portion of the braking since the tires are more heavily loaded even after dynamic weight transfer has occurred from braking.
I am new here. I am a commercial trucker. I have an interest in physics, as I realize they play a large part in the mechanics of what I do. I have been doing longhaul trucking for years now. Prior to this I was a state certified automotive mechanic for over a decade, and before getting into trucking in 2008, had switched to heavy duty vehicle repair (semi trucks and the like).
Although I am uncertain how to put into a physics formula how it works, the stopping distance of a semi (18 wheeler or a 10 wheeler if equipped with superwide tires) will vary based on road conditions like all vehicles do. This is as a result of where the rubber meets the road. With a typical passenger vehicle (4 wheeler, car, pickup, etc.) most would argue that weight doesn't play an issue. In the Northern USA, pickup truck owners will place sand bags in the beds of their trucks for added traction (either above or behind the rear axle). I know that this traction aids in acceleration, but also balances out the braking in less than ideal road conditions.
With a semi truck and trailer there are a few variables to take into consideration in regards to the initial post. Currently the average 18 wheel or 10 wheel semi and trailer has a maximum gross vehicle weight rating of 80,000 pounds. An empty truck and trailer will not stop as well as a loaded one because the trailer when empty can hop or slide under heavy braking, at the same time however, a fully loaded truck and trailer takes longer to stop. The weight of the load, the way the product is loaded, the type of brake system (as since this topic started disc brakes have entered the trucking world), and other things come into play.
The back story for me coming across this page is a Facebook group post. The driver was hauling an overweight load, and had a hard braking event when a car pulled out of a Mc Donalds parking lot in front of them. The load was pallets of bottled water. The driver locked up the brakes, and almost hit the car. A poster said that had the truck not been overloaded that it might not have caused an issue, and another poster rebutted with the statement that 1200 pounds makes no difference. I am not an engineer, nor a physics professor, so I can't get on my soapbox. I just thought I would share things from my perspective. Perhaps it will do some good, or at least provide food for thought.
Hate to revitalize this, but there is a factor coming from tire loading sensitivity, which will lower the mu, as the load of a tire goes up. so adding weight to a vehicle will most always reduce its deceleration rates, all other things being equal.
~Gelsamel
I won’t take your word for it, because you’re wrong
If the wheel brakes can dissipate the energy and if coefficient of friction is the same, stopping distance doesn’t change with weight
Fr=Kn
N = mg
ma=kng
a=kg
Thread is now closed to try to limit the nonsense necroposts.
  • Love
  • · Replies 21 ·
  • · Replies 17 ·
