Domain of a Function with Sign Graph
4 replies · 3K views · last reply
math4life
Find the domain of the function. You will need a sign graph. Answer in interval notation.
f(x)= (3)/[(x2-4x)1/2]
No clue - I don't know how to use a sign graph or what the positive/negative results mean as solutions on a number line.
I am not sure what a sign graph is.
But the domain is the x values for f being defined. There is a square root, so what is inside can't be less than zero. Since it is a fraction, the denominator can't be zero.
I meant sine graph instead of sign graph. So what do I do? Should I set the denominator to greater than or equal to zero and solve?
I tried solving using the above method but I think my math is wrong. Nonetheless it is wrong because my teacher wants a sine graph on a number line...
1) (sqrt(x2-4x) greater than or equal 0
2) x2-4x greater than or equal 0 (this step is wrong I'm pretty sure - squaring both sides)
3) x2-4x+4 greater than equal 4
4) (x-2)2 greater than equal 4
... ? I still need the sine graph.
I suspect "sign graph" was the correct original intent.
When solving [itex]x^2-4x = x(x-4) > 0[/itex], this boils down to the cases:
[tex]\left\{ \begin{array}{r}{ x > 0 \\ x-4<0} \end{array}[/tex]
[tex]\left\{ \begin{array}{rl} {x<0 \\ x-4 >0} \end{array}[/tex]
This can also be illustrated with a sign graph of x^2 - 4x:
___________________0________4________________
And from this one can determine the domain...
Solving [itex](x-2)^2 > 4 \Rightarrow |x-2| > 2[/itex] is also valid.
--Elucidus
EDIT: Fixed a TeX gaffe.
